Power at your fingertips and protection no matter what the day brings, OtterBox announces the OtterBox Defender Series for the HTC P6500. Following the popular Defender Series design, this case keeps your PDA safe from drops, dust, dirt and scratches while allowing full user interaction. With OtterBox, your P6500 is secure so you’re never out of touch.
“With a variety of applications, the P6500 is used in harsh work environments that require device protection such as oil and gas, agriculture, logistics, medical and consumer product industries,” said Curt Richardson, CEO, OtterBox. “Using this case, companies can save money by preventing expensive repairs or replacements and even downtime, essential in today’s economy.”
The OtterBox Defender Series for the HTC P6500 provides three innovative layers of protection allowing for device mobility:
- Layer one: safeguards keypad, screen and camera from dust and dirt.
- Keypad and screen: includes two optional thermal formed protective clear membranes. One membrane provides a cut-out opening for use with the fingerprint reader. The other membrane covers the fingerprint reader for more complete protection.
- Camera: A scratch-resistant lens shields the camera
- Layer two: hi-impact polycarbonate shell
- Layer three: silicone skin that wraps over the device to absorb bump and shock*
The OtterBox features acoustic vents on the speakerphone and headset speaker to protect while allowing clear sound transmission. Sync/charge jack is accessible through a silicone plug and all buttons, camera and flash remain functional. The HTC P6500 incorporates enhanced security features such as a fingerprint ID sensor, which remains accessible through layer one with the cut-out opening. Case also includes a holster style ratcheting belt clip.
Additional Information:
Environmental Protection:
- Drop and Shock- Protection against drop, bump & shock
- Water Protection- Not tested or recommended for water protection
- Dust Intrusion- Dust does not enter in a sufficient quantity to interfere with satisfactory operation of equipment
Colors:
- Layer 2: black
- Layer 3: black
- Belt Clip: black
Dimensions (case only):
- 5.74 inches X 1.18 inches X 3.18 inches
- 145.8 mm X 30 mm X 80.8 mm
Approximate Weight (case only, including layer 1):
- 90 grams (3.17 ounces)
About OtterBox:
Founded in 1996, OtterBox is highly respected in the design and production of rugged and semi-rugged cases to safeguard technology and other valuables.
Built upon fundamentals of hard work, creativity and perseverance, OtterBox is the innovator of premier protective solutions for leading global handheld manufacturers, wireless carriers and distributors.
*Case NOT fully protected against water. Will provide some added protection against drop, bump and dust. NOT intended for protection against water intrusion.
