OtterBox Case For BlackBerry Storm
Stop traffic and turn heads with the OtterBox Defender Series case for the BlackBerry Storm smartphone from Research In Motion (RIM) (Nasdaq: RIMM). Offering complete interaction with the keys, BlackBerry SurePress touch technology, sync/charge, USB port, camera and more, this case provides a captivating combination of looks and defense from bumps, drops and scratches.
Three essential layers on this case safeguard your BlackBerry Storm smartphone from whatever the day brings:
  • Layer 1: two built-in polycarbonate screens, one over the smartphone screen and buttons and a separate one over the camera and flash.
  • Layer 2: Hi-impact polycarbonate shell
  • Layer 3: Silicone skin to absorb bump and shock
Access your audio jack, as well as the convenience, lock, mute, volume and navigation keys right through the case. Acoustic vents safeguard the microphone, speaker and receiver while maintaining clear sound transmission. The ambient light sensor also remains functional through a polycarbonate window.
Carry your smartphone hands-free with the included ratcheting holster. Also, the BlackBerry Storm smartphone features a magnet proximity sensor which automatically shuts off the display to maximize battery life when stored, a feature fully supported with the OtterBox holster.
From hectic travel to on-the-go work and weekend schedules, the OtterBox for the BlackBerry Storm smartphone unites recognized Defender Series protection in a sleek design ideal for any lifestyle.
Additional Information:
Environmental Protection:
  • Drop and Shock- Protection against drop, bump & shock
  • Water Protection- Not tested or recommended for water protection
  • Dust Intrusion- Dust does not enter in a sufficient quantity to interfere with satisfactory operation of equipment
Colors:
  • Layer 2: black
  • Layer 3: black
  • Belt Clip: black
Dimensions (Case Only):
  • 4.76 x 2.80 x 0.90 in (120.90 x 71.12 x 22.86 mm)
Approximate Weight (Case Only; including layer 1):
  • 0.179 lb (81.2 grams)
About OtterBox:
Founded in 1996, OtterBox is highly respected in the design and production of rugged and semi-rugged cases to safeguard technology and other valuables.
Built upon fundamentals of hard work, creativity and perseverance, OtterBox is the innovator of premier protective solutions for leading global handheld manufacturers, wireless carriers and distributors.
For more information, visit www.otterbox.com or call 888-695-8820.
OtterBox, never out of its element!
Notes:
*Case NOT protected against water. Will provide some added protection against drop, bump and dust.
The BlackBerry and RIM families of related marks, images and symbols are the exclusive properties and trademarks of Research In Motion Limited.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
