DAPs
OtterBox Armor Series Protects the 2nd generation iPod touch
Take your music everywhere with the OtterBox Armor Series™ case for the 2nd generation iPod touch. Listen to your tunes while skiing down a mountain, catching rays at the beach or backpacking through a national forest. Similar to previous Armor Series models, this case incorporates recognized protection from water, dust, dirt, sand and drops; however, the new design features rounded edges for a sleeker, more contemporary look than the original.
“The Armor Series was designed with adventure in mind because people love to take their music with them everywhere,” said Curt Richardson, CEO of OtterBox. “This new case is great for protecting your expensive iPod touch in any environment.”
Lined with impact-absorbing rubber to provide optimal protection for your delicate device, the Armor Series case is ready for life’s extremes. A thin, waterproof membrane protects the touch interface from dust and scratches while still allowing complete device interaction.* Also, this case is compatible with 8, 16 and 32 GB iPod touch 2nd generation models.
The external headphone jack is compatible with any style headphones that have a standard mini stereo plug (3.5mm) and the case comes with a belt clip and removable neck lanyard so you can customize your carrying style.
Don’t miss a beat; protect your iPod touch 2nd generation on any adventure with an Armor Series case from OtterBox!
Additional Information:
Environmental Protection:
  • Drop and Shock — Protection against drop, bump & shock
  • Water Protection — Submersion for half hour at 3 feet
  • Dust Intrusion — Completely protected against dust intrusion
Optional Accessories:
  • Armband
  • Waterproof headphones
Colors:
  • Black with grey accents
Dimensions:
  • 6.0″ X 3.2″ X 0.72″ – excludes headphones and belt clip
Weight (case only):
  • 5.6 oz (0.16 kg)
About OtterBox:
Founded in 1996, OtterBox is highly respected in the design and production of rugged and semi-rugged cases to safeguard technology and other valuables.
Built upon fundamentals of hard work, creativity and perseverance, OtterBox is the innovator of premier protective solutions for leading global handheld manufacturers, wireless carriers and distributors.
For more information, visit www.otterbox.com or call 888-695-8820. OtterBox, never out of its element!
*Note: OtterBox for iPod products are NOT adapted to withstand pressures experienced by scuba diving. Using the incorrect case may cause leakage. OtterBox is not responsible for personal property when used in the incorrect case. For more details, please see our warranty.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
