In-Wall Speakers
Origin Acoustics Announces New Speakers and Subwoofers: CEDIA 2022
The 2022 Origin Acoustics line-up includes in-wall loudspeakers and subwoofers, outdoor / landscape speakers and soundbars.
Origin Acoustics Logo
Origin Acoustics has been a popular exhibitor at the CEDIA Expo in recent years. Launched in 2014, they became the second most popular brand in the in-wall/in-ceiling architectural speaker category by 2019 according to CEPro’s brand analysis (pdf download). Their new range of loudspeakers and subwoofers was introduced at CEDIA 2022; the new lineup includes a mix of outdoor, in-wall, in-ceiling, soundbars, and subwoofers for both residential and commercial installations.
Outdoor Surface Mounted Speakers
Origin Acoustics Outdoor Surface Mount Residential Speakers
Starting off their CEDIA 2022 product announcements, Origin Acoustics has unveiled the latest category expansion in its Surface Mount outdoor speaker line. Three models are available, with either a 5, 6, or 8-inch IMPP (Injection Molded Polypropylene Plastic) high-performance woofer, which delivers great low-end response from a sealed enclosure.
In addition to the woofer, the speaker has a 1-inch aluminum tweeter that is designed specifically for outdoor environments.
The C Bracket combined with the screw-down end caps allows for maximum vertical and horizontal mounting options.
These speakers are great for outdoor applications and carry an IPX6 rating with UV resistance for better reliability.
Slim Commercial Speaker
Origin Acoustics Slim Commercial In-ceiling/In-wall Speaker
The PC60S speaker features a new slim design that is UL 1480A approved, consisting of a 6.5-inch IMPP high-performance woofer with a 1-inch DPSD silk tweeter for a smooth and balanced sound.
The speaker is enclosed in a metal back can with a depth of 4.35-inches allowing dealers to install this product where most normal 8-inch depth speakers won’t fit. The speaker has front-mounted adjustable impedance settings for 8 ohms, along with 70v/100v, with multiple wattage taps for each, and is concealed by a thin bezel magnetic grill.
Professional 70v Surface Mount Speakers
Origin Acoustics Pro Outdoor Surface Mount 70v Commercial Speakers
In this speaker line, there are 3 UL 1480A-approved models available. The speakers include a 5, 6, or 8-inch IMPP high-performance woofer, which is designed to deliver strong low-end performance from the front-ported enclosure.
The woofer is accompanied by a 1-inch aluminum tweeter designed specifically for today’s high-demand commercial applications. Front-mounted wiring and adjustable impedance settings for 8 ohms, along with 70v/100v with multiple wattage taps for each, allow for easy installation.
These speakers are perfect for indoor or outdoor applications and carry an IPX6 rating with UV resistance.
Ambisonic Big Bollard Landscape Speakers
Origin Acoustics Ambisonic Big Bollards Landscape Speaker
The Big Bollard Landscape speakers from the Origin Acoustics Ambisonic brand are designed to deliver incredible performance from a beautiful design for any Residential or Commercial outdoor application.
The speakers are available with round or square aluminum sleeves in silver, black, and bronze.
Each speaker contains a 10-inch subwoofer, a 6.5-inch polypropylene mid-range and a round planar magnetic ribbon tweeter. This tweeter design allows 360° dispersion. The tweeter is treated with a Kapton coating utilizing a special application process, which allows the product to stand up to the outdoor elements without impacting the sound.
For installation flexibility, each speaker has an adjustable impedance setting for 8 ohms, along with 70v/100v with multiple wattages. The speakers have a 30hz to 40Khz frequency response and can handle up to 300 watts of peak power.
Minimal Opening System Design Centric Speakers
Origin Acoustics Min Opening Speaker System
The new MOS36 is the latest addition to the minimum opening system line of products from Origin Acoustics.
An easy-to-install enclosure provides a very low-frequency response from a 6-inch fiberglass woofer, which ports around a 2-inch wide-band aluminum driver, providing a well-balanced sound from a design-centric 4-inch opening.
The system includes 6 different finish options, in the square, round, and both flushed and surface mount options, along with the necessary spacers to adjust for various surface material thicknesses.
The MOS36 is the latest in a series of products that address the interior design needs of today’s modern homes, while still delivering the high-performance sonic experience that customers are looking for.
Slim Powered Subwoofer
Origin Acoustics Subs10 In-wall Subwoofer
Origin Acoustics further expands its line of subwoofers with the SUBS10 Slimline Subwoofer
The subwoofer incorporates a 10-inch woven fiberglass woofer and a built-in amplifier that delivers up to 400 watts of peak performance.
The SUBS10 installation has flexibility with wall mount or in-room options, and with a depth of less than 5-inch the product can even fit under furniture without being seen.
A USB output is available for powering an optional wireless receiver. This provides more convenience as it reduces wire clutter while still delivering deep bass down to 35Hz.
This subwoofer is the latest addition to Origin Acoustics Design Centric Technology™ line of products, engineered with both performance and the ability to blend into any environment.
New Soundbars
Origin Acoustics Soundbars 2022
The new line of Origin Acoustics soundbars includes several unique features designed to address the cosmetic needs of consumers, along with the installation flexibility needed for today’s design-centric homes.
Tip: The Origin Acoustics soundbars are passive, which means they require external amplification to operate.
The line consists of 8 multi-channel models, which align with most TV widths and utilize Origin’s patent-pending InstaWidth™ design. This allows you to adjust each end cap up to .75 inches, allowing for 1.5 inches of total adjustment. VesaMatch™ mounting design by Origin Acoustics provides easy installation.
There are also 2 LCR models available for on-wall home theater applications. All the soundbars utilize a mix of 3.5” fiberglass drivers along with 1-inch DPSD Silk dome tweeters wrapped in an aluminum cabinet for improved sound clarity.
The new Origin Acoustics soundbars are designed to meet the needs of Design Centric Installations™ without sacrificing audio performance.
Availability and Pricing
For availability and pricing info for all Origin Acoustics products refer to their website and dealer/installer network
Origin Acoustics Acquires Ambisonic Systems
Pro Audio Technology’s SR-2408iw Loudspeakers Deliver Big Sound in Tight Quarter: CEDIA 2022
Pro Audio Technology Launches The Intelligent SR-28212ai Loudspeaker
Theory Audio Design’s Iws12-6 & Iws12-9 In-Wall Subwoofers Are Going To Shake Your Foundation: CEDIA 2022
Discover More New Products from CEDIA 2022
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Owners of Samsung's 2024 HW-Q990D, HW-Q800D, and HW-S801D models have a big and annoying problem... Here's what to do if your soundbar is affected.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
Does Sony's advanced new wireless home theater system earn its lofty price tag?
Our favorite in-ceiling and in-wall speakers and subwoofers for distributed audio and home theater will be heard, but not seen.
