Orchard Audio Introduces Starkrimson Duo/Trio GaN Power Amplifier
We’re starting to get excited about GaN power stages. The Orchard Audio Starkrimson Duo/Trio is the fourth power amplifier in less than two weeks utilizing the technology that we’ve seen or heard.
Orchard Audio Starkrimson Trio Amplifier Front Top
Expect to read a lot about GaN power stages going forward; William Jennings spent a lot of time at T.H.E. Show listening to 3 other power amplifiers that utilize the technology and you can read his detailed explanation of how it works here.
Orchard Audio and AGD Productions have taken different paths with their respective products and you might notice a significant difference in the pricing as well. AGD’s most affordable GaN power amplifier is almost $2,500 more expensive than the Duo/Trio.
Orchard Audio is introducing the Starkrimson Duo/Trio amplifier. The Duo (dual mono) configuration is a stereo amplifier. The Trio (triple mono) configuration is perfect for driving the front three channels in a home theater, as well as for 2.1 systems.
Orchard Audio Starkrimson Trio Amplifier Back Top
This latest design fully explores the benefits of the latest gallium nitride (GaN) transistors, providing less harshness, cleaner highs, and better overall transparency and detail, and much lower noise levels.
The pulse-depth modulation (PDM) is performed completely in the analog domain before being amplified by the GaN power stages.
Starkrimson amplifiers use Orchard Audio’s proprietary DC-coupled, fully balanced dual feedback modulator, which allows the amplifier to be completely balanced from input to output, through the use of bridged GaN power stages.
This unique triple (or dual) mono design is packaged in an aluminum and steel chassis with high-end gold-plated binding posts and connectors.
Features:
  • Fully balanced from input to output
  • Power: 150 watts (300 watts peak) per channel
  • Extremely low noise and distortion
  • 2-ohm capable
Specifications:
  • Signal-to-Noise Ratio (SNR): 121dB (A-weighted, 22kHz BW)
  • Frequency response: DC – 80kHz+
  • Gain (balanced input): 16.8dB or 21.5dB
Orchard Audio is offering pre-order prices (starting at $1,399.95 for Duo and $2,249.95 for Trio) on its website until the end of July 2023. Starkrimson Duo/Trio amplifiers will start shipping in August/September.
Additional specifications and test results are available on Orchard Audio’s website.
Related reading: Orchard Audio’s New PecanPi+ DAC and Streamer Feature AKM’s Latest Flagship Chips
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
At $2,199, the TEAC AP-507 power amplifier can be configured for two channel stereo, bi-amp, or bridged.
At $1,999, Orchard Audio Valencia is a balanced desktop power amplifier designed for headphones, but powerful enough for speakers.
Using GaN technology, Starkrimson Mono Ultra Premium power amplifier boasts 250-watts of power at 8 ohms, 500-watts at 4 ohms.
Digital Music Systems
Does the $299 WiiM Amp streaming amplifier deliver on its long list of features? Power, multi-room audio support, and surprising build quality makes this...
Ask an Expert
Understand the basic audio components of a Hi-Fi stereo system so you know what to look for when shopping for audiophile equipment.
Allen Sides of Ocean Way Audio and Alberto Guerra of AGD Productions join us to discuss their collaboration during T.H.E. Show 2023.
AGD's implementation of GaN transistor technology requires some explanation but it truly offers something unique and exciting in sound reproduction.
AR Tube Audio Corporation has purchased Audio Research at a critical moment and saved the legacy high-end brand from extinction. Acora Acoustics' Valerio Cora...
