Optoma’s UHZ35ST Short Throw Laser Projector Delivers 4K Resolution and 30,000 Hours?
Optoma announces the UHZ35ST Short Throw Laser Projector providing home theater and gaming in UHD 4K resolution through pixel shifting.
Optoma UHZ35ST Short Throw Projector
You have to love the skillful art of public relations; and this is not to just pick on the manufacturer that actually makes some very good projectors that deliver excellent value for the money, but how many people will place this on a coffee table to create that 100-inch image? Let’s dig a little deeper into this. Optoma has announced its new UHZ35ST short throw projector. The UHZ35ST incorporates a laser light source, and 4K UHD resolution via pixel shifting.
Building on the foundation of its previously popular UHD35STx, the UHZ35ST replaces the former’s limited life lamp-based light source with Optoma’s 30,000 hour (In Eco Mode) DuraCore laser light source
UHD Resolution via Pixel Shifting
DLP 4K Pixel Shifting
The laser light source is also combined with a .47-inch 1080p resolution DLP imaging chip (aka DMD – Digital Micromirror Device) from Texas Instruments. The chip contains 2.1 million pixels (very tiny mirrors). The projector is able to display 4K UHD resolution (8.3 million pixels) via shifting the pixels on the 1080p chip both vertically and horizontally at 240Hz (240 times per second). This process is so fast the image displayed on the screen is classified as a 4K UHD resolution image.
Short Throw Lens
Optoma UHZ35ST Short Throw Projector Lifestyle
To support a large-screen viewing experience, the Optoma UHZ35ST incorporates a short-throw lens. This allows the display of up to 100-inch images from about 3.6 feet away from the screen; which allows users to experience large-screen home theater or gaming even in smaller rooms. The UHZ35ST also has a compact design that is 34% smaller than the previous UHD35STx.
Keystone Correction
To position the image on the screen properly, the UHZ35ST is equipped with horizontal and vertical keystone correction, as well as 360° and portrait mode operation.
Gaming
The UHZ35ST delivers a fast input response. With four times the standard refresh rate at 240Hz in 1080p and an ultra-low-input lag of 4ms for PC gaming.
Gaming with Optoma UHZ35ST Short Throw Projector
Entertainment Content Access
Dual HDMI inputs provide connections for game consoles, set-top boxes, laptops, PCs, Blu-ray players, or media streamers via a single cable. You can also connect an HDMI dongle streaming device like the Google Chromecast, Amazon Fire TV, Apple TV or Roku stick.
Additional Specifications
  • Resolution: 4K UHD (3840×1260) via pixel shifting
  • Light Output: 3,500 lumens
  • Contrast Ratio: 500,000:1
  • HDR: HDR10 and HLG compatibility
Optoma UHZ35ST Short Throw Projector with HDR
  • 3D Viewing Mode: Full HD 3D, Compatible with 3D Blu-ray, 3D Gaming, and more… (requires additional glasses purchase)
  • Throw ratio: 0.496:1
  • Screen Size Range: 36 to 300-inches
  • Projector Distance: 15.75 to 129.92 inches
  • Noise level: (typical) 28dB, (max) 30dB
  • IP rating: IP6X
  • Light source: DuraCore laser light source with up to 30,000 hours of maintenance-free operation (in eco mode)
  • Gaming Support: Built-in Enhanced Gaming Mode with 4ms response time in 1080p at 240Hz and 16.9ms response time in 4K at 60Hz
  • Audio:  1 speaker with built-in amplification (15 watts system output)
  • Connectivity: 2x HDMI ver 2.0 in, 3.5mm Audio out (allows connection to an external audio system), USB-A power 1.5A, RS232, RJ45
  • Standard Control Options: Wireless Remote Control (card style), On-board Touch Controls
  • Custom Control Options: RS232, AMX, Crestron RoomView, Extron IPLink
  • Power Supply: External Plug-in
  • Eco-Sustainability: The UHZ35ST’s chassis is made up of 50% post-consumer recycled (PCR) materials.
Optoma UHZ35ST Short Throw Projector Rear Connectivity
Optoma UHZ35ST Short Throw Projector Controls
Optoma UHZ35ST Short Throw Projector Power Supply
From Oliver Blundell, Product Manager at Optoma: “The new UHZ35ST offers all the top features that have made our popular UHD35STx a favorite, boasting an industry-leading low latency and flexible short throw performance,… Paired with a new laser light source and more sustainable chassis, the UHZ35ST guarantees greater energy efficiency for elevated home entertainment and gaming experiences.
Key Differences
Here is a comparison of some of the key features of the UHZ35ST and the UHD35STx that it is replacing.
Feature/SpecificationUHZ35STUHZ35STx
Light SourceDuracore LaserLamp (240 watts)
Light Source LifeUp to 30,000 Hours4,000 to 10,000 hours depending on the light mode setting)
Light OutputUp to 3,500 LumensUp to 3.600 Lumens
Contrast Ratio500,000:11,000,000:1
Keystone CorrectionUp to + or – 15 degrees Horiz/VertUp to + or – 40 degrees Horiz/Vert
Lens ShiftNoYes – Vertical +0%
SPDIF (digital optical) Audio OutputNoYes
Audio System1 speaker x 15 watts 1 speaker x 10 watts
Dimensions (WDH)10.79 x 8.4 x 4.49 inches12.4 x 10.63 x 4/65 inches
Net Weight6.61 l lbs7.72 lbs
Price$3,299 US
$4,499 CAD
$1,396 US
$2,238 CAD
Optoma UHZ35ST Short Throw Projector Front
Availability and Pricing
The Optoma UHZ35ST is available for purchase in the United States for an estimated street price (Amazon) of $3,299 at Amazon or $4,499 at Amazon.ca
Tip: The Optoma UHD35STx is available with a street price of $1,396 at Amazon or $2,238 at Amazon.ca
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
