Optoma Debuts UHZ68LV 4K UHD Laser Projector at ISE 2025
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Optoma UHZ68LV Projector Front Angle
With so much hype being showered on extra large screen TVs like the 98-inch models from TCL and the 116-inch model (116UX) shown at CES 2025 from Hisense one would think that manufacturers had thrown in the towel on video projectors.
We still think it’s going to be a few years before high-end projectors become a niche category that will only appeal to those spending six figures on a custom home theater set-up. Quality matters and the price of microLED TVs that can be assembled into something over 120″ will take some time to come down.
So why are manufacturers still developing new projectors?
Those who buy into the dedicated home theater experience still feel that projectors provide a more cinematic experience making them a viable large-screen home theater viewing option. With that in mind, Optoma is showing its latest high-end projector, the UHZ68LV at ISE (Integrated Systems Europe) 2025.
With advanced features, the UHZ68LV redefines Optoma’s visual product lineup, designed to deliver an elevated home cinema experience.
The UHZ68LV displays 4K UHD resolution (via pixel shifting), powered by Dual-Laser Technology with high brightness, and color accuracy. With a peak white brightness of 5000 lumens and 90% DCI-P3 cinema-grade color accuracy, the UHZ68LV projector is designed to deliver bright images on screens as large as 300 inches, even in rooms where some ambient light is present.
Optoma Laser Light Engine
With its light output capability, the UHZ68LV can display Dolby Vision and HDR10+ HDR formats more accurately, dynamically optimizing each frame, with a high level of contrast, color accuracy, and detail.
The UHZ68LV incorporates Optoma’s PureEngine™ Ultra processor for home cinema, which is optimized for home theater. The processing supports smooth motion, sharp details, and precise color reproduction. The addition of Filmmaker Mode also preserves the director’s original vision, while ISF calibration modes optimize images for any viewing environment.
To make physical setup easier, the UHZ68LV has 1.6x zoom, lens shift, and 360-degree projection capabilities. The projector can be placed in the front, or rear, or mounted on the ceiling in relation to the screen. This makes it flexible for installation in almost any room environment.
Tip: The UHZ68LV is a standard throw projector, unlike UST projectors, the UHZ68LV needs to be placed from 1 to 12 meters from the screen, depending on the desired screen size.
Optoma UHZ68LV Projector Rear
Specifications
Model Optoma UHZ68LV
Price£3,999 (US pricing forthcoming)
Display TechnologyDLP™
Native Aspect Ratio16:9 (compatible with 4:3, 21:9, 32:9)
Resolution4K UHD (3840×2160) – via pixel shifting Note: 3D images displayed in 1080p.
Light SourceDual laser light source with up to 30,000 use-hour life
Brightness (WLO – White Light Output)5,000 lumens
Contrast ratio3,200,000:1  (Dynamic Black On)
Screen Size Range0.78m ~ 7.65m (30.6″ ~ 301.1″) diagonal
Projection distance (m)2.1M@80” ~ 12.75M@300″
Throw ratio1.2:1 ~ 1.92:1
Focal length (mm)17.63mm~27.88mm/0.694″~1.097″
Native offset126%
Zoom1.6 (manual)
Lens shiftVertical -106 ~ 126%, Horizontal –10 ~ 10%
Keystone CorrectionHorizontal +/-30°, Vertical +/-30°
Horizontal scan rate15 ~ 255Khz
Vertical scan rate24 ~ 240Hz (240Hz for 1080p)
Screen Uniformity85%
Inputs1 x HDMI 2.1, 2 x HDMI 2.0 (eARC)
Outputs1 x USB-A power 1.5A,
2 x USB-A power 0.9A,
1 x 3D sync,
1 x Audio 3.5mm,
1 x S/PDIF
Noise level 25dB (min)/31dB (max)
SecuritySecurity bar, Kensington Lock, Password protected interface
OSD / Display languages25 languages (refer to user guide)
24/7 operationYes
360° operationYes
Operating conditions0°C~40°C/32°F~104°F, max. altitude 3,048m/10,000ft, max. humidity operating 80%, non-operating 90%
Speaker System2 x 5 watts (10 watts total)
Dolby Atmos Pass-ThroughYes – via HDMI-eARC
Input Lag (Gaming Support)8.50ms
ControlBacklit Remote,
1 x RJ45,
1 x RS232,
2 x 12V trigger
NetworkingLAN Control
Power supply100 ~ 240V, 50 ~ 60Hz
Power Consumption 0.5W (standby),
165w (min),
345w (max)
Dimensions (WDH)498 x 331 x 171mm
(19.61 x 13.03 x 6.73 inches)
Net weight9.2kg (20 lbs 4oz)
Included AccessoriesAC power cord, Remote control, 2 x AAA batteries, Quick start user manual
The Bottom Line
Optoma has a great track record when it comes to video projectors and it looks like they have brought the right one to introduce at ISE 2025. The UHZ68LV has the core features and specifications you would expect for a projector targeted to the custom install market, as well as being suited for Institutional and commercial applications.
One weakness of projectors is that they are not as bright as most TVs, but with the capability of being able to put out as much as 5,000 lumens, that should go a long way towards the UHZ68LV being able to take advantage of HDR and 3D without disappointing results.  However, it must be noted that Optoma did not provide information on what Lumen standard they were using.
The only other downside is the absence of a decent built-in speaker system – However, those who purchase this projector most likely have a home theater system already (or considering one as a companion purchase) – and the UHZ68LV does provide Dolby Atmos pass-through for decoding by a compatible external AVR.
For those attending ISE 2025 Optoma is in Hall 3, stand 3D500, at the Fira de Barcelona, Gran Via in Spain.
Price & Availability
The UHZ68LV has an RRP of £3999.99 (US pricing forthcoming), Availability through authorized dealers TBD. For more information, visit: optoma.co.uk/product/uhz68lv.
Audio Technica ATH-R30x Open Back Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Lots of power, bridgeable configuration options, and rack-compatible sizes add flexibility to any custom home theater setup.
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
In-Wall Speakers
The Focal Utopia CINEMA LCR and Subwoofer are designed for luxury home theater set-ups in large spaces.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
