Optoma Unveils ML1080 and ML1080ST Compact Laser Projectors: Infocomm 2023
Optoma’s ML1080 and ML1080ST Compact Laser Projectors offer a high performance and portable option for your backyard movie theater.
Optoma ML1080 Compact Laser Projector
Infocomm 2023 just concluded and whilst the show is focused on the latest in audio and display technology for business and institutional applications, there are always a few products for the consumer market that stand out.
There are two new projectors from Optoma that deserve attention, the compact ML1080 and ML1080ST. These projectors are extremely compact and portable but don’t sacrifice performance features. Let’s take a closer look.
Optoma ML1080/ML1080ST Connections Rear
Core Features
Standard and Short Throw Versions: The ML1080 and ML1080ST incorporate the same features with one exception, they have different lens assemblies. The ML1080ST can project a 100-inch image from a distance of 5 feet, while the ML1080 requires a longer projector-to-screen distance of about 8 feet/9-inches to project a 100-inch image.
Light Engine: Both projectors incorporate Optoma’s DuraCore RGB Triple Laser light source for consistent white and color light output that supports up to 30,000 hours of use.
Display Technology: ML1080 series projectors incorporate a DLP Imaging Chip. In addition to the laser light source, the image information is provided by a DLP imaging chip (aka DMD – Digital Micromirror Device) from Texas Instruments. The DLP chip has 2.1 million pixels (1080p FHD resolution), which are very tiny mirrors that angle back and forth very rapidly to produce the light and dark parts of the image in combination with the reflected laser light source that adds color.
Time of Flight
Time-of-Flight (ToF) Technology: This delivers automatic geometric and focus correction to create precisely proportioned projected images. Four-corner correction provides a quick place-and-play projected image setup.
USB-C Power: Home users can take advantage of the convenient USB-C power input port, enabling them to use PD 3.0 portable charging batteries, to enjoy video content on the go for outdoor movies, camping, holidays, and more.
Creative Cast Compatible: Via the Optoma Creative Cast App (iOS, Android), you can access the following capabilities with the ML1080 and ML1080ST projectors:
  • Mirror the screen from your laptop or mobile device.
  • Wirelessly broadcast, share, or stream photos and documents from a laptop or mobile device.
  • Share content between rooms and control your presenting device from the palm of your hand.
Optoma ML1080 Compact Laser Projector for meetings
Specifications
  • Brightness: 1,200 lumens
  • HDR Support: HDR10 and HLG (Hybrid Log Gamma)
  • Contrast Ratio (Native): 1,200:1
  • Contrast Ratio (Dynamic): 3,000,000:1
  • Native Aspect Ratio: 16:9 (can be adjusted to both 16:9 and 4:3 aspect ratios.
  • Keystone Correction: Vertical +/-40° (Auto or Manual)
  • Horizontal Scan Rate: 15  to 140Khz
  • Vertical Scan Rate: 24 to 240Hz
  • Screen Uniformity: 90% – This represents how well the projector can display an image with consistent color and brightness across the entire screen surface.
  • Diagonal Screen Size Range: 60 to 100-inches
  • Throw Ratio (ML1080): 1.2:1
  • Throw Ratio (ML1080ST): 0.78:1
  • Projection Distance (ML1080): 62.76 to 104.61 inches
  • Projection Distance (ML1080ST): 40.79 to 67.99 inches
  • Zoom Type: Fixed
  • Noise level (typical): 25dB
  • Noise level (max): 28dB
  • 3D Compatibility: No
  • IP Water/Dustproof RatingIP5X
  • Audio System: 1 speaker/3 watts
  • Security: Kensington Lock
  • Dimensions (WDH): 6.18 x 5.31 x 2.68 inches
  • Net Weight: 2.2 lbs
  • Inputs: 1 x HDMI 2.1, 1 x USB-C power, 1 x USB-A power (1.5A), 1 x USB-A power (0.5A0
  • Output: 1 x Security: Kensington Lock, Audio output – 3.5mm
  • Wired Control: 1 x RS232 (via mini USB connector)
Optoma ML1080 Compact Laser Projector fits in bag for easy travel
Availability and Pricing
The Optoma ML1080 and ML1080ST are available for purchase from Authorized Optoma Dealers.
Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Sony's 2025 ULT wireless speaker line-up. Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Totem Tribe Tower Thunderbird Speakers Drivers Close-Up Totem Tribe Tower Thunderbird Speakers Drivers Close-Up
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Vertere DG-X Turntable Red Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Sony just brought its most powerful video processor for projectors down to what should be a much more affordable price point.
At $3,795, does the Leica Cine Play 1 portable projector offer enough in comparison to its rivals from Hisense and Formovie?
The next generation of DLP chips for projectors will be 90% smaller, which could unlock new product innovations.
Priced at $1,799 or $1,999, BenQ offers gamers new laser projectors that are nearly identical. Find out which one is right for you.
At $1,899, the Dangbei DBOX02 is a featured packed portable 4K lifestyle projector that includes Netflix built-in for simplified streaming.
The Optoma GT3500HDR 1080p UST projector can do 100-inch diagonal from less than a foot away from the screen and accepts 4K/HDR inputs for...
At $2,499, the Optoma UHZ55 replaces the UHZ50 laser projector designed for home entertaiment and gaming. New WiSA support simplifies wireless speaker setup.
If you are looking for a traditional style video projector, but updated with the latest tech, such as 4K resolution, laser light source, and...
