OPPO UDP-205 4K Blu-ray Player Built for Audiophiles
OPPO UDP-205 4K Ultra HD Audiophile Blu-ray Disc Player
Flagship Disc Player for Audiophiles
OPPO Digital announced its best disc player to date, model UDP-205. The $1300 4K Ultra HD Blu-ray Disc player brings top-of-the-line audio performance to a universal player that supports 4K Ultra HD Blu-ray and many other digital audio and video formats.
The OPPO UDP-205 is a step-up version of the recently released UDP-203 ($550) that offers many of the same features: playback of 4K Ultra HD Blu-ray, regular Blu-ray, Blu-ray 3D, DVD-Video, DVD-Audio, SACD, Audio CD and many other formats; High Dynamic Range (HDR10) and firmware upgradable to Dolby Vision; dual HDMI outputs – HDMI 2.0 for UHD and HDMI 1.4 for audio; and an HDMI 2.0 input port for external streaming devices or set-top boxes.
The UDP-205’s audio performance is significantly upgraded over the UDP-203 and previous generation players. The UDP-205 provides reference level sound quality through the analog outputs, improves the clock precision of the HDMI audio output, and increases the power of the built-in headphone amplifier. For the analog output stages, the UDP-205 utilizes two ES9038PRO DACs, which are the flagship of the ESS Sabre Pro series, delivering best-in-class audio performance.
The UDP-205 offers a dedicated stereo output in addition to its 7.1-channel analog audio output. The stereo audio output is powered by a dedicated ES9038PRO DAC chip and specially designed buffer and driver stages. It provides both XLR balanced and RCA single-ended connectors. The balanced output features a true differential signal path all the way from the DAC to the 3-pin XLR connector. By transmitting a pair of differential signals, the balanced output provides better common-mode noise rejection and improves signal quality. For a more intimate listening experience, headphones can be connected directly to the UDP-205’s built-in headphone amplifier. The headphone amplifier is connected directly to the ESS SABRE PRO DAC and offers a unique performance advantage over standalone headphone amplifiers. Compared to the built-in headphone amplifier in our previous generation BDP-105/105D players, the new design offers more power and higher performance.
In addition to its playback capabilities, the UDP-205 adds a USB DAC, a coaxial and an optical digital audio input so users can take advantage of the excellent audio performance of the UDP-205 with other sources. The asynchronous USB DAC input supports sample rates up to 768 kHz PCM and DSD 512. By bypassing the low fidelity, poor quality DAC of traditional computer soundcards, the UDP-205 turns any computer into a high performing multimedia source by utilizing the ES9038PRO DAC. For additional convenience and flexibility, the UDP-205 can convert digital signals from cable and satellite boxes, televisions, video game consoles and other digital transports with coaxial and optical digital outputs to analog.
The UDP-205 features a high-stability, high-precision HDMI clock and a special HDMI audio jitter reduction circuit. This unique design significantly reduces jitter and eliminates timing errors, allowing customers to enjoy their music with increased accuracy when they use the audio-only HDMI output port for connecting the audio signal. PCM and DSD signals rely on the HDMI clock directly, so the HDMI audio jitter reduction circuitry can improve the sound quality of PCM and DSD audio. For compressed bitstream audio, it helps to ensure error-free transmission, and may improve the audio performance depending on whether the audio decoder in the A/V processor or receiver uses a synchronous or asynchronous clock scheme.
The company says advanced engineering, rigorous parts selection, and rock-solid build quality are foundations to the UDP-205’s performance. The UDP-205’s audio circuitry is powered by a massive toroidal power supply, which provides a very clean and robust power source to the audio components. The front panel is made of brushed aluminum attached to a metal chassis. Four heavy-gauge machined feet provide a stable foundation for the UDP-205, and isolate it from outside vibration. A new double-layered chassis further enhances the rigidness and vibration-canceling capabilities. The internal layout and chassis design promote healthy air flow so critical components can be naturally cooled. Strategically placed heatsinks and ventilation grilles allow the UDP-205 run both cool and quiet without the need for internal or external fans.
Price and Availability
The OPPO UDP-205 is now available for $1,299 at Amazon and is expected to start shipping April 28, 2017. Soon after you could find it at specialty retailers and custom installers.
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
