Onkyo Ups Ante for Entry Level Receivers with 7.1-Channel TX-SR503
New entry level model features step-up D/A converters, seven amplifier channels, and three component video inputs for greater performance and flexibility
UPPER SADDLE RIVER, NJ (04/12/05) — Onkyo has introduced the TX-SR503 A/V receiver, improving upon the company’s popular TX-SR502 with upgraded processing, improved connectivity, and a seventh amplifier channel. The model includes a wide array of features for home theater, including 7.1 channel processing, HDTV capable component video switching, and a newly designed preprogrammed remote control. This Onkyo TX-SR503 is currently available in both black and silver finishes at a suggested retail price of just $300.
The TX-SR503 boasts wide bandwidth component video switching with three inputs to switch up to three high definition and progressive-scan sources without degrading video quality. There are three A/V inputs with both composite and S-Video connections, plus a front panel A/V input for convenient connection of portable devices. The receiver has four assignable digital audio inputs with one coaxial and three optical connectors, RCA line-level connections for a CD player and audio recorder, and a subwoofer preamplifier output.
The TX-SR503 features a full suite of processing for home theater, including Dolby Digital EX, DTS-ES, and even DTS 96/24. With DTS Neo:6 and Dolby ProLogic IIx, the receiver is capable of automatically deriving full 7.1-channel audio from absolutely any stereo or multichannel source. The receiver features upgraded high quality linear PCM 192 kHz/24-bit D/A converters and a sophisticated 32-bit DSP engine for ideal reproduction of soundtracks and multichannel audio.
The Onkyo TX-SR503 includes seven internal power amplifier channels with high-current, low-impedance discrete output devices, to deliver a continuous power output of 75 Watts per channel into 8-Ohm loads. Onkyo’s WRAT (Wide Range Amplifier Technology) gives the power stage a linear frequency response from 10 Hz to 100 kHz to ensure it’s up to the challenge of the most demanding audio sources, such as SACD and DVD-Audio. There are dual banana-plug-compatible multi-way speaker binding posts for all main channels with color-coding for simplified wiring, as well as front channel “B” terminals to enable the receiver to drive a stereo pair in a second zone.
The dot-matrix fluorescent front panel display makes setup and operation of the receiver easy and fast, including variable speaker configuration and distance settings for simple optimization of any speaker arrangement. With the new adjustable crossover on the subwoofer pre-out channel, the LFE channel signal can be cutoff at 60, 80, 100, 120 or 150 Hz, for seamless integration of any satellite and subwoofer combination.
The receiver’s high quality AM/FM tuner section has 30 random presets, and FM automatic scan tuning. The included RI (Remote Interactive) compatible preprogrammed remote control has been redesigned for improved simplicity, making control of an entire entertainment system simple and convenient.
The TX-SR503 is currently available in either black or silver finishes at a suggested retail price of $300.
Onkyo has also introduced the 5.1-channel TX-SR303 A/V receiver, a 65 Watt per channel budget receiver with Dolby Digital, DTS, and ProLogic II processing. It features the same 192kHz/24-bit DACs found in the TX-SR503, and four A/V inputs with both composite and S-video capability. The TX-SR303 is available in silver finish at a suggested retail price of just $200.
http://www.gspr.com/onkyo/txsr503.html
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
