Onkyo’s TX-RZ30 AVR Is Packed With Features: CEDIA 2024
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Onkyo TX-RZ30 A/V Receiver Lifestyle
With the increased popularity of soundbars and streaming amplifiers, the traditional AVR (AV Receiver, Home Theater Receiver) seems to have taken a back seat in the last couple of years, as the introduction of new AVR models is becoming less frequent. However, they still have an integral part to play in the home theater environment and with that in mind, Onkyo is releasing the latest entry into the high-end RZ series, the TX-RZ30.
The Onkyo TX-RZ series currently consists of two models, the RZ70 released in 2023, and the RZ50 that was released in 2021. Looking at the release dates, it is the right time to either replace the RZ50 or add a newer, lower-priced model to the mix. The latter is where the RZ30 seems to come in: a new entry point to Onkyo’s high-end RZ series receivers. Our comparison chart at the end of this article will give you a better idea of how it fits into the line-up..
Onkyo TX-RZ30 A/V Receiver Angle
Features
Just as the RZ50 and RZ70, the RZ30 is THX-Certified, which assures consistent performance.
With nine amplified channels and two subwoofer outputs, the RZ30 supports up to a 5.2.4 or 7.2.2-channel home theater speaker setup. Two additional wired zone preamp outputs are also provided that support Zone 2 and Zone 3 controllable two-channel stereo set-ups.
To manage the several speaker setup options, the RZ30 has Dirac Live room correction built-in (full-bandwidth version – license included). This allows users to fine-tune their speaker setup to more accurately match room acoustics. The room correction process can be accomplished via the Dirac PC/MAC app and USB mic (requires additional purchase).
Dirac Live requires a network/internet connection. Dirac Live Bass Control is also available as an optional one-time $299 charge.
Pro Tip: Klipsch Optimized Mode is also included for peak performance with compatible Klipsch-branded hi-fi speakers.
As mentioned at the top of the article, the RZ30 incorporates a 9-channel amplifier (Class A/B) rated to deliver 100 Watts per channel (8 ohms). Support is provided for Dolby Atmos/Dolby Atmos Music, DTS:X, as well as IMAX Enhanced and additional surround sound processing.
24-bit/192kHz Hi-res audio playback is supported. Digital audio format file format compatibility includes MP3, WMA, WAV, MPEG-4/AAC, FLAC, and ALAC.
For access to Music streaming content, the RZ30 provides access to Apple Music, Amazon Music HD, Spotify Connect, Tidal, Deezer, Pandora, Tune-In, and is Roon Ready
In addition to providing physical speaker connectivity, the RZ30 incorporates DTS Play-Fi and is “Works with Sonos” Certified (via Sonos Port) for flexible wireless multiroom setup capability.
The RZ30 includes HDMI-eARC and Gaming Support (4K/120Hz, 8K/60Hz) with up to 40Gbps transfer rate, VRR (Variable Refresh Rate), ALLM (Auto Low Latency Mode), QFT (Quick Frame Transport), SBTM (Source-based Tone Mapping) and Dynamic HDR.  HDR: Pass-through support is provided for all HDR formats, including Dolby Vision and HDR10+.
Wireless connectivity for the RZ30 includes Bluetooth (Aptx HD), AirPlay 2, Chromecast Built-in, and Wi-Fi (Wired Ethernet is also included).
Onkyo TX-RZ30 A/V Receiver Rear
In addition to wireless connectivity, the RZ30 provides access to abundant wired inputs: 6 HDMI, 1 Component Video, 2 Composite Video, 6 Analog Audio, 1 Digital Optical, 1 Digital Coaxial, 1 Phono (MM), and 1 USB port. If you’re still rocking
As far as wired outputs go, the RZ30 provides 2 HDMI, 9 Multichannel Pre-out, 2 Subwoofer outputs, and 1 quarter-inch analog headphone output.
To operate the many features that the RZ30 has to offer, Onkyo provides several control options, including a wireless handheld remote, a smartphone app, voice control via Google Assistant and Siri, and third-party CI control via RS232 connection.
Onkyo TX-RZ Receivers Comparison Chart
TX-RZ30TX-RZ50TX-RZ70
Price$1,199 $1,599$2,799
THX CertifiedYesYesYes
Amplifier TypeClass A/BClass A/BClass A/B
Number of Amplified Channels9911
Power Output (per channel, 8 ohms, 20Hz-20kHz, THD 0.08%, 2-ch Driven)100-watts120-watts140-watts
Preamp Outputs91111
Subwoofer Outputs222
Max Audio Processing Channels9.211.211.2
Surround Sound SupportDolby Atmos
Dolby Atmos Music
DTS:X
IMAX Enhanced
Dolby Atmos
Dolby Atmos Music
DTS:X
IMAX Enhanced
Dolby Atmos
Dolby Atmos Music
DTS:X
IMAX Enhanced
Auro 3D Audio via Firmware Update
Klipsch Optimized ModeYesYesYes
ESS Sabre DACYes
Room CorrectionDirac Live Full Bandwidth version includedDirac Live Full Bandwidth version includedDirac Live Full Bandwidth version included
Video Support Up to 4K/120Hz, 8K/60HzUp to 4K/120Hz, 8K/60HzUp to 4K/120Hz, 8K/60Hz
HDRHDR10
HDR10+
Dolby Vision
HLG
HDR10
HDR10+
Dolby Vision
HLG
HDR10
HDR10+
Dolby Vision
HLG
Gaming SupportVRR (Variable Refresh Rate)
HDMI Version2.12.12.1
HDMI ARC/eARCYesYesYes
HDMI Inputs/Outputs6/26/27/3
Analog In/Out6/136/155/17
Digital In: Optical / Coaxial1/11/12/2
Phono Input (MM)111
Speaker Terminals91113
Headphone Output111
WiFi YesYesYes
BluetoothYesYesYes
Power Consumption750 W850 W 850 W
Dimensions (WxHxD)17.1 x 7 x 15.1”
435 x 177.5 x 382.5 mm
17 1/8 x 7 15/16 x 15 11/16˝
435 x 201.5 x 398 mm
17.1 x 7.9 x 18.9”
434.34 x 200.7 x 480.1 mm
Weight25.4 lbs (11.5 kg)30.9 lbs (14 kg) 48.5 lbs (22  kg)
Onkyo TX-RZ30 A/V Receiver Front
The Bottom Line
The Onkyo TX-RZ30 has an interesting place in Onkyo’s line-up. It is not a breakthrough AVR, but there are some standout features, such as offering built-in full bandwidth Dirac Live Room Correction at an affordable price point and an optional upgrade to Dirac Live Bass Control with two independent subwoofer outputs, Onkyo’s continuation of THX Certification, and offering both multi-zone wired and wireless connection options.
Also, Onkyo is continuing to partner with sister company Klispch through the offering of the Klipsch Optimized Mode for select Klipsch Reference Series speakers. Onkyo and Klispch have also partnered on a new soundbar line and there is more to come on that front.
However, one of Onkyo’s tag lines for the RZ30 (and other models) is the use of the term “Smart AV Receiver.” Although this may be a good marketing label, AVRs with built-in streaming and multi-room wireless connectivity have been around for a few years – including several of Onkyo’s own AVR products in the RZ and the TX-NR line (NR stands for Network Receiver) – which are the next step down from the RZ line. So being “smart” doesn’t really say much.
In any case, even without an IQ test, the new TX-RZ30 has a lot to offer for those who want to bring that cinematic sound experience home.
Pricing & Availability
The Onkyo TX-RZ30 A/V Receiver will be available in October 2024 for $1,199 at Crutchfield and authorized retailers.
Optional Dirac Live Bass Control costs $299 extra.
Related Reading
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
