Onkyo TX-NR1010, TX-NR3010 and TX-NR5010 A/V Receivers Announced
For 2012 Onkyo announced three new top-of-the-line THX Ultra2 Plus A/V receivers with Cisco Linksys' SimpleTap technology. The new models include the $3,000, 9-channel flagship TX-NR5010 Network A/V Receiver offering a full 11.4-channel implementation of DTS Neo:X; a more moderately priced 9-channel alternative, the TX-NR3010 Network A/V Receiver which also includes DTS Neo:X 11.4; and lastly, a high-power seven-channel solution, the value-packed TX-NR1010 Network A/V Receiver.
Onkyo TX-NR5010
The flagship TX-NR5010 is aimed squarely at the avid home theater enthusiast. As part of the THX certification promise, this receiver is designed to deliver the highest audio and video quality for an unsurpassed home cinema experience right out of the box. Housed in a rigid chassis with separate anti-resonant aluminum top and side panels, the unit has a massive toroidal transformer supported by two discrete transformers for audio and video processing. With gold-plated audio terminals and speaker posts, this unit is fastidiously outfitted to audiophile-grade specifications.
Onkyo TX-NR3010 A/V Receiver
Onkyo TX-NR3010
Like its slightly more powerful sibling, TX-NR3010 also boasts multiple transformers for A/V processing, but features a heavy-duty EI transformer in place of toroidal power. All models feature isolated power and preamp blocks to reduce interference with super-rigid chassis to prevent vibration.
With Ethernet for access to preloaded audio streaming channels such as Spotify, and connectivity for smart phones, tablets, and PC via DLNA or Bluetooth, these receivers are designed for seamless integration into users' digital lifestyles and to distribute entertainment throughout the home.
Onkyo TX-NR1010 A/V Receiver
Onkyo TX-NR1010
Onkyo has been working with Cisco to incorporate SimpleTap that delivers better experiences to mutual broader set of customers. With the inclusion in these three high-end receivers, Onkyo becomes the first company to integrate SimpleTap technology into CE products. Firmware updates will be available to enable all 2012 Onkyo Network enabled receivers to take advantage of this new technology.
HDMI connectivity has also been enhanced by adding Zone2 HDMI connectivity that removes the need for a secondary analog connection in order to access audio in a second zone. Powered audio is available in up to three zones simultaneously–with multi-zone playback and setting controls managed by remote app.
Onkyo TX-NR1010 A/V Receiver - back
Onkyo TX-NR1010
Onkyo TX-NR3010 A/V Receiver - back
Onkyo TX-NR3010
Onkyo TX-NR5010 A/V Receiver - back
Onkyo TX-NR5010
To conjure up the signature Onkyo sound, audio signals are passed through a sophisticated digital-to-analog conversion stage, with PLL jitter-cleaning, VLSC noise-mitigation, and top-quality TI Burr-Brown DAC modules working to create a pristine analog waveform.
Signals are then amplified through discrete Three-Stage Inverted Darlington Circuitry, with a triple transistor array that cuts distortion and boosts current flow to the speakers. This innovative amplifier design capitalizes on the unique benefits offered by a low negative feedback topology, preserving the life, vitality, and realism of the audio as it was originally recorded. Outputted through discrete transistors, the resulting sound further burnishes Onkyo's reputation as the masters of high fidelity audio.
For optimum video performance, all three models feature Onkyo's Dual Core Video Engine–hailed as the best video processing system currently available. This system pairs the mighty HQV Vida VHD1900 module with Marvell's Qdeo technology for seamless upscaling to 4K. ISF video calibration further enhances smooth and vivid picture quality.
Onkyo Remote Control
Each receiver uses the
same remote control
A new Differential DAC Mode and Digital Crossover Processing Network are also included on all three models to optimize performance when bi-wiring and bi-amping the front channels–further demonstrating Onkyo's commitment to audiophile-level sound.
With everything from an analog video input for PC to a generous mix of optical and coaxial digital audio inputs, all three models boast an exhaustive the list of A/V connections. In addition to the capacity to link with an iPhone, iPod, or flash memory device, these models include two USB ports in the front and rear to accommodate the UWF-1 Wireless LAN Adapter and UBT-1 Bluetooth USB Adapter (sold separately).
Onkyo improves usability with a 1080p overlaid display with Quick Set-Up function enabling fast mid-program adjustment, while remote control apps for Android-powered phones and iPhone offer access to system settings, as well as playback control from anywhere in the home.
Features
  • THX Ultra2 Plus certification to recreate the cinematic experience with dynamic Reference Level sound to larger home theaters up to 85 cubic meters in size and a viewing distance of approximately 3.5 meters
  • 11.4-channel pre-outs with DTS Neo:X 11-channel upmixing support for both the TX-NR5010 and TX-NR3010, another world first for Onkyo
  • First consumer electronics partner to incorporate Cisco Linksys' SimpleTap technology
  • Audyssey MultEQ XT32 room equalization with multi-channel upmixing from DTS Neo:X, Audyssey DSX, and Dolby Pro Logic IIz
  • An additional HDMI output to enable 1080p playback in a second zone
  • InstaPrevue picture-in-picture video input preview and selection technology
  • Front-panel Mobile High-Definition Link HDMI port for phone/camcorder
  • Extra HDMI inputs to support 3D Video plus Dolby TrueHD and DTS-HD Master Audio (8+1 inputs on all three models)
  • Bluetooth 3.0 and aptX wireless audio streaming via optional adapter
Price and Availability (July 2012)
See more A/V Receivers.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
