Onkyo PA-MC5500 THX-Ultra2 Plus Multi-channel Amplifier
Onkyo today announced its top-of-the-line PA-MC5500 nine-channel THX-Ultra2 Plus certified analog power amplifier that is 8-ohm rated at 150 Watts per channel, and up to 400 Watts dynamic power into 3 ohms. It utilizes Onkyo's exclusive WRAT (Wide Range Amplifier Technology) design philosophy, which proscribes low negative feedback, low distortion, extended frequency response, and a power supply with high instantaneous-current capability. To achieve all this, the PA-MC5500 uses large, custom output transistors in push-pull configuration and massive power supply consisting of a large toroidal power transformer and two 22,000 µF storage capacitors. Despite all this power, the PA-MC5500 preserves the subtle details of the sound with a three-stage inverted Darlington circuit to remove distortion and the use of professional balanced line-level XLR inputs for the optimal interface with its ideal companion, the Onkyo PR-SC5508 9.2-channel Preamplifier/Processor. The 51-lb PA-MC5500 has a rigid, anti-resonant chassis, gold-plated inputs and outputs, plus multi-zone and bi-amp capability to allow full utilization of all channels no mater what the system configuration.
Onkyo PA-MC5500 THX-Ultra2 Plus Multi-channel Amplifier - Back
Features
  • 220 W/Ch (6 Ohms, 1 kHz, 1 Channel Driven, IEC)
  • WRAT (Wide Range Amplifier Technology)
  • Dynamic Power:
    • 400-watts (3 Ω Front)
    • 300-watts (4 Ω Front)
    • 180-watts (8 Ω Front)
  • THD (Total Harmonic Distortion): 0.05% (Rated power)
  • Damping Factor: 60 (Front, 1kHz, 8 Ω
  • Push-Pull Amplification Design with Three-Stage Inverted Darlington Circuitry to Remove Distortion
  • All Discrete Output Stage Circuitry
  • Massive Toroidal Transformer
  • Two Large, Customized, 22,000 µF Capacitors for Effective Power Supply
  • Audio-Tuned Reference Capacitors for Each Channel
  • Large, Custom-Designed Power Transistors to Drive High Currents
  • Low-Impedance, Copper Bus Plates for Perfect Ground Potential
  • High-Current, Low-Impedance Circuit Boards with Thick Copper Foil (70 µm)
  • Flat, High-Rigidity, Anti-Resonant Chassis
  • Gold-Plated XLR Inputs
  • Machined Solid Brass RCA Inputs
  • Gold-Plated, Color-Coded, Banana Plug-Compatible, Transparent Speaker Posts
  • Multi-Zone Capability (up to Zone 3)*
  • Bi-Amping Capability*
  • 12 V Trigger Input
  • Auto Power Down Function
  • Aluminum Front Panel
  • Weight: 23.0 kg
Price and Availability
The Onkyo PA-MC5500 Power Amplifier will be available in September for $1,699 MSRP.
More Component Announcements
Other THX Certified separates announced today include the BD-SP808 Blu-ray player and the PR-SC5508 A/V Preamplifier/Processor.
1 Comment
1 Comment
  1. SC
    November 17, 2015 at 4:04 pm
    looking for a good 6 channel power amp (used).
    Trying out open baffle speakers with active crossover.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
