CD Players
Onkyo C-7000R CD Player
Onkyo introduced the C-7000R CD player to their new reference hi-fi series component line styled after the company's 1980 stereo classic models.
The C-7000R brings together features and refinements to bring the very best out of your audio CDs and CD-R/RWs, and even any MP3- or WMA-encoded discs you may have made on your computer. To ensure minimal signal interference, the C-7000R employs a thermally regulated high-precision clock, PLL ultra-low jitter technology, and a new circuit board construction. All of this highly sensitive componentry is housed in anti-vibration casing, with separate aluminum panels for the top, front, and sides. In keeping with the zero-tolerance approach to interference, digital circuitry and analog circuitry are physically separated, and you have the choice of operating the C-7000R in either digital-only or analog-only mode. The silent disc mechanism and solid die-cast aluminum tray epitomize the unit's audiophile build quality.
To ensure minimal signal interference, the C-7000R CD player employs a thermally regulated, high-precision clock with a state-of-the-art crystal oscillator. To further reduce potential interference, the player can be operated in analog-only or digital-only mode. Furthermore, analog and digital circuitry are physically separated and employ independent transformers: a massive toroidal transformer for analog, and an EI transformer for digital. The audiophile build-quality of the C-7000R is epitomized by a silent disc mechanism, a solid die-cast aluminum tray, and AES/EBU digital outputs.
Onkyo C-7000R CD Player - Rear
Features
  • Plays Audio CD, CD-R, CD-RW, MP3 CD, and WMA CD
  • DIDRC (Dynamic Intermodulation Distortion Reduction Circuitry)
  • Separate Digital/Analog Circuitry
  • Separate Massive Transformers for Digital and Analog Circuitry (Toroidal Transformer for Analog Circuitry)
  • Thermally Regulated High-Precision Clock
  • Silent Disc Mechanism with Solid Die-Cast Aluminum Tray
  • Separate Anti-Vibration Aluminum Panels for Top, Front, and Sides
  • New Circuit Board Construction to Reduce Vibration
  • PLL (Phase Locked Loop) Ultra Low Jitter Technology
  • Separate Burr-Brown 192 kHz/24-Bit DACs (PCM1792) for L/R Channels
  • Pure Analog Mode
  • Pure Digital Mode
  • 3 Digital Outputs (AES/EBU, Optical, and Coaxial)
  • Wide-Spaced, Gold-Plated, Machined Solid Brass Audio Terminals
  • Display Dimmer (Normal/Dim/Off)
Specifications
  • Frequency Response: 2 Hz–20 kHz
  • S/N Ratio: 116 dB
  • THD (Total Harmonic Distortion): 0.0015%
  • WHD: 435 x 99 x 315.2 mm
  • Weight: 12.0 kg
Price and Availability
The Onkyo C-7000R CD Player will be available January 2011 for $1,499.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
With more options than we've seen in years, here are our picks for Editors' Choice Awards for AV receivers in 2024.
Our favorite A/V receivers on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
The backbone of a home theater or surround sound system, today's best AVRs are packed with features and performance (updated for 2024)
Klipsch, Onkyo and Integra have been swept up in Gentex's acquisition of VOXX International. Can they all survive in 2025?
Select Onkyo, Integra and Pioneer A/V receivers add support for Dirac Live Bass Control, Amazon Music HD, TIDAL MAX, Source-based Tone Mapping and Google...
At $1,199, the Onkyo TX-RZ30 9.2 Channel A/V Receiver includes Dirac Live, Dolby Atmos, THX Certification, IMAX Enhanced, and more.
Yamaha RX-V2300 6.1-channel Receiver ($999) Onkyo TX-NR900 THX Select 7.1-Channel Receiver ($1,500) So you are interested in a new receiver? Maybe you want to...
