Omnimounts Full Line of Professional Mounts Provides a Complete Digital Signage Solution
Extensive Line-up of Wall Mounts, Ceiling Mounts and Floor Stands Address Virtually Every Digital Signage Application Imaginable
PHOENIX, ARIZ. — April 14, 2008 — OmniMount, dedicated to being a one-stop-shop for professional and consumer products, announced that its full line of commercial wall mounts, ceiling mounts and floor stands is now available. Ideal for virtually all digital signage applications, these professional grade products all feature Lift n’ Lock for easy installation and a large-capacity cable management system.
“OmniMount offers a comprehensive line of digital signage solutions to help our customers get their message across,” said Hal Truax, general manger of professional products for OmniMount. “All of our digital signage products — from the Portrait Fastback Series of wall mounts to the ceiling mounts and floor stands — are designed to be robust with utility in mind. They also come equipped with all the user-friendly and convenience features installers have come to expect from OmniMount.”
Each of OmniMount’s Portrait Fastback Series of wall mounts — the 54FBPT-CT (Compound Tilt), 54FBPT-T (Tilt) and 54FBPT-F (Fixed) — provides a one-box digital signage mounting solution. All feature a portrait orientation specifically designed for digital signage; sliding lateral on-wall adjustment; universal rails for greater panel compatibility; and a rock-solid locking system for added safety. The 54FBPT-CT, the flagship of the series, is a sophisticated compound tilt digital signage mount ideal for applications requiring maximum tilt angles and allows for maximum flexibility in terms of placement. It comes equipped with a locking pin mechanism which tilts the panel at precise 3&#186 increments making it well-suited for single or multiple panels. The 54FBPT-CT’s compound tilt design allows the mounted panel to be pulled out and tilted down for overhead positioning.
Wall Mounts
54FBPT-CT – Product Specifications
• Universal & VESA Compliant: up to 400×800
• Fits most: 32″ to 63″ flat panels
• 175 lbs (79.4 kg) maximum weight capacity
• Tilts up to +30° in 5 increments
• Mounting profile: 3.9″ (99mm)
• Mounting: Double-stud
• Includes complete Grade 5 hardware kit
• Anti-theft security feature
• Available in black
54FBPT-T – Product Specifications
• Tilts -5o and up to +15o in 3o increments
• Mounting profile: 4.2″ (107mm)
54FBPT-F – Product Specifications
• Mounting profile: 2.0″ (51mm)
OmniMount’s line of ceiling mounts, including the DCM UA double ceiling mount with universal adapter, the DCM tilt double ceiling mount, the SCM UA tilt single ceiling mount with universal adapter and the SCM tilt single ceiling mount, provides versatile and flexible solutions for single or back-to-back mounting options. Every mount in the series offers landscape and portrait mounting options and comes equipped with a pin tilt mechanism that tilts the panel at precise increments, making them well suited for single or multiple panels.
Ceiling Mounts
DCM UA — Product Specifications
• Universal and VESA compliant: up to 400×800
• 400 lbs (181.4 kg) maximum weight capacity
• Tilts up to +30o in 5o increments
• Includes 24″ of 1.5″ NPT pipe
• Supports 2 panels for back-to-back mounting
• Includes ceiling plate
DCM — Product Specifications
• VESA compliant: up to 200×200
• Tilts up to +30o in 5o increments 400 lbs (181.4 kg) maximum weight capacity
SCM UA — Product Specifications
• 200 lbs (90.7 kg) maximum weight capacity
• NPT extension pipes available in 12″, 18″ and 24″ lengths
SCM — Product Specifications
— more —
OmniMount’s professional floor stands, including the FSUA floor stand with universal adapter and FS floor stand, deliver maximum adaptability and placement flexibility, making them the most versatile in their category. The FSUA and FS offer portrait or landscape orientation mounting options and a continually adjustable tilt assembly and shelf. OmniMount’s floor stands tilt -5o to +5o and pan 0 to +15o left and right for optimum viewing.
Available floor stand accessories consist of the FSTAUA, floor stand tilt assembly with universal adapter, and FSTA, floor stand tilt assembly; both allow users to mount additional flat panels on either the FSUA or FSA. The FSVS, floor stand vented shelf, allows users to manager components while the FSCA floor stand caster assembly helps to easily maneuver either floor stand.
Floor Stands
FSUA – Product Specifications
• 165 lbs (74.8 kg) maximum weight capacity*
• 40 lbs (18.1 kg) shelf capacity
• Fits most 42″ to 55″ flat panels
• Pans +-15o
• Tilts -5o to +15o
FS – Product Specifications
• Fits up to 37″ flat panels
• Pans +-15o
• Tilts -5o to +15o
*Sum of all shelves, components and flat panels.
Talking Points:
• OmniMount announced that its full line of digital signage solutions, including wall mounts, ceiling mounts and floor stands, is now available.
• Ideal for virtually all digital signage applications, OmniMount’s professional grade digital signage products all feature Lift n’ Lock for easy installation and a cable management system.
• OmniMount’s Portrait Fastback Series of wall mounts consisting of the 54FBPT-CT (Compound Tilt), 54FBPT-T (Tilt) and 54FBPT-F (Fixed) provides a one-box digital signage mounting solution.
• OmniMount’s line of ceiling mounts, including the DCM UA double ceiling mount with universal adapter, the DCM tilt double ceiling mount, the SCM UA tilt single ceiling mount with universal adapter and the SCM tilt single ceiling mount, provides versatile and flexible solutions for single or back-to-back mounting options.
• OmniMount’s professional floor stands, including the FSUA floor stand with universal adapter and FS floor stand, deliver maximum adaptability and placement flexibility, making them the most versatile in their category.
About OmniMount
For nearly 30 years, OmniMount has upheld its position as a global leader by continually evolving the category through product innovation. Represented worldwide in more than 65 countries, OmniMount products have been recognized for groundbreaking design, high quality and long-term reliability. Thanks in part to the company’s in-house industrial design and engineering team, precise attention to detail and quality control standards are built into every product, producing the most breakthrough and well-built products on the market.
Today, the OmniMount product line features hundreds of mounting solutions that cover the demands of nearly every application. From the smallest speaker to the largest flat panel and everything in between, OmniMount has been a pioneer in developing consumer and commercial products to maximize the home theater experience. More information is available at www.omnimountpro.com.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
