Impressive Ultra Low Profile Flat Panel Tilt Mounts Now Available
PHOENIX, Ariz. — September 24, 2007 — OmniMount, a global leader in both consumer and commercial mounting solutions, announced the anticipated release of three new ultra low profile tilt mounts for flat panels ranging from 26″ to 75″. Appropriately named the Ultra Low Profile Series, this new line features a remarkably slim mounting profile — only 1.5″ off the wall in the fixed position — ensuring that flat panels blend seamlessly into any environment. The ULPT-X, ULPT-L, and ULPT-M support flat panels from 55″-75″, 40″-63″ and 26″- 42″ respectively.
“As more and more consumers make flat panel displays the centerpiece of their entertainment experience, OmniMount will continue to introduce mounting solutions that provide an enhanced viewing experience for end users,” said Brett Stenhouse, OmniMount vice president of marketing. “The release of the ULP Series, most especially the extra large ULPT-X for flat panels up to 75″, addresses the fact that flat panels are getting bigger and consumers are looking for them to blend into their decor. These mounts reinforce our position of leadership giving users stylish, yet highly functional mounting products.”
The ULP Series is manufactured with the best quality standards in the industry including durability, function and design. Available in extra large (X), large (L), and medium (M), these low profile mounts are made from heavy-grade steel, have a durable anthracite powder coat finish and include extruded aluminum end cap that present a clean side view. This line also includes all the features installers are accustomed to from OmniMount: ‘Lift n’ Lock’ for easy installation, locking system for added safety and security, sliding lateral on-wall adjustment, universal rails for maximum compatibility, open architecture for simplified wiring and an installation template.
To make mounting and wiring flat panels even easier, OmniMount has designed an innovative built-in kickstand so access to wiring post-installation requires only one person and no vertical lifting of the flat panel. When in use, the kickstand holds the bottom of the flat panel away from the wall so only one person is needed to complete the wiring. The ULP Series is available now and retails for $199.95 (ULPT-M), $299.95 (ULTP-L), and $329.95 (ULTP-X).
Stenhouse added: “The Ultra Low Profile Series is a great addition to the OmniMount portfolio and users who prefer a fixed mounting solution as a better fit for their viewing environment can also expect two new models for release later in the year.”
ULPT-X Ultra Low Profile Flat Panel Tilt Mount
Product Features:
Ultra low profile design
Lift n’ Lock for easy installation
Includes complete Grade 5 hardware kit
Includes installation template
Sliding lateral on wall adjustment
Open architecture for trim out
Includes security hardware
Locking system for added safety and security
Aluminum end caps included to conceal mounting hardware
Built-in kickstand allows for easy wiring access
Extruded aluminum end cap presents clean side view
Product Specifications:
Supports most flat panels up to 75″, 300 lbs
Universal and VESA compliant
Tilts +15°
Triple-stud mounting
Available in an attractive anthracite finish
ULPT-L Ultra Low Profile Flat Panel Tilt Mount
Product Features:
Supports most flat panels from 40″- 63″, 200 lbs
Tilts +15°
Double-stud mounting
ULPT-M Ultra Low Profile Flat Panel Tilt Mount
Product Features:
Supports most flat panels from 26″- 42″, 125 lbs
Tilts +15°
Talking Points:
OmniMount introduces three ultra low profile flat panel tilt mounts, the ULPT-X, ULPT-L, and ULPT-M supporting flat panels ranging from 26″- 75″.
The ULP Series has a cutting edge design and the innovative kickstand feature allows for easy wiring of super-sized flat panels, with a profile from the wall of 1.5″.
Available now, the ULPT-X, ULPT-L, and ULPT-M will retail for $329.95, $279.95 and $199.95 respectively.
About OmniMount
For nearly 30 years, OmniMount has upheld its position as a global leader by continually evolving the industry through product innovation and the creation of new product categories. Represented worldwide in 59 countries to date, OmniMount products have been recognized for groundbreaking design, high quality and long-term reliability. Thanks in part to the company’s in-house industrial design and engineering team, known as ID&E, precise attention to detail and quality control standards are built into every product, producing the most breakthrough and well-built products on the market. Today, the OmniMount product line features hundreds of mounting solutions that cover the demands of nearly every application. From the smaller speaker to the largest flat panel and everything in between, OmniMount has been a pioneer in developing professional and consumer products to maximize the home theater experience. For a closer look, visit www.omnimount.com.
