Digital Cameras
Olympus Tough TG-1 iHS Rugged Digital Camera Announced
Olympus announced their flagship rugged digital camera, the 12-megapixel Tough TG-1 iHS which is waterproof, shockproof, freezeproof, crushproof and dustproof. It combines incredible durability with the world's first high-speed bright f2.0 lens on a Tough camera and converter-lens compatibility to create a versatile system camera. The combination of durability and outstanding image quality make it possible to shoot in even the harshest conditions. Capture beautiful underwater scenes and aquatic life, snap photos of dusk-lit peaks or record your ride down the rapids in dazzling 1080p Full HD Video.
Superior Optics
The Olympus TG-1 iHS incorporates an ultra-bright, high-speed f2.0 lens so you can capture high-quality images at blazing fast shutter speeds, even in low-light conditions. The camera's three-inch high-resolution OLED display (610K dots) provides excellent visibility in bright situations, enabling you to compose the perfect shot in direct sunlight. Protective coatings help to prevent scratches and cut down on reflective glare, and the new lens on the Olympus TG-1 iHS transforms your photographs with the same FAST AF system technology found in Olympus PEN cameras. Never worry about water droplets obstructing your images thanks to the water-repellent lens coating that prevents water from remaining on the lens surface.
Olympus TG-1 iHS Rugged Digital Camera - Back
Durable Performer
The Olympus TG-1 iHS is Waterproof to 40 feet, Shockproof to 6.6 feet, Freezeproof to 14°F and even Crushproof to a weight of 220 pounds. A high-sensitivity, high-speed 12-megapixel backlit CMOS sensor combined with a blazing fast, DSLR-quality TruePic VI image processor results in high-speed autofocus, enhanced Intelligent Auto for spectacular scene and subject recognition, and 8x Super-resolution Zoom to produce jaw-dropping images in locations that make even the most seasoned photographers cringe. This family of technologies combines for unmatched image quality in challenging shooting conditions with improved lighting, less noise and response times twice as fast as traditional cameras.
Olympus TG-1 iHS Rugged Digital Camera - Top
Designed specifically to keep up with the on-the-go photographer, the new Super Sport Mode combines high-speed autofocus with extra fast shutter speeds up to 1/2000 to freeze the action. Conveniently located on the dial, this mode captures five shots in a high-speed burst to ensure crisp shots in even the most extreme action sport settings. Low Light Mode is perfect for capturing the mood of low-light indoor scenes, beautiful sunsets or late night outdoor festivities without ruining the ambience with a bright flash. Shoot like a pro with five frames-per-second high-speed burst shooting and 1080p Full HD videos (1920×1080 pixels) or 60 frames-per-second (3mp) at the touch of button, allowing for slow-motion playback. Thanks to iHS Technology, your videos will benefit from excellent color reproduction and faster processing speeds, while Multi-Motion IS compensates for user movement during recording, creating smoother videos. Linear PCM Recording, an audio technology pioneered by Olympus for professional voice recorders, records your videos with high-definition audio for optimal playback results.
In iAuto mode, the Olympus TG-1 iHS automatically detects the subject, lighting and situation to identify the scene you're shooting up to 30 different scenes including Night, Sport, Beach and Snow, Underwater Snapshot and Backlight HDR and adjusts the settings for ideal results.
Olympus TG-1 iHS Rugged Digital Camera with Lens
System Expandability
For serious photographers, Olympus is offering system expandability for the Olympus TG-1 iHS. A converter ring allows you to add a lens converter adapter, waterproof Fisheye Converter Lens and Teleconverter Lens for use on land or in water. The Fisheye Converter Lens captures panoramic, wide-angle shots without sacrificing the brightness of the 4x wide optical zoom (25-100mm) f2.0 lens. The Teleconverter Lens extends your optical zoom from 4x to 6.8x, delivering dramatic close-ups with professional-looking background blur. Combined with the Olympus TG-1 iHS 8x Super-resolution Zoom, which extends the range of the optical zoom with virtually no loss of image quality, you can reach an unmatched 13.6x magnification. Both converter lenses are waterproof to 40 feet. If 40 feet is not deep enough for you, the new Olympus PT-053 underwater housing is designed specifically for the TG-1 iHS, enabling you to dive to depths of 135 feet (45m).
Extreme Versatility
With the GPS and e.compass functions on the Olympus TG-1 iHS, location and landmark information will be displayed and recorded along with every image. The camera is also equipped with a logging function so you can track the route taken from recorded images by using applications such as Google Earth and Picasa. And with the brand-new LI-90 battery, you'll worry less about battery life and more about your next destination. Mark your spot on the map with the built-in manometer, which records elevation and water depth and even displays a warning when the user approaches a depth of 40 feet. The Olympus TG-1 iHS boasts four different underwater scene modes — Underwater Snapshot, Underwater Wide 1, Underwater Wide 2 and Underwater Macro — each carefully calibrated to allow for optimal color balance, exposure and flash so you automatically get the best results. An LED illuminator on the front of the camera enhances focus and exposure for macro shooting — great for underwater close-ups where light is scarce. The LED illuminator also works in conjunction with the flash to help illuminate your subject in low-light conditions.
Price and Availability
The Olympus TG-1 iHS will be available in June 2012 for $399.99 in titanium and ships with a USB Cable & Charger (F-3AC), Lithium-Ion Battery (Li-90B), Wrist Strap, Instruction Manual and ib Software CDs, Quick Start Guide and a Warranty Card.
Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Sony's 2025 ULT wireless speaker line-up. Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Totem Tribe Tower Thunderbird Speakers Drivers Close-Up Totem Tribe Tower Thunderbird Speakers Drivers Close-Up
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Vertere DG-X Turntable Red Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
