Olympus has released its smallest and lightest PEN micro four thirds digicam designed for people who want to try an interchangeable lens camera for the first time. Available in silver, black, white and red, the PEN E-PM2 offers a 16.1-megapixel High-Speed Live MOS Sensor and new TruePic VI image processing engine as the award-winning, flagship Micro Four Thirds system camera, Olympus OM-D E-M5. Armed with this technology, the new PEN provides outstanding low-light performers with a maximum ISO of 25,600 and a dynamic range that has also been increased, enabling finer expression of gradations between dark and bright areas with a wider range of intensity. An AF Illuminator and accessory FL-LM1 flash, included with both cameras, adds to their low-light performance. Photos and HD videos will be crisp and clear thanks to three modes of in-body image stabilization and the award-winning Olympus Dust Reduction System.
With intuitive vertical touch navigation menu users can tap the screen to instantly focus the subject and automatically trigger the shutter for instantaneous in-focus image capture thanks to the Touch AF Shutter function. The combination of the speedy response of the touchscreen panel and the FAST (Frequency Acceleration Sensor Technology) AF system, the same technology that made the Olympus OM-D the world’s fastest autofocusing camera, gives users the power to capture precisely the image they want at precisely the moment they want it. With instantaneous focusing, the camera won’t shake the moment the shutter is released, assuring maximum clarity and stability, even when shooting moving subjects. Maximum frame rates have also increased more than 2X with a maximum frame rate of 8 fps in Single AF mode.
A 3-inch, 460,000-dot high-definition LCD screen and an Anti-Finger Print coating to reduce smudges. The display offers a wide 176-degree angle of view and is bright enough to compose images even in harsh midday light. The intuitive and practical touchscreen makes navigating the camera’s menus and graphical user interface effortless. Going through a day’s photos is as easy as scrolling through the images and enlarging photos with the tap of a finger. A convenient button on top of the E-PM2 calls up the Live Guide function instantly from any shooting mode for intuitive assistance whenever needed.
A new Water Color effect joins 11 available in-camera Art Filters (Diorama, Pop Art, Soft Focus, Pale & Light Color, Light Tone, Grainy Film, Pin Hole, Cross Process, Gentle Sepia, Key Line and Dramatic Tone) and adds to other brilliant, easy-to-use functions, including Variations and the new Monochrome effect. In-camera RAW data editing selects various settings for RAW data editing and previews the images before applying changes. The customizable Self Timer programs the shutter release to go off at select intervals to ensure the perfect shot. A small single AF target can be selected for pinpoint focusing beyond the existing 35-point area selection. Users can get creative while shooting in 1080i Full HD Movie with fade effect, so you can transition from art filter to art filter without stopping the movie. While shooting a movie with the E-PL5, the Movie Teleconverter function magnifies up to 4x without image deterioration.
Using the OLYMPUS Image Share application, which is compatible with both iPhone and Android smartphones and the Toshiba FlashAir SDHC memory card, it’s easier than ever to upload pictures to your favorite social network. You can set up the FlashAir using the built-in smartphone connection capability for an effortless Wi-Fi connection between PEN and your smartphone. The OLYMPUS Image Share application makes it easy to upload images to a smartphone by selecting them from thumbnails, apply Art Filters on the smartphone and share. Images can also be enjoyed by friends and family by issuing a one-time password to connect several smartphones simultaneously to the cameras.
[youtube id=”RRA6SujNjEc” width=”610″ height=”373″]
Pricing & Availability
Available in silver, black, white and red:
- $549.99 → Olympus PEN E-PM2 Body Only
- $599.99 → Olympus PEN E-PM2 Body with MSC M.ZUIKO DIGITAL ED m14-42mm f3.5/5.6 Prime Zoom Lens
