Olympus has released the PEN E-PL5 micro four thirds digital camera, which features an all-metal body, swiveling/flip-up screen with the same 16.1-megapixel High-Speed Live MOS Sensor and new TruePic VI image processing engine as its flagship OM-D E-M5. Armed with this technology, the new PEN offers outstanding low-light performers with a maximum ISO of 25,600 and a dynamic range that has also been increased, enabling finer expression of gradations between dark and bright areas with a wider range of intensity. An AF Illuminator and accessory FL-LM1 flash, included with both cameras, adds to their low-light performance. Photos and HD videos will be crisp and clear thanks to three modes of in-body image stabilization and the award-winning Olympus Dust Reduction System.
Tapping in on the chosen subject within the frame of the cameras’ LCD monitor instantly focuses the subject and automatically triggers the shutter for instantaneous in-focus image capture thanks to the Touch AF Shutter function. The combination of the speedy response of the touchscreen panel and the FAST (Frequency Acceleration Sensor Technology) AF system, the same technology that made the Olympus OM-D the world’s fastest autofocusing camera, gives users the power to capture precisely the image they want at precisely the moment they want it. With instantaneous focusing, the camera won’t shake the moment the shutter is released, assuring maximum clarity and stability, even when shooting moving subjects. Maximum frame rates have also increased more than 2X with a maximum frame rate of 8 fps in Single AF mode.
The E-PL5 has a 3-inch, 460,000-dot high-definition LCD screen and an Anti-Finger Print coating to reduce smudges. The display offers a wide 176-degree angle of view and is bright enough to compose images even in harsh midday light. Capturing the shot you want is easy with the E-PL5 swivel LCD that rotates up 170 degrees for simple self-portrait shooting. The intuitive and practical touchscreen makes navigating the camera’s menus and graphical user interface effortless. Going through a day’s photos is as easy as scrolling through the images and enlarging photos with the tap of a finger. Change the feel of each camera to suit your preferences with a detachable grip included. My Sets on the E-PL5 Mode Dial allow further customization to suit the user’s shooting preferences.
The Olympus E-PL5 provides a new Water Color effect joins 11 available in-camera Art Filters (Diorama, Pop Art, Soft Focus, Pale & Light Color, Light Tone, Grainy Film, Pin Hole, Cross Process, Gentle Sepia, Key Line and Dramatic Tone) and adds to other brilliant, easy-to-use functions, including Variations and the new Monochrome effect. In-camera RAW data editing selects various settings for RAW data editing and previews the images before applying changes. The customizable Self Timer programs the shutter release to go off at select intervals to ensure the perfect shot. A small single AF target can be selected for pinpoint focusing beyond the existing 35-point area selection. Users can get creative while shooting in 1080i Full HD Movie with fade effect, so you can transition from art filter to art filter without stopping the movie. While shooting a movie with the E-PL5, the Movie Teleconverter function magnifies up to 4x without image deterioration.
Using the OLYMPUS Image Share application, which is compatible with both iPhone and Android smartphones and the Toshiba FlashAir SDHC memory card, it’s easier than ever to upload pictures to your favorite social network. The camera can set up the FlashAir using the built-in smartphone connection capability for an effortless Wi-Fi connection between PEN and your smartphone. The OLYMPUS Image Share application makes it easy to upload images to a smartphone by selecting them from thumbnails, apply Art Filters on the smartphone and share. Images can also be enjoyed by friends and family by issuing a one-time password to connect several smartphones simultaneously to the camera.
[youtube id=”uyeHzlqo94I” width=”620″ height=”360″]
Pricing & Availability
Available in silver, black and white
- $649.99 → Olympus PEN E-PL5 Body Only
- $699.99 → Olympus PEN E-PL5 Body with MSC M.ZUIKO DIGITAL ED m14-42mm II R f3.5/5.6 Zoom Lens
