Mirrorless Cameras
Olympus OM-D E-M1 Interchangeable Lens Camera
Olympus OM-D E-M1 Digital Camera Front
Micro Four Thirds Camera Delivers DSLR Image Quality, Rugged Durability and Super-Large EVF
Olympus just announced the 16.3-megapixel OM-D E-M1, its flagship Micro Four Thirds digital camera for advanced photographers looking for a high-performance tool in a compact system camera package. The powerful E-M1 is packed with incredible speed and image quality that rivals full-frame DSLRs, in a portable yet lightweight body designed to go anywhere.
The Olympus OM-D E-M1 now works seamlessly with all ZUIKO Digital lenses, in addition to working with M.ZUIKO Digital lenses, so photographers can enjoy optimum performance of the entire Olympus lens lineup. This is possible due to advanced DUAL FAST AF system that combines both Contrast AF and On-Chip Phase Detection AF. DSLR users familiar with an optical viewfinder will marvel at its electronic viewfinder (EVF) that is as large as a full-frame DSLR viewfinder and has added creative control. Its ergonomic body provides easy access to all manual controls and is ready for action in the most difficult shooting conditions.
Olympus OM-D E-M1 Digital Camera Top Angle View
DSLR Image Quality
With the OM-D E-M1, experience the highest image quality of any Olympus camera through the combination of a new 16.3 megapixel Live MOS sensor, a new TruePic VII image processor, and its best-in-class M.ZUIKO lenses. The TruePic VII image processor reduces noise and color fading at high ISOs for improved image reproduction. New Fine Detail Processing II technology configures the appropriate sharpness processing for each individual lens for natural, high-quality resolution, as well as reducing compression artifacts when recording movies.
Fast and Accurate AF
The newly developed DUAL FAST AF selects the ideal method, depending on lens type and settings: either 37-point On-Chip Phase Detection AF or 81-point Contrast Detection AF to maximize the performance of both ZUIKO and M.ZUIKO lenses. Both systems work together to significantly improve continuous autofocus tracking performance when a Micro Four Thirds lens is attached and C-AF is selected. Users can select Group Target AF for a variety of situations, Small Target AF for pinpoint shooting, or Super Spot AF for capturing even smaller subjects and specifying a small area focus location during macro shooting.
The TruePic VII engine supports 10 frames-per-second shooting with a 41-picture RAW buffer in single autofocus (S-AF) mode and 6.5 frames-per-second shooting with a 50-picture RAW buffer in continuous autofocus (C-AF) mode. The 1/8000th of a second mechanical shutter freezes fast-moving subjects like a hummingbird and works in bright conditions to create pictures with dramatic blur.
Olympus OM-D E-M1 Digital Camera Back
New Super-Large Interactive Electronic Viewfinder
The E-M1’s advanced, built-in Interactive Electronic Viewfinder features a 1.48x (35mm equivalent of .74x) magnification factor that rivals full-frame DSLR cameras. The extremely high-resolution 2.36 million-dot LCD panel provides a large, clear image that is on a par with optical viewfinders. Tracking moving subjects is completely natural, with a display time lag of only 0.029 seconds. Users can experiment with aspect ratio, magnification, color, and highlight and shadow, and the effects of camera settings on subjects are viewable prior to capturing the finished image. Adaptive Brightness Control raises the brightness when shooting in bright outdoor conditions and lowers the brightness in dark indoor conditions, reducing visual errors from light and dark adaptation of the eye.
Color Creator is a new easy-to-use tool that fine-tunes hue and color saturation using the intuitive GUI and Live View screen, so users can create original images imbued with their own choice of colors. Creative Color was created with a designer’s sensitivity in mind, and hue can be adjusted in 30 steps, and color saturation adjusted in eight steps, including the baseline.
5-Axis Image Stabilization System
The Olympus E-M1’s built-in 5-Axis Image Stabilization with Multi-Motion IS mechanism reduces the effects of camera motion and image blur from five directions. Whether shooting stills or HD video, even the motion blur caused by walking or running is stabilized. New algorithms make image stabilization more effective at low shutter speeds. When it is employed while panning during still image shooting or movie recording, IS-AUTO mode automatically detects the camera’s movements and provides optimal correction regardless of direction or camera orientation – even when panning in a diagonal direction. Users can check the image stabilization effects on the Live View screen as well as the viewfinder to accurately frame and focus, even during telephoto or macro shooting. Multi-Motion IS, used in combination with the 5-Axis Image Stabilization mechanism, produces excellent correction during movie recording.
Rugged Freeze, Splash, Dustproof Durability
The Olympus OM-D E-M1 expands the dustproof and splashproof capabilities of the E-M5 even further with freezeproof capabilities — guaranteed operation down to 14°F — for the best environmental resistance of any Olympus interchangeable lens camera. Its durable magnesium alloy body, and weather-resistant seals and gaskets block moisture and dust for use in any environment, without sacrificing image quality. The camera’s Supersonic Wave Filter (SSWF) dust reduction system vibrates at a super-high speed of more than 30,000 times per second to powerfully remove dust particles so users can shoot in dusty environments.
Ultimate Camera Control
Advanced photographers will appreciate the intuitive 2×2 Dial Control system to easily adjust four often-used functions with the camera’s lever or two dials: aperture/shutter speed, exposure compensation, ISO speed and white balance. A built-in grip similar to that of the E-M5 makes shooting with Four Thirds lenses more comfortable, and all frequently accessed buttons are logically laid out. Controls are now more functional: the settings reset function is activated by pressing and holding the OK button and there is a toggle option for the My Settings shortcut and a locking mode dial to prevent unintentional movement of the mode dial during shooting or when removing the camera from a case or bag. The dedicated “mic-in” jack supports an external microphone when recording HD movies and a built-in X-Sync socket easily connects to studio strobes.
Built-In Wi-Fi
The Olympus OM-D E-M1 includes built-in Wi-Fi, and the set-up is simple. By quickly scanning the QR code displayed on the camera’s LCD with a smart device, it syncs with the Wi-Fi network created by the camera. The free Olympus Image Share 2.0 smartphone app synchronizes a user’s smartphone and E-M1 so the camera’s “Live View” is effectively displayed on the phone, and the camera can be controlled by touching the smartphone display as if it were the camera. This is ideal for taking self-portraits, capturing images of wildlife from a distance and sharing images easily online. The E-M1’s remote shooting function has been improved for use in all main shooting modes (P, A, S, M and iAUTO). Users can now wirelessly adjust various settings, such as the shutter speed, aperture value, ISO and exposure compensation, as well as operate the Live Bulb shooting mode from their Wi-Fi devices. They can also use their smartphone to embed GPS information into their images.
More Creative Features
New Diorama II adds to the popular range of Olympus in-camera Art Filters and offers left and right blur effect in addition to the top and bottom blur effect of Diorama I. The Olympus E-M1 is equipped with two variations of HDR Shooting – HDR1 and HDR2. With a single press of the shutter button, four images with differing exposures are captured and automatically merged in the camera into a single HDR high-contrast image or super-high-contrast image. Photo Story mode enables users to capture a scene from multiple viewpoints and then combine the images into a single image to create unique collages inside the camera. Time Lapse Movie converts the series of pictures taken using interval shooting into a movie inside the camera. The Time Lapse Movie length has been increased to a maximum of 100 seconds. The number of possible shots that can be captured with Interval Shooting has been increased to 999. The E-M1 is also equipped with Focus Peaking, which dramatically improves the usability of older manual focus lenses.
Lenses and Accessories
Olympus also announced today the development of two new high-performance lenses, establishing the M.ZUIKO PRO lens category. The ZUIKO Digital ED 12–40mm f2.8 PRO lens (24–80mm, 35mm equivalent) and the ZUIKO Digital ED 40–150mm f2.8 PRO (80–300mm, 35mm equivalent) will expand the imaging options for professionals and serious photo enthusiasts alike.
The M.ZUIKO Digital ED 12-40mm f2.8 PRO lens (24–80mm, 35mm equivalent) is the first model in the new M.ZUIKO PRO category and is scheduled for release at the same time as the Olympus OM-D E-M1. It features dustproof and waterproof performance, toughness and excellent image quality. Its mount employs the same type of sealing as the camera body and is Movie & Still Compatible (MSC) with high-speed, near-silent autofocus during still shooting and high-definition (HD) video capture. It maintains the brightness of a constant f2.8 aperture for high-grade image creation, one of the requirements of professional photographers for a high-performance lens.
The M.ZUIKO Digital ED 40-150mm F2.8 PRO (80–300mm, 35mm equivalent) also joins the new M.ZUIKO PRO lens category. This lens is currently under development, with a planned release in the latter half of 2014. It will be a telephoto zoom lens with a bright constant f2.8 aperture and will feature a dustproof and splashproof construction rugged enough for professional use.
Several new accessories are designed to complement the Olympus OM-D E-M1 and broaden the creative horizons of all advanced photographers. The HLD-7 Power Battery Holder is a dustproof and splashproof power battery holder that can enable the capture of approximately 680 shots (based on CIPA tests) between charges. It features a shutter button for shooting with the camera held vertically and two control dials and two function buttons for the same easy controls as when shooting from a horizontal position. The GS-5 Grip Strap for the HLD-7 keeps buttons and dials accessible even when the battery holder is attached. The PT-EP11 Underwater Case is made exclusively for the Olympus E-M1 and allows shooting down to 45 meters.
The new CBG-10 Camera Bag is compact, yet designed with Four Thirds lens use in mind, and the highly water-resistant CS-42SF Soft Camera Case, which is part of the Camera Bag CBG-10 system, is made exclusively for use with the E-M1. The CSS-P118 Shoulder Strap is made of washable material with a slender width that matches the versatility of the Micro Four Thirds System.
U.S. Pricing and Availability
The Olympus OM-D E-M1 will be available in October 2013 for $1399.99 (body only) in Black.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
