Camera Lenses
Olympus M.ZUIKO ED 75-300mm f4.8-6.7 II Lens
Olympus M.ZUIKO DIGITAL ED 75-300mm 1:4.8-6.7 II telephoto lens
Olympus announced the affordable M.ZUIKO ED 75-300mm f4.8-6.7 II lens (35mm equivalent 150-600mm) for Micro Four Thirds system cameras, offering a new advanced ZERO (Zuiko Extra-low Reflection Optical) coating to keep scratches off, and eliminate ghosting and lens flare even in bright lights.
The second-generation super-telephoto lens boasts the same high focal length and first-class components as its predecessor, the M.ZUIKO DIGITAL ED 75-300mm 1:4.8-6.7, and is capable of bringing faraway subjects like children’s faces, animals and landscape features vividly to life with superb-quality close-ups. Olympus fitted a circular aperture that ensures a professional-looking bokeh with smooth and even background defocusing.
The compact size and light weight of this tiny telephoto lens make it convenient to carry. Olympus has redesigned the lens to match the distinctive OM-D E-M5 and PEN series cameras. The lens includes Olympus’ near-silent MSC (Movie and Still Compatible) focusing technology to reduce the whir that can otherwise ruin movie playback on a High-Definition TV.
The M.ZUIKO DIGITAL ED 75-300mm 1:4.8-6.7 II benefits from the 5-axis image stabilization of the OM-D E-M5 and maximizes the performance of the Olympus PEN compact system cameras for brilliant still images and high-definition (HD) video capture.
Pricing and Availability
The Olympus M.ZUIKO DIGITAL ED 75-300mm f4-6.7 II Lens will be available in March 2013 for $549.99.
2 Comments
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
