Camera Lenses
Olympus M.ZUIKO Digital ED 9-18mm and 14-150mm Lenses
Ultra-Compact and Lightweight Lenses Designed for Any Micro Four Thirds Camera, Including the PEN E-PL1
Olympus just announced two new additions to its Micro Four Thirds™ System lens lineup: the M.ZUIKO DIGITAL ED 9-18mm F4.0-5.6 (35mm equivalent 18-36mm) and M.ZUIKO DIGITAL ED 14-150mm F4.0-5.6 (35mm equivalent 28-300mm). Designed to maximize the performance advantages of the Micro Four Thirds System, the new lenses are significantly lighter and more compact — easily fitting in a jacket pocket.
The new lenses, made with ED (extra-low dispersion) glass for superior image quality, complement the design of the PEN cameras, including the powerfully simple E-PL1, making it the all-in-one package for consumers with any skill level, including those who are new to photography.
The Micro Four Thirds System standard meets the telecentric requirements of dedicated digital design. Light rays strike the imaging element nearly head-on for optimum edge-to-edge image reproduction. It also enables much more compact design than the Four Thirds System standard (or other interchangeable lens systems) because it reduces the outer diameter of the lens mount by 6mm, and the distance from the lens mount to the sensor (the flange back distance) by approximately half. As a result, M.ZUIKO DIGITAL Micro Four Thirds System lenses offer uncompromising professional quality for capturing both still-images and High-Definition (HD) videos, and the lenses are exceptionally compact to make capturing your life more fun.
The super wide-angle M.ZUIKO DIGITAL ED 9-18mm F4.0-5.6 zoom lens (35mm equivalent 18-36mm) offers a 100 percent angle of view, and overturns the rule that super wide-angle zooms have to be big and heavy. With a length of just 49mm and a weight of just 155g, it is less than half the size and 60 percent of the weight of the ZUIKO DIGITAL ED 9-18mm F4.0-5.6. With its wide angle of view, including background scenery in group photos is a snap, and it can be used to create unique images with a sense of dramatically exaggerated perspective.
Olympus M.ZUIKO DIGITAL ED 14-150mm F4.0-5.6 Micro Four Thirds Lens
The high-power wide-angle to telephoto M.ZUIKO DIGITAL ED 14-150mm F4.0-5.6 zoom lens is 65 percent smaller and 70 percent lighter than the comparable 10x ZUIKO DIGITAL ED 18-180mm F3.5-6.3, making it ideal for everything from portraits and indoor scenes to sports and landscape photography.
By maximizing the advantages of the Micro Four Thirds System design, compact size, low weight and amazing image quality, the two new lenses significantly expand the photographic potential of the system. The inner focusing mechanism uses a light, compact, single-element unit to enable exceptionally fast, quiet autofocusing for smooth, superior operating ease during still and video capture. The manual focusing mechanism is designed to offer a responsive feel and precise operation, enabling you an affordable, high-quality means to capture your life in stills or HD videos.
Both lenses offer quieter and more responsive AF performance, and provide professional image quality for capturing amazing still images and videos. They are compatible with all Micro Four Thirds System Olympus PEN cameras, and all other current and future cameras that comply with the Micro Four Thirds System standard. When mounted on an Olympus PEN camera, the lenses are stabilized thanks to the camera’s in-body Image Stabilization system and offer effective shake compensation at all focal lengths.
Availability / U.S. Pricing / Product Configurations
M.ZUIKO DIGITAL ED 9-18mm F4.0-5.6 – MSRP: $699.99 (available early May 2010)
M.ZUIKO DIGITAL ED 14-150mm F4.0-5.6 – MSRP: $599.99 (available early June 2010)
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
