Camera Lenses
Olympus M.ZUIKO DIGITAL ED 75-300mm F4.8-6.7 Lens
World's Smallest 600mm Telephoto Zoom Lens
Olympus announced the M.ZUIKO® DIGITAL ED 75-300mm F4.8-6.7 Micro Four Thirds lens, a 35mm equivalent of 150-600mm is the world's smallest and lightest 600mm super telephoto lens. Weighing merely 15.17 ounces and measuring 2.76 by 4.57 inches, this lightweight lens delivers excellent portability and outstanding image quality when paired with the award-winning Olympus PEN® cameras. Previous lenses offering 600mm or more have been too large and heavy for most users to enjoy super telephoto shooting. This lens is smaller and lighter than the comparable ZUIKO DIGITAL ED 70-300mm f4.8-6.7.
Silent Operation
The M.ZUIKO DIGITAL ED 75-300mm f4.8-6.7's rear focusing mechanism is comprised of a single-element unit, to enable remarkably fast and nearly silent HD movie recordings with sound. The manual focusing mechanism is designed to deliver quiet and precise auto focus operation, for an affordable, high quality means to capture your life in still images or HD videos.
The new lens is made with ED (extra-low dispersion) glass to maximize the performance of the Micro Four Thirds System. The Micro Four Thirds System standard meets the telecentric requirements of dedicated digital design. Light rays strike the imaging element nearly head-on for optimum edge-to-edge image reproduction. It also enables much more compact design than the Four Thirds System standard (or other interchangeable lens systems) because it reduces the outer diameter of the lens mount by 6mm, and the distance from the lens mount to the sensor (the flange back distance) by approximately half. As a result, M.ZUIKO DIGITAL Micro Four Thirds System lenses offer uncompromising professional quality for capturing both still images and HD videos, and the lenses are exceptionally compact to make capturing life more fun.
The Micro Four Thirds System's design, compact size, low weight and amazing image quality with the new lenses extend the photographic potential of the system by adding more options. The new lenses are compatible with all Micro Four Thirds System Olympus PEN cameras, and all other current and future cameras that comply with the Micro Four Thirds System standard. When mounted on an Olympus PEN camera, the lenses are stabilized thanks to the camera's in-body Image Stabilization system and offer effective shake compensation at all focal lengths.
Availability
The M.ZUIKO DIGITAL ED 75-300mm f4.8-6.7 will be available in December 2010 in black and silver.
U.S. Pricing / Product Configurations
M.ZUIKO DIGITAL ED 75-300mm f4.8-6.7 Estimated Street Price: $899.99
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
