Camera Lenses
Olympus M.ZUIKO DIGITAL ED 40-150mm f4.0-5.6 Lens
80-300mm Equivalent Lens
Olympus announced the M.ZUIKO DIGITAL ED 40-150MM F4.0-5.6 Micro Four Thirds lens weighing only 6.7 ounces. With a wide zoom range with a 35mm equivalent to 80-300mm, this lens offers versatility and portability. It's an affordable complement to the powerfully simple 3x wide-angle zoom lens (M.ZUIKO DIGITAL ED 14-42 f3.5-5.6) that comes standard with the PEN kit.
The M.ZUIKO DIGITAL ED 40-150mm f4.0-5.6 has two lens elements in the rear focusing mechanism. The manual focusing mechanism is designed to deliver quiet and precise auto focus operation, for an affordable, high quality means to capture your life in still images or HD videos.
The new lens is made with ED (extra-low dispersion) glass to maximize the performance of the Micro Four Thirds System. The Micro Four Thirds System standard meets the telecentric requirements of dedicated digital design. Light rays strike the imaging element nearly head-on for optimum edge-to-edge image reproduction. It also enables much more compact design than the Four Thirds System standard (or other interchangeable lens systems) because it reduces the outer diameter of the lens mount by 6mm, and the distance from the lens mount to the sensor (the flange back distance) by approximately half. As a result, M.ZUIKO DIGITAL Micro Four Thirds System lenses offer uncompromising professional quality for capturing both still images and HD videos, and the lenses are exceptionally compact to make capturing life more fun.
The Micro Four Thirds System's design, compact size, low weight and amazing image quality with the new lenses extend the photographic potential of the system by adding more options. The new lenses are compatible with all Micro Four Thirds System Olympus PEN cameras, and all other current and future cameras that comply with the Micro Four Thirds System standard. When mounted on an Olympus PEN camera, the lenses are stabilized thanks to the camera's in-body Image Stabilization system and offer effective shake compensation at all focal lengths.
Availability
The M.ZUIKO DIGITAL ED 40-150mm f4.0-5.6 will be available in November 2010 in black and silver.
U.S. Pricing / Product Configurations
M.ZUIKO DIGITAL ED 40-150mm f4.0-5.6 Estimated Street Price: $299.99
Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
