DSLR Cameras
Olympus EVOLT E-410 Digital SLR Camera Announced
Portable Powerhouse Meets Any Challenge with 2.5-Inch Live View LCD, 10-Megapixel Imaging Sensor and Proven Dust Reduction System for Spot-Free Images
Olympus today announces the EVOLT E-410 digital SLR (single lens reflex) camera — easy enough for the first-time user, advanced enough for the serious photographer. High performance and functionality are packed into a surprisingly portable and simple-to-use body. The E-410 is the best value in its class (available in three configurations beginning at $699.99 for the body) and is loaded with innovations, including:
  • Live View LCD enables users to compose shots from a variety of angles other consumer digital SLR cameras just can’t match;
  • 10-megapixel Live MOS Image Sensor generates super high-resolution images that can be cropped or blown up to poster size without sacrificing image quality;
  • TruePic III for superior image quality in all lighting situations;
  • Dust Reduction System ensures spot-free photos, so users can spend more time taking pictures and less time removing unsightly specks from digital images with computer software; and
  • Extremely portable and lightweight body complemented by two new ultra-compact digital specific lenses that won’t weigh you down and encourage users to take it along on vacations or any family outing.
Innovative 2.5-Inch Full Time Live View HyperCrystal LCD
The E-410 offers ease-of-shooting and greater flexibility with the Live View LCD. Composing photographs is easier as subjects can be seen on the Live View LCD, which offers a wide 176-degree viewing angle. This enables images to be effortlessly taken from angles that would typically be difficult with a traditional optical viewfinder — which is still the only option on many competing digital SLR cameras. Interacting with subjects, such as toddlers and pets, is also possible thanks to the Live View LCD, which enables pictures to be taken while holding the camera away from your face.
The E-410’s big and bright 2.5-inch LCD display with approximately 230,000 pixels includes HyperCrystal™ technology, which offers many times the contrast of conventional LCD monitors, and enables images to be beautifully displayed in vivid color – both in preview and playback. The HyperCrystal LCD also provides a wide viewing angle, which ensures images can be composed from even the most obscure angles. The larger LCD makes viewing icons and text on the camera’s menu a squint-free process.
“The E-410’s Live View LCD is appealing to many consumers moving up from digital point-and-shoot cameras as many of these consumers have never used an optical viewfinder,” said Richard Pelkowski, product manager, Olympus Imaging America Inc. “The Live View LCD is also perfect for capturing up-close macro shots of flowers and jewelry.”
Detailed, Bright and Colorful Photos with 10-Megapixel Live MOS Image Sensor
The E-410 is loaded with an impressive 10 million pixels for high-resolution photos. The 10-megapixel sensor gives users the flexibility to blow-up their prints to the large sizes supported by many of today’s printers, or crop the image to print only a part of the image that is important to them. The high-performance Live MOS image sensor in the E-410 delivers excellent dynamic range for accurate color fidelity, and a new state-of-the-art amplifier circuit to eradicate noise and capture fine image details in the highlight and shadow areas.
Olympus’ proven Dust Reduction System produces spot-free photos with the exclusive Supersonic Wave Filter™. The patented ultrasonic technology vibrates to remove dust and other particles from the front of the image sensor and captures it on a special adhesive membrane every time the camera is turned on. These spot-free photos liberate users from hours spent retouching photographs at the computer or sending their cameras back to the manufacturer to remove dust trapped inside.
TruePic III for Image Clarity
Olympus’ enhanced TruePic III Image Processor produces crystal clear photos using all the pixel information for each image to provide the best digital images possible for every photo with accurate color, true-to-life flesh tones, brilliant blue skies and precise tonal representation in between. TruePic III also lowers image noise by one step to reduce noise in images shot at higher ISO settings, enabling great results in low-light situations.
Two More Lenses Added to World’s Largest Selection of Digital Specific Lenses
The versatility of the Olympus E-System comes from delivering the largest selection of “Designed-for-Digital” lenses — more than any other manufacturer to date. Olympus’ Zuiko Digital Specific Lenses come in a wide range of focal lengths to achieve the best image result in any given situation, and impress with their spectacular clarity and edge-to-edge sharpness.
The E-410 one-lens outfit includes a compact, Zuiko Digital ED 14 – 42 mm f3.5 – f5.6 Lens (equivalent to 28mm – 84mm in 35mm photography) that perfectly matches the imager so light strikes the sensor directly to ensure rich, accurate colors and edge-to-edge sharpness. Its 3x ED Glass zoom lens covers the range most frequently used in everyday photography and weighs just 7.5 ounces, offering users an extremely dynamic, portable everyday-use zoom. Close-ups as near as 9.84 inches (0.25 m) are also possible throughout the zoom range.
The E-410 two-lens outfit adds the Zuiko Digital ED 40-150mm f4.0-5.6 (80-300mm equivalent) Lens, which provides users with greater telephoto power for far-away shots in a compact size. This telephoto lens is smaller than many standard zoom lens at 2.6 inch diameter x 2.8 inch length and a weight of 8.8 ounces – a real benefit for anyone who wants to pack a powerful zoom lens without taking up much space. It also has great close focusing abilities, and is able to capture a subject up-close from a distance of 31.5 inches (.8m). Consumers won’t break the bank to get this great focal flexibility. For a mere $100.00, the two-lens kit includes the Zuiko Digital ED 40-150MM telephoto zoom lens — a $279.00 value!
Both lenses are exceptionally compact, allowing unimpeded mobility. They are sized for comfortable handling and designed for maximum image quality at an excellent price. Most important, these new lenses have the world-renowned ED lenses that deliver stunning high-quality images.
All E-Series cameras support the Four-Thirds Standard whereby Olympus and various other manufacturers produce high-quality Four-Thirds-compliant lenses and accessories that are specifically designed for digital SLR image capture. Because the E-410 is part of the Olympus E-System, it is compatible with a large and growing range of Olympus E-System accessories to further enhance personal shooting styles and applications. This includes the full line-up of Zuiko Digital Specific lenses and flashes.
Easy-to-Use, Easy-to-Handle Light and Ergonomic Design
The EVOLT E-410 is extremely portable, measuring 5.1 inches (129.5mm) by 3.58 inches (91mm) and 2.1 inches (53mm), excluding protrusions, and weighing 13.4 ounces (380 grams) body only. The new camera has a classic penta-mirror design that is light and compact enough to comfortably shoot with all day. Beyond its portable size, the E-410 delivers unparalleled ease of use – from menus that make sense and buttons on the body that are easy to understand and operate, to automatic settings for every imaginable situation.
While the E-410 includes a full range of manual control options to customize your creativity, it also has 30 shooting modes designed to provide the ideal settings for a variety of shooting situations automatically. These include Digital Image Stabilization, Night Scene, Fireworks, Beach and Snow, and Candle Light to name a few, as well as an xD Panorama mode (for use with Olympus xD-Picture Cards). Users also benefit from special color modes and the possibility to apply a variety of Black & White filters.
A new high-power rechargeable battery is included with the E-410 so that users can keep shooting for extended periods. Accepting both CompactFlash Type I & II, Microdrives, and xD-Picture Cards, the camera provides a choice of data storage options for enhanced flexibility, and it is possible to transfer image files from one card to the other right inside the camera.
Availability
The Olympus EVOLT E-410 Digital SLR will be available in May 2007. It includes: EVOLT E-410 Body, USB Cable, Video Cable, Li-Ion Battery Pack (BLM-1), Li-Ion Battery Charger (BCM-2), Shoulder Strap, OLYMPUS Master Software CD-ROM, Manuals, Warranty card.
US Pricing / Product Configurations
EVOLT E-410 body Estimated Street Price: $699
EVOLT E-410 with ED 14-42mm f3.5/5.6 Zuiko Digital Zoom Lens Estimated Street Price: $799
EVOLT E-410 with both ED 14-42mm f3.5/5.6 and ED 40-150mm f4.0/5.6 Zuiko Digital Zoom Lens Estimated Street Price: $899
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
