Olympus DP-10 Digital Audio Recorder
Olympus has anounced the DP-10 digital audio recorder, a “microcassette successor,” featuring the simple design and operation of analog recorders but with the memory, recording quality, battery life and storage capacity of a digital device.
Individuals looking for simplicity will be pleased with the look, feel and function of the DP-10. About the size of a deck of cards, the DP-10 fits neatly in the palm of your hand. The size of the LCD screen is impressive at 1.78 inches wide, and features a large, easy-to-read font.
Generously sized and easy to reach, the “Play”, “Stop” and “Record” buttons are located directly below the LCD screen. Each function button is color-coordinated to further enhance ease of use. The “Rewind” and “Fast-Forward” buttons allow for fast and slow playback to help easily find specific segments in audio files. A large front speaker is prominently positioned at the bottom of the device making it very easy to listen to files. A volume control wheel is located on top of the recorder and the “Erase” button is positioned off to the side to prevent data loss error during handling.
Recording in high-quality WMA format, the DP-10 boasts 63 hours of battery life. Set to LP mode, the device can record for more than 131 consecutive hours.
Complementing the memory is an easy-to-use interface that enables users to arrange files through a “calendar search”. This gives users the ability to organize recordings by date and time, as well as search for past recordings with ease.
In addition to the search function, DP-10 users will benefit from fast and slow playback settings that make note taking and transcription easy and efficient. The Noise Cancellation and Microphone Sense Settings are two other great functions of the DP-10 that help create premium recordings regardless of the environment. The Noise Cancellation blocks out unnecessary background noises so audio is captured with optimum clarity. The Microphone Sense Setting can be adjusted easily with the side button and set at 'high' or 'low'. This feature adjusts the microphones to pick up faint sounds easier or soften loud sounds to allow for the best audio recording.
Olympus DP-10 Features
  • Large LCD screen (1.78 inches) and font size
  • Large front speaker and function buttons
  • High-quality WMA recording
  • 63 hours of battery life
  • 71 hours (HQ) / 131 hours (LP) of recording time
  • Easy-to-use calendar search (no folders) for added simplicity
  • Playback speed control
  • Noise cancellation
  • Four-language display — EN, SP, FR, PT
  • Microphone Sense Setting
Availability
The DP-10 digital audio device will be available at the end of August 2010. Two AAA alkaline batteries and an instruction manual are included.
U.S. Pricing
DP-10 Estimated Street Price: $34.99
“The DP-10 brings analog users to the digital realm with minimal change in appearance and function. It gives them the best of both worlds.”
— Amy Leslie, product manager, Olympus Imaging America Inc.
Nothing KEF Headphone 1 Lifestyle
Nothing challenges the Apple AirPod Max with the new Headphone 1 with Sound by KEF.
Cyrus Audio 40 PPA Phono Preamp Front Cyrus Audio 40 PPA Phono Preamp Front
At $2,899, Cyrus Audio makes a bold claim about its 40 PPA which supports MC and MM cartridges with balanced XLR outputs and upgraded...
iFi Go pod MAX wireless IEM Adapters iFi Go pod MAX wireless IEM Adapters
The iFi Go Pod Max turns wired IEMs wireless with Bluetooth 5.4, balanced amp, and high-res audio—elevating sound while exposing your IEMs’ true colors.
Dangbei MP1 Max 4K Projector Lifestyle Dangbei MP1 Max 4K Projector Lifestyle
At under $2,000, the Dangbei MP1 Max is a compact 4K lifestyle projector with Google TV, AI setup, and hybrid laser-LED tech for screens...
Yamaha YH-L500A Wireless Headphones Lifestyle Yamaha YH-L500A Wireless Headphones Lifestyle
With proprietary Sound Field technology, the Yamaha YH-L500A wireless headphones provide personalized cinematic audio for $229.
V-MODA M10 and M100 Pro DJ Headphones V-MODA M10 and M100 Pro DJ Headphones
Not all headphones are designed for all listening needs. The V-MODA M-100 PRO and M-10 are affordable headphones that provide the quality and durability...
Amazon Prime Day is July 8-11, 2025
Daily Deals
Amazon Prime Day is a four-day shopping event from July 8-11, 2025 offering the biggest discounts of the year on consumer electronics.
