Okoro Media Systems to Showcase Meedio Essentials Of Home Entertainment At Cedia Expo
High-end audio visual home theater PC manufacturer, Okoro Media Systems (OMS), will be working with WSKA Software Corporation to showcase Meedio Essentials of Home Entertainment on high end plasma TV displays at the CEDIA Expo in Indianapolis.
CEDIA (Custom Electric Design & Installation Association) Expo Trade Show, September 9 -11, Indianapolis, Indiana Convention Center, Booth #2001 — Furniture in Motion exhibit.
“Our relationship with Meedio and WSKA enables us to give our customers a wider choice in their media management options. The freedom of choice for our customers is a core value of our business philosophy,” said Isidore Okoro, President of Okoro Media Systems.
OMS will also be unveiling two new models to demonstrate its high-end video output capability and Meedio’s software functionality. Four plasma TV displays will be provided by the Socratic Group. Hooker Furniture will be providing the home entertainment cabinets with Furniture in Motion’s integrated plasma lift systems to give the whole home theater experience. This whole home theater solution will be demonstrated at booth # 2001.
The new lines of HTPC’s were developed based on extensive research and feedback from the HTPC community. New to the OMS family of HTPC is the Low Profile and the Classic Series. The Low Profile series are designed for the enthusiast that wants a HTPC that does not take up a lot of room and blends seamlessly with other audio visual components. The Classic series enables an enthusiast who wants a more elegant HTPC, which does not have a hint of the traditional PC look. Designed with the look of a high end DVD player, the Classic series has no front USB or Firewire connections to disturb its elegant look.
The Classic will feature the high end HDA Digital X Mystique 7.1 Gold Dolby Digital Live sound card. This sound card allows real time encoding of sound content to 5.1 channel Dolby Digital surround sound through only one optical or coaxial connection to a digital decoder or AV receiver.
Both series are built on the AMD Athlon64 processor platform featuring “Cool N Quiet” technology and a minimum of 1 GB of memory. Like all other Okoro Media System home theater PC’s, you have the power to customize your HTPC online.
“Unveiling our new line of home theater PC’s at CEDIA is an excellent venue. We are excited to be among the industries top audio visual manufacturers and home design installers. This will give us a chance to show the industry what high end electronic consumers should be looking for in cutting edge digital media management and audio visual clarity,” said Christopher Curry, Vice President of Sales/Operations of Okoro Media Systems.
For more information about the fore mentioned products contact these respective companies listed below.
•Meedio Essentials of Home Entertainment – WSKA Software Corp.
•Plasma TV displays – Socratic Group
•HDA Digital X Mystique 7.1 Gold Dolby Digital live sound card – Blue Gears, Inc.
•Home Entertainment Cabinets — Hooker Furniture
•Plasma lift systems — Furniture in Motion
•Low Profile and Classic HTPC’s — Okoro Media Systems
Be sure to visit www.okoromedia.com often for upcoming products and events.
Tel: 781 297 3552
eFax: 781 846 4694
www.gowska.com
Socratic Group
2600 South Road
Ste 44-259
Poughkeepsie, NY 12601
Tel: 207-939-6579
Fax: 815-366-1218
socraticgp@aol.com
BlueGears, Inc.
41662 Christy St.
Fremont, CA 94538
Tel: 510.657.7252
Fax:510.657.7275
www.bluegears.com
Hooker Furniture Corporation
P. O. Box 4708
Martinsville, Virginia 24115
Phone: (276) 656-3314
Fax: (276) 632-0026
www.hookerfurniture.com
Furniture in Motion
350 Fifth Avenue
Suite 4918
New York, NY 10118
Tel: 212-594-6701
Fax: 212-594-6702
www.liftboxsystems.com
Okoro Media Systems
203 N. LaSalle
Suite 2100
Chicago, IL 60601
Tel: (877) 539-4788
www.okoromedia.com
Other product or service names mentioned herein are the trademarks of their respective owners.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
