OCZ Colossus 3.5-inch SSD
Cutting-Edge High-Capacity Colossus 3.5″ SSD Line with up to One Terabyte of Storage
OCZ Technology Group, Inc. today released the Colossus 3.5″ Solid State Drive (SSD) Series, designed to meet the performance and storage demands of high-end desktop users and enterprise clients. Available in up to one terabyte configurations, the Colossus Series marks a milestone in solid state drive technology, making it possible to have both high performance and high capacity in one solution.
“The new Colossus Series is designed to boost desktop and workstation performance and is for high power users that put a premium on speed, reliability and maximum storage capacity,” said Eugene Chang, VP of Product Management at the OCZ Technology Group. “The Colossus core-architecture is also available to enterprise clients with locked BOMs (build of materials) and customized firmware to match their unique applications.”
In addition to ample capacity, the OCZ Colossus delivers excellent performance made possible by an internal RAID 0 architecture. Excelling at small file processes during common tasks such as emailing, web browsing, and file transfer, Colossus allows for a state-of-the-art computing experience from basic to complex applications:
Colossus 3.5″ SSD (120GB — 1TB)
Maximum Read 260MB/s
Maximum Write 260MB/s
Sustained Write 220MB/s
Max IOPS (4k file size — random write) 14,000
For enterprise applications, Colossus SSDs not only diminish performance bottlenecks suffered by mechanical hard drive infrastructures, but reduce both heat and noise and provide a more durable alternative. This translates into exceptional energy-savings and reduced maintenance costs. Furthermore, the Colossus line is built with cost-effective multi-level cell (MLC) flash to make it a viable option for enterprise clients hesitant to adopt competing products due to the higher costs.
The Colossus SSD is available in 128GB, 256GB, 512GB, and 1TB solutions to accommodate a broader spectrum of applications than current 2.5″ SSD products; the 3.5″ housing is a straight drop in for many existing rack systems. The Colossus SSD series has an excellent 1.5 million hour mean time between failures (MTBF) and comes backed by a leading 3-year warranty and dedicated technical support, ensuring peace of mind over the long term. Additionally, OCZ offers unique customization options for OEM clients that may require tailored hardware and firmware solutions for their unique business.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
