Octava 4×2 HDMI Cross Switch for HD Theater
Norcross, Ga. – Octava Inc., specialists in HDMI solutions, announced the release of a Dual Output 4×2 HDMI Cross Switch. This unique product allows Home theater owners with dual displays to switch between 2 displays or create a “picture by “picture” effect.
As the price of flat panel technology continues to drop, many home theater enthusiasts will install multiple displays. For example, high-end home theater owners may install large Front Projection DLP for “weekend viewing” of movies and a smaller Flat Panel Display ( Plasma, LCD) for daily use.
Octava’s Picture-By-Picture 4×2 HDMI Cross switch is designed for Dual Display Theater systems. This unique 4×2 HDMI Cross Switch has 2 outputs and 4 Inputs and supports Full 1080P, and V1.3 standards . The Cross switch allows users to create a “Picture By Picture” system. The “picture by picture feature allows viewing of 2 different video sources simultaneously. For example, you may watch a sporting program on a large Projector and watch a second different program on a secondary display.
In addition, the 2 Outputs allow users to switch between 2 displays. Owners of large screen front projectors system and flat panel display can easily select which display they wish to view. For example, “day to day” HD programming can be switched to the LCD and “weekend viewing” (movies, major sporting events) can be switched to the Projector system thus allowing the user to share video sources and cut down projector bulb “wear and tear”
The outputs of the HDMI Cross Switch can be independently selected from 4 video inputs. The HDMI Cross switch does not “split” the input to both displays, which merely shows same video on both display. The significant advantage of the HDMI Cross Switch is flexibility such as “picture by picture” viewing, independent EDID communication between display and source, and Dual Display switching which maximizes user flexibility.
HDMI is the latest standard for distributing High Definition Digital Video and Audio in high def displays for 2 reasons: 1) uncompressed digital format ensures the best picture quality and 2) HDMI allows content providers to ensure that their intellectual property is protected through HDCP.
All Products are available at: www.octavainc.com
LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
