HDTV 4K & 8K TV
Octava- 3×4 HDMI V1.3 Distribution Amp targets multiple HDTV systems.
Norcross, Ga. – Octava Inc., specialists in HDMI distribution equipment, announced the release of 3×4 HDMI V1.3 switch and splitter Distribution Amplifier. The 3×4 HDMI Distribution Amplifier allow users to deliver Full 1080P HD video and audio streams to 4 HD displays simultaneously via HDMI. The 3×4 HDMI distribution amp is designed for home theaters, and public HD display kiosks that require the highest picture quality to be shown on 4 or more HD displays.
The Pro HD series 3×4 HDMI Distribution Amplifier distributes Full 1080P video streams to 4 HDTV’s simultaneously. The 3×4 HDMI distribution amps is fully scaleable and can distribute HDMI to more than 4 HD displays by cascading multiple units. Integrated 3×1 HDMI switching allow up to 3 separate HD sources to be selected. RS-232 serial port is provided for integration with 3rd party control systems.
In addition, a Digital Toslink Audio output is provided. The Digital Toslink Audio Output “couples” audio data from the HDMI data stream. The 3×4 Distribution Amplifier processes the HDMI data and outputs the audio via Toslink Audio while leaving the HDMI signals ( both audio and video) available to both HDMI outputs. The advantage is that users can easily integrate the 3×4 HDMI Distribution Amplifiers with pre-existing Surround Sound Audio Equipment that has no HDMI audio capability.
HDMI is the latest standard for distributing High Definition Digital Video and Audio in high def displays for 2 reasons: 1) uncompressed digital format ensures the best picture quality and 2) HDMI allows content providers to ensure that their intellectual property is protected through HDCP.
Product info available at: www.octavainc.com
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
