NZXT Tempest EVO Gaming Chassis
The Airflow King is reborn with advanced cooling performance, maximum expandability, and superior cable management
NZXT announced the Tempest EVO, a sleek, all black, steel mid tower gaming chassis. Building off of the original Tempest’s award winning design, the EVO brings advanced cooling power, expandability, and cable management. The Tempest EVO maximizes airflow circulation with Dual 120mm intake, side 120mm, and a rear 120mm fan. NZXT even redesigned the fan blades so they effectively deliver more air at lower noise levels. Additionally, the bottom mounted PSU provides better airflow and separation of heat from the CPU.
The Tempest EVO puts a premium on expandability with E-ATX support allowing for compatibility with higher end graphics cards, power supplies and server boards while the server-like HDD space holds up to 8 HDDs ensuring that enthusiasts can make significant upgrades to their system without having to replace the chassis. Installation and upgrades are a breeze with pre-drilled cable routing on the motherboard allowing for a cleaner look and improved airflow. The case also features added space behind the motherboard panel from a punched side panel design that allows for easy heatsink removal. Tempest EVO is well equipped for overclocking and watercooling enthusiasts with predrilled watercooling tube access and support for a dual 120mm radiator at the top panel.
“The original Tempest is one of our most successful designs due to its optimal airflow capabilities” said Johnny Hou, Chief Designer at NZXT. “With the additional improvements the Tempest EVO brings to the equation, it’s destined to be a top performer in its class.”
The Tempest EVO is available now at an MSRP of $99.99.
About NZXT
NZXT is a global brand established in 2004 as a PC hardware company built on the dreams of gamers. Their unique lineup of award-winning gaming hardware is completely inspired by gaming culture with product designs driven by the worldwide community of PC Enthusiasts and gamers. Combining unique design and unparalleled performance, gamers can find quality hardware representing their own style and personality in NZXT.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
