NUU Splash Portable Waterproof Wireless Speaker
Nuu Splash Wireless Speaker
NUU introduced the Splash, a portable waterproof wireless speaker with integrated microphone for all Bluetooth devices, including iPhones, tablets, laptops and more.
Designed to withstand everyday situations, NUU Splash is manufactured using aircraft-grade aluminum for lightweight toughness and is IP55 certified against dust and low pressure water jets for worry-free enjoyment. Awarded by the lnternational Electrotechnical Commission, IP ratings are the international standard to measure the degree of protection against solids and liquids.
The NUU Splash features easy to access volume and track selection controls and doubles as a speakerphone with a built-in microphone, giving users the ability to answer and hold conference calls wherever they are. Equipped with two neodymium speaker drivers and a passive bass radiator, the Splash delivers crisp, clear and balanced sound for both music and voice.
NUU Splash is Bluetooth 2.0 compatible with a rated battery life of 10 hours play or 240 hours stand by, has an auxiliary audio connector and can be charged using a micro USB plug.
Price and Availability
The NUU Splash portable waterproof wireless speaker is currently available for $79 at goNUU.com in green, blue, gray, red and black.
Specifications
  • Bluetooth: Version 2.0
  • Bluetooth Range: 10m
  • Water & Dust Resistance Rating: IP55
  • Battery Life: Up to 7 hours playback time (varies by volume level and audio content)
  • Audio Output Power: 2 x 3W
  • Speaker Driver: 2 x 40mm 4 ohm
  • AC Adaptor: 5V/2.6A with Micro USB plug
  • Supports Bluetooth A2DP audio profile, Bluetooth Handsfree profile (HFP) and Headset Profile (HSP)
  • Size (W x H x D): 155 x 62 x 52mm
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
