Novas SWS-10 in-wall goes below 20Hz; Now Thats In Your Face Bass!
NOVA (By: Earthquake Sound)
Bass in your face may seem a little hard to attain, since subwoofers are usually mounted on the floor behind a sofa or to the sides in a corner somewhere. But what if they weren’t, what if you were able to install 10″ subwoofer drivers on each side of the plasma TV, in the walls? No need to wait, you and your customers can now enjoy full-force bass with the SWS In-wall system, by Nova. This in-wall subwoofer system inegrates an Earthquake SWS-10″ shallow driver combined with the patented Earthquake SLAPS-10″ passive radiator for tight , clean and full of impact bass, all at the same time.
Earthquake was first to step into the shalllow woofer revolution: the SWS revolution provides the consumer with a speaker, with an xmax peak-topeak almost equal to its mounting depth with out lagging on performance. For those of you with math issues, we deliver 2 1/2″ deep 10″ subwoofer with over 2.5″ peak-to-peak excursion. Several Earthquake patented Technologies were implemented in designing the in-wall subwoofers: # 6,675,931 Low profile audio speaker /# 6,626,263 Passive speaker system / # 6,460,651 Passive speaker system / # 6,044,925 Passive speaker.
The SWS-10″ shallow woofer is packed with advanced features:- “UV” treated multi laminate composite foam surround. Pressed into a high-roll shape for ultra long excursions without taxing the cone area (more cone area = more spl)- Weather-resistant electroplated PVC cone, with platinum finish. Light aweigth, durable, and nondeforming under extreme excursions, allowing for high efficiency operation. – Grade “A” aluminum dust cap. This strong, light weight dust cap is directly attached to the voice coil. And it acts as a giant heat sink by deeping the voice coil running below normal operation temperature.
SWS In-wall subwoofer also comes with grill options, paintable metal mesh or cloth grill to blend perfectly with any decor. The cabinet is only 3.5″ in depth perfect for any in-wall application and is also a bass reflex system. Easy to install, this in-wall subwoofer system comes equipped with the Earthquake patented “TURN-N-LOCK” mechanism. It also can be fixed to the exisiting 2×4’s through a set of holes in the frame. Combined with the Image series in-walls you can install a complete home theater system with subwoofers front and rear surround. This whole application will be completely stealth with no obstruction, no wires, baby proof animal proof and no hassle.
MSRP:SWS10-In-wall…$1,899.00
Contact:
Earthquake Sound Corporation
Ph: 800-576-7944 / Jean-Paul
Fx: 510-732-1095
www.earthquakesound.com
nationalsales@earthquakesound.com / Michael
pr@earthquakesound.com / Jean-Paul
Edifier M90 Wireless Speakers Lifestyle Gaming in White
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool
Sylvox debuts the world’s first frameless outdoor TV at CES 2026, plus a 110-inch 4K QLED model built to survive sun, rain, sports nights,...
Brane Party Pro Portable Speaker at CES 2026 Brane Party Pro Portable Speaker at CES 2026
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Audio-Technica AT-LP7X Turntable Audio-Technica AT-LP7X Turntable
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Onkyo Muse Y50 Streaming Amplifier Black Angle Onkyo Muse Y50 Streaming Amplifier Black Angle
Onkyo marks its 80th anniversary with the Muse Y-40 and Y-50—compact streaming integrated amps with AirPlay 2, MM/MC phono, and HDMI ARC.
Klipsch The Nines II Wireless Power Speakers Lifestyle Klipsch The Nines II Wireless Power Speakers Lifestyle
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
