Nocs Design’s Monolith and Mini Active Wireless Loudspeakers Support Spotify and TIDAL Connect
Designed and engineered in Sweden, Nocs Mini and Monolith wireless speakers aim to simplify your stereo listening experience.
Nocs Monolith Wireless Speaker
Wireless loudspeakers offer a number of advantages that give them enormous appeal to music listeners regardless of their budget; high-end loudspeaker manufacturers have seen the writing on the wall (that would be Sonos) and spent the past five years developing wireless active alternatives to their traditional passive models in order to attract new blood.
Well-regarded manufacturers of traditional passive speakers such as PSB, Bowers & Wilkins, Sonus faber, ELAC, Triangle, Dynaudio, and KEF have clearly seen the light and not only have a growing range of products already — but there is a lot in the pipeline for Q4 2024 and beyond.
Nocs Mini
Nocs Mini
The growth of the category has attracted the attention of smaller brands such as Swedish manufacturer, Nocs, which have introduced its Mini and Monolith wireless loudspeakers into the market.
Tip: The Mini and Monolith are designed in Sweden and assembled in Estonia.
Shared Features
Nocs Monolith Angle
Nocs Monolith
  • Non-Traditional Physical Cabinet Design: The first thing you notice about the Nocs Mini and Monolith is their non-traditional physical design in which the speaker drivers are laid out in a rectangle rather than a more traditional vertical layout.
  • Nocs Studio Sound: Streaming all your music content with Nocs Studio Sound.
  • Spotify and TIDAL Connect: You can stream music from Spotify and TIDAL to the Monolith or Mini directly from your smartphone or other compatible device.
Tip: We have seen this design approach in their very high-end Stratton Acoustics Elypsis 1512 loudspeakers. However, that is where the similarity ends. Nocs is going for a different customer base at much more reasonable prices with these models.
Nocs Design Music App
  • Easy Setup: The NOCs Design Music App (Android/iOS) provides easy setup and control of the Monolith and Mini.
  • Multi-Speaker Connectivity: Connect up to 8 Monoliths or Minis wireless to expand your listening experience throughout the house.
  • NAT (Nocs Amplitude Tuning): This feature provides consistent sound over the entire amplitude range.
  • Diaphragm Material: PP composite with elastomer.
  • Case Material: PP composite, braced.
Nocs mini
Nocs mini
Comparison
Nocs MiniNocs Monolith
Speaker Type5-Way
Cabinet ConstructionCNC machined MDF (Medium Density Fiberboard).CNC-machined birch plywood
Full Range Drivers2 x 3.5-inches 3 x 3.5-inches
Woofer Drivers2 x 6-inches (vented/bass reflex)
SubwooferCustom-tuned subwoofer module with a passive radiator. Neodymium magnet, long stroke subwoofer driver.
Frequency Response (+/- 3dB)40Hz to 20kHz30 Hz to 20 kHz
Amplifier Type Class DClass D
Power Output110 watts150 watts
Maximum SPL (at 1 meter)94 dBNot provided
Bluetooth 5.0ACC, SBCACC, SBC
Apple AirPlay 2YesYes
Spotify ConnectYesYes
Tidal ConnectYesYes
Nocs Design Music AppYesYes
Wireless Multiroom ConnectivityUp to 8 MinisUp to 8 Monoliths
Wi-FiYesYes
Dimensions270 x 230 x 106 mm
(10.6 x 9 x 3.9 inches)
550 x 380 x 180 mm
(21.5 x 15 x 7 inches)
Weight3.3 kg (7.9 lbs)12 kg (26.45 lbs)
Pricing & Availability
The Nocs Design Mini is priced at $800 each and the Monolith is priced at $1,500 each. Both speakers are available through the Nocs Design website
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
