Earbuds & In-Ear Headphones
Noble Audio’s FoKus Triumph Wireless Earbuds Incorporate xMEMS Technology
$369 premium wireless earbuds combine a custom made 6.5mm dynamic driver with a Cowell xMEMS driver for high-quality sound.
Noble Audio FoKus Triumph True Wireless Earbuds with Case
Noble Audio, makers of wired and wireless in-ear monitors, earphones, and related accessories has released its FoKus Triumph TWS (True Wireless Stereo) Earbuds.
Designed to deliver the high-end sound quality that Noble Audio is known for, the FoKus Triumph incorporates a custom 6.5mm dynamic driver coupled with the xMEMS Labs Cowell, an all-silicon “solid-state” speaker.
XMEMS Labs Cowell Driver Module
Following the Falcon Max and XM1, the FoKus Triumph is Noble’s third product to benefit from its partnership with xMEMS Labs.
The FoKus Triumph
At the core of the FoKus Triumph, is the incorporation of the Qualcomm SoC QCC3071 chip, which is combined with custom dynamic drivers for accurate bass and midrange reproduction and the xMEMS Cowell solid-state driver for the tweeter frequencies.
Noble Audio FoKus Triumph Wireless Earbuds Internal Assembly featuring the xMEMS Cowell speaker module
Noble Audio FoKus Triumph Wireless Earbuds Internal Assembly featuring the xMEMS Cowell speaker module.
For content access and additional audio support, the FoKus Triumph includes Bluetooth 5.3, LDAC, Snapdragon Sound, and aptX Adaptive (which provides lossless audio support).
Additional Features:
  • Multi-Point Connectivity: This allows the Fokus Triumph to be paired with more than one source device so that you can switch between those devices without having to re-pair the earbuds..
  • Voice Control: Voice assistant support for Siri and Google is provided.
  • Onboard Control: Easy touch controls are provided for basic earbud functions.
Noble Audio FoKus App
  • FoKus App: The Noble FoKus app is free and is available on Google Play and Apple’s App Store. The app includes a 10-band equalizer with presets and the ability to create custom presets. The equalizer includes a hearing test function that will personalize your EQ settings based on the results of the hearing test. Transparency Mode can be controlled by the app as well.
  • Battery Life and Charging: Battery life is an expected 7.5 hours at 50% volume. The designer charging case is wrapped in Alcantara and has wired and wireless charging options. The 500 mAh battery provides up to 4 extra charges for the earbuds.
  • Exterior Design: The build includes an Alcantara-covered charging case, ergonomic shells, and hand-painted faceplates. The Earbuds provide an ergonomic and secure fit.
Noble Audio FoKus Triumph True Wireless Earbuds inside Charging Case
Pricing & Availability
The FoKus Triumph is available for $369 direct from Noble Audio and Authorized Dealers.
Tip: Product supply fluctuates.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
