Niles Expands CAT-5 Balun Assortment To Include Wall Mount Models
Custom installation professionals can mix-and-match component and wall-mount baluns to reduce cabling costs and deliver polished, professional trimouts
DENVER, COLORADO — September 6, 2007 — Niles Audio Corporation, The First Name in Custom Installation, today announced the introduction of nine wall mount CAT-5 Balun models. Each wall mount balun is designed to complement a component counterpart in the popular Niles balun lineup. Niles baluns convert a wide range of signals to balanced circuit topology enabling conventional audio/video signals to be transmitted over long runs of low-cost CAT-5 cabling. Normally used in pairs, each balun in the series is designed with a specific signal application in mind, i.e., analog audio, digital audio, composite video, S-video, cable TV, component video and VGA signal distribution. Because both Niles wall-mount and component baluns feature passive circuitry, they can be mixed and matched to provide solutions for virtually any installation. For example, a component balun can be used to send high definition video signals from a cable/satellite receiver to a wall mount balun that is installed behind a flat panel display.
“The overwhelming success of our component balun offering inspired us to add corresponding wall mount versions for every application,” said Frank Sterns, president of Niles. “Now professional custom installers can select the appropriate baluns based upon their specific need for any installation,” Sterns added.
The Niles wall mount balun lineup consists of nine models, each with a specific signal distribution application in mind:
1.) C5-A2WM wall mount stereo audio balun is for placing line level audio devices extended distances from their audio source (up to 760 meters)
2.) C5-DAWM wall mount digital audio balun is for placing digital audio devices extended distances from their digital audio source (up to 180 meters)
3.) C5-VWM wall mount video balun is for placing composite video devices extended distances from their video source (up to 760 meters)
4.) C5-SVWM wall mount S-video balun is for placing S-video devices extended distances from their video source (up to 150 meters)
5.) C5-VGAWM wall mount VGA balun is for placing VGA video devices extended distances from their VGS video source (640 X 480 pixels up to 100 meters)
6.) C5-VA2WM wall mount composite video and stereo audio balun is for placing A/V devices extended distances from their A/V source (color devices, up to 670 meters)
7.) C5-SVA2WM wall mount S-video and stereo audio balun is for placing A/V devices extended distances from their A/V source (up to 150 meters)
8.) C5-HDDAWM wall mount component video and digital audio balun is for placing A/V devices extended distances from their A/V source (1080i and 720p up to 150 meters and 480i/p up to 300 meters)
9.) C5-RFWM wall mount cable TV/antenna balun is for extending cable TV and 75-ohm antennas up to 100 meters
All new balun models will be on display at the CEDIA Expo in Booth 606 and will be available in October 2007.
Talking Points
• Niles baluns transmit audio/video signals over CAT-5 cabling
• Niles baluns are used in pairs to reduce cost and increase flexibility/range over conventional wiring
• There are nine varieties of baluns that cover distributing analog audio, digital audio, composite video, S-video, cable TV, component video and VGA signals
• Niles wall mount and component balun models can be mixed to provide the ideal signal origin and termination connections
• Niles baluns ship with a ten-year limited warranty
Corporate Information
Niles Audio Corporation, based in Miami, is a 29-year-old company recognized as the First Name in Custom Installation. As a leading designer, manufacturer and marketer of audio/video custom installation products, Niles Audio is guided by seven principles: a commitment to reliable, high-performance, application-specific product design, a complete and up-to-date product assortment with just-in-time delivery, extensive training and technical support, exemplary customer service and strong dealer relationships. Niles is a brand based on strength, reliability and outstanding performance with a wide range of award-winning, innovative products.
Additional information may be obtained by contacting Mike Detmer at Niles Audio Corporation, 12331 SW 130th Street, Miami, FL 33186 (1-800-BUY-HIFI; ext. 197) or by visiting www.nilesaudio.com.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
