In-Wall Speakers
Niles Cynema Soundfield In-Wall Soundbar System
Niles Cynema Soundfield In-Wall Soundbar System - tweeter
Niles Audio today introduced Cynema Soundfield, an innovative soundbar speaker system, which features a unique in-wall mounting system that allows it to be perfectly centered under flat-panel displays without the hassle of cutting or drilling wall studs. The modular system simplifies installation and offers the flexibility to place speakers exactly where needed for the ultimate in audio performance while providing an aesthetically pleasing look.
An unobtrusive addition to any residential entertainment system, home theater, or flat panel TV installation, the Cynema Soundfield system is available in three active models and one passive model in lengths of 48, 55, and 65 inches to match today’s most popular display sizes. The in-wall soundbar consists of left, right, and center self-contained speaker modules and includes a preamp/amplifier module for the powered models. Powered models also include a separate low voltage power supply — easily mounted in a stud bay adjacent to a wall outlet or behind the display — to eliminate the need for high-voltage wiring in the wall and the electrician required to do it.
Cynema Soundfield’s speaker and amplifier modules easily snap in from the front into rails mounted on the wall’s studs, and can be adjusted between the studs as needed to achieve the best soundfield. Installers can configure the mounting positions of each speaker module and the amplifier around existing studs with ease. The speaker and amplifier modules have small foldable L-shaped brackets on each side to enable the installer to temporarily hang the modules on the in-wall mounting system’s rails, freeing up both hands and making the speaker and amplifier connection terminals easy to see and connect. Wiring is run through specially designed spaces in the mounting system to eliminate the need to drill holes in the studs. Included spacers can be inserted to cover any empty areas between modules for a clean installation. A low-profile, magnetically attached, and paintable MicroPerf grille makes the entire assembly virtually invisible to end users for a clean look.
Included with the CSF-65A, CSF-55A, and CSF-48A amplified models is a 3-channel by 30 W digital preamp/amplifier with Dolby Digital processing. The preamp/amplifier module can be operated via IR for simple integration and auto-senses audio input to function as a seamless extension of the TV’s remote control. The amplified Cynema Soundfield systems incorporate versatile design features that enable them to work effortlessly as part of a whole-house distributed audio system and connect wirelessly with Niles subwoofers. The passive CSF-48P does not include an amplifier module, allowing integrators to utilize any form of amplification for added flexibility.
The Cynema Soundfield passive model contains three speaker modules, one in-wall mounting system with grille, and one cutout template for the in-wall mounting system. The three powered models contain one preamp/amplifier module, one in-wall power supply unit with AC power cord, one cutout template for the in-wall power supply box, one Niles SW-T bracket for mounting an optional Niles SW-T wireless subwoofer transmitter, one TOSLINK optical cable 3m, one stereo 3.5mm to dual RCA cable, one DC power cable for the optional wireless transmitter 1.5m, and three speaker wires for the left, center, and right speaker modules.
Price and Availability
The Niles Audio Cynema Soundfield system is now shipping at an MSRP of $1,195.95 for the CSF-48P, $1,599.95 for the CSF-48A, $1,749.95 for the CSF-55A, and $1,999.95 for the CSF-65A.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
