Loudspeakers
Niles CM Loudspeakers Deliver The Utmost In High Fidelity In Distributed Audio Systems
8″ models complement larger areas in residential and light commercial installations
DENVER, COLORADO — September 6, 2007 — Niles Audio Corporation, The First Name in Custom Installation, today announced the addition of four new 8″ ceiling mount loudspeakers to its wide range of application-specific CM Loudspeakers. All four models feature an 8″ integrated woofer/baffle design to provide rich, robust bass response which is perfect for filling larger residential and commercial areas with high fidelity sound. Each of the new 8″ models incorporate pivoting tweeters to provide precise dispersion of high frequencies while allowing the flexibility to install the loudspeakers where they look best. All CM Ceiling Mount Loudspeakers feature weather resistant construction to accommodate installation in moist indoor areas like showers and outdoor areas under eaves. Including these four new models, custom installation professionals now have over thirty in-ceiling loudspeaker solutions to choose from, covering virtually every system design requirement.
“With their integrated baffle/woofer design, Niles new 8″ CM models pack powerful bass with a reduced outer diameter, making them ideal for larger areas in residential and commercial installations,” said Frank Sterns, president of Niles. “Because Niles CM Ceiling Mount Loudspeakers are weather resistant, they are ideal for installation in moist indoor areas like showers and outdoor areas under eaves,” Sterns added.
The new CM830, CM850 and CM860 two-way loudspeakers with pivoting tweeters have a distinct and easy-to-describe feature/performance upgrade path. They are sold in pairs and typically employed in distributed audio systems to provide stereo sound in a room or for a zone of music. The CM850Si stereo input model provides a high-quality solution for installations where only one speaker can be used. Its woofer combines the bass from the left and right channels while its bridge-mounted stereo imaging tweeter array directs the high-frequency sounds from both the left and right channels at opposing angles to preserve stereo separation. All four new models will be on display at the CEDIA Expo in Booth 606 and will be available in December 2007.
CM8 (Two-way Loudspeakers with Pivoting Tweeter) Series Details:
> CM830 — MSRP $349.95 per pair — employs a polypropylene woofer with butyl rubber surround and 1″ fluid-cooled UltraSilk soft dome tweeter for clarity at high frequencies and proprietary bridge-mounted tweeter pivot mechanism which allows for up to 20 degrees of tweeter adjustment
> CM850 — MSRP $399.95 per pair — employs an injection-molded TCC (talc, carbon and ceramic) woofer with butyl rubber surround and 1″ fluid-cooled Teteron dome tweeter for ultra-wide dispersion and smooth high-frequency response and proprietary bridge-mounted tweeter pivot mechanism which allows for up to 20 degrees of tweeter adjustment
> CM860 — MSRP $499.95 per pair — employs an interlaced glass fiber woofer with butyl rubber surround and 1″ fluid-cooled Teteron dome tweeter for ultra-wide dispersion and smooth high-frequency response and proprietary bridge-mounted tweeter pivot mechanism which allows for up to 20 degrees of tweeter adjustment
> CM850Si — MSRP $274.95 each — employs a dual voice coil, injection-molded TCC (talc, carbon and ceramic) woofer with butyl rubber surround and dual 1″ pivoting fluid-cooled Teteron dome tweeters for ultra-wide dispersion and smooth high frequency response and bridge-mounted stereo imaging tweeter array to direct high frequency sounds from left and right channels at opposing angles to preserve stereo separation
Talking Points
• Niles CM8 Series Loudspeakers provide a rich, robust bass, perfect for larger residential and commercial areas
• All Niles CM models feature weather resistant construction and are ideal for installation in moist indoor areas like showers and outdoor areas under eaves
• All Niles CM models employ integrated baffle/woofer design to deliver powerful bass from a speaker with a reduced outer diameter
• All Niles CM models incorporate pivoting tweeters to provide precise dispersion of high frequencies while allowing the flexibility to install the loudspeakers where they look best
Corporate Information
Niles Audio Corporation, based in Miami, is a 29-year-old company recognized as The First Name in Custom Installation. As a leading designer, manufacturer and marketer of audio/video custom installation products, Niles Audio is guided by seven principles: a commitment to reliable, high-performance, application-specific product design, a complete and up-to-date product assortment with just-in-time delivery, extensive training and technical support, exemplary customer service and strong dealer relationships. Niles is a brand based on strength, reliability and outstanding performance with a wide range of award-winning, innovative products.
Additional information may be obtained by contacting Mike Detmer at Niles Audio Corporation, 12331 SW 130th Street, Miami, FL 33186 (1-800-BUY-HIFI; ext. 197) or by visiting www.nilesaudio.com.
Niles, The First Name In Custom Installation, and Blending High Fidelity And Architecture are registered trademarks of Niles Audio Corporation in the United States and/or other countries. All other trademarks are property of their respective owners.
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
