Camera Flashes
Nikon SB-700 Speedlight Flash
Nikon Inc. introduced the versatile new SB-700 Speedlight, the latest addition to Nikon's powerful and renowned Creative Lighting System for a wide range of photographers and applications. The SB-700 is a high-performance flash that brings simplicity to on-camera, remote and multiple flash photography. Building on the success of the popular SB-600 Speedlight and the advanced functionality of the SB-900 Speedlight, the SB-700 also incorporates a wide zoom range covering the most popular focal lengths and FX/DX-format identification that optimizes zoom settings based on the user's camera body. The SB-700 also provides a more efficient use of batteries and flash coverage in addition to three light distribution patterns for flash-to-scene customization. Whether used as an on-camera flash or as a wireless commander or remote, the Nikon SB-700 Speedlight offers dependable and consistent flash exposure even under the most challenging lighting conditions.
Designed for a variety of photographers ranging from amateurs in the field to professionals in the studio, the SB-700 integrates a host of new features designed to make flash photography simple, accurate and creative. The SB-700 is for photographers looking for an on-camera Speedlight offering more power for greater depth-of-field control than the built-in flash, or an additional Speedlight for wireless multiple flash set-ups. This Speedlight will also satisfy the needs of photographers looking for a compact Speedlight that can be set up as a Commander or a Remote as well as those who want to upgrade from their existing or older Nikon Speedlight.
The Nikon SB-700 has many new and redesigned features and that make it easy-to-use, yet powerful enough to assist in tough and challenging lighting conditions and settings. The SB-700's LCD design and layout enables easy-to-remember and intuitive operation, while the multi-step power zoom covers wide 24-120mm angle of view with FX-format cameras. The improved user interface of the SB-700 utilizes a large easy-to-read dot-matrix LCD panel making navigation and usage even easier.
As part of Nikon's popular Creative Lighting System, the SB-700 includes support for Nikon's advanced wireless TTL operation and can function as a wireless Commander with control over two separate groups of Speedlights, or as a Remote Speedlight when controlled by the SB-900 Speedlight or the built-in Speedlight set to Commander Mode in most Nikon D-SLR's. The SB-700 also incorporates a high-speed recycling time of approximately 2.5 seconds for full power with NiMH batteries, and approximately 3.0 seconds with AA Alkaline batteries. The Nikon SB-700 also features a new Quick Wireless Mode with A:B (light ratios) for quick setting of multiple flash units. This makes it easy and quick to control two remote flash units in i-TTL mode.
Additionally, the SB-700 also features enhanced Thermal Cut-Out detection that automatically detects heat build-up due to rapid flash firing. By increasing the recycling time if the temperature of the flash head rises above a certain threshold, the SB-700 protects the flash from damage due to overheating.
For improved durability, heat-resistance and ease-of-use, the SB-700 uses new hard plastic-type color filters for fluorescent or incandescent color temperature balancing. When using the supplied filters, the flash automatically recognizes which filter is being used and adjusts white balance accordingly on select Nikon D-SLR cameras. Additionally, the SB-700's AF-assist illuminator is compatible with the complete line of AF systems used in Nikon D-SLR cameras*.
Similar to the Nikon SB-900 Speedlight, three illumination patterns (standard, center-weighted and even) can be selected in SB-700 to match each shooting situation. When “even” is selected, the light from the flash will cover a subject from center to edges without light falloff. This pattern is suitable for shooting group photographs indoors. The “standard” pattern will cover all conventional, standard flash coverage. The center-weighted pattern provides larger guide numbers than other light distribution types at the same focal lengths. This illumination pattern is suitable for subjects such as portraits, in which the light falloff at the image edges can be ignored.
Like the Nikon SB-900, when the SB-700 is mounted on a camera compatible with user firmware updates, the SB-700 firmware can be updated using the same procedure as with a Nikon D-SLR camera.
Available Accessories
The SB-700 uses four AA type Alkaline, Lithium or rechargeable NiMH batteries. To enhance the weatherproof ability of Nikon D-SLRs, optional water guards will be available for select cameras to protect the connection between the flash and camera, allowing users to utilize the flash when weather conditions are less than ideal. The SJ-4 Color Filter set provides a Warming, Red, Yellow or Blue filter for adding color to the background, foreground or just to accent the scene.
Price and Availability
The new Nikon SB-700 Speedlight is scheduled to be available in mid-November 2010 for $329.95. The SB-700 will come bundled with the Speedlight Stand, Bounce Adapter, Color Filter Holder, Intelligent Color Filter Kit, Diffuser Dome and soft case.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
