DSLR Cameras
Nikon D7100 Digital SLR Camera
Nikon D7100 DSLR Camera
Nikon today announced their new flagship DX-format camera, the D7100 DSLR, which features a new 24.1-megapixel CMOS sensor, 51-point AF system and wireless connectivity. The company claims the innovative sensor design delivers the ultimate in image quality by defying convention; because of the high resolution and advanced technologies, the optical low pass filter (OLPF) is no longer used. Using NIKKOR lenses, the resulting images explode with more clarity and detail to take full advantage of the 24.1-megapixel resolution achieved with D7100’s DX-format CMOS sensor.
Driven by Nikon’s exclusive EXPEED 3 image processing engine, the D7100 realizes a focus on image quality that extends beyond staggering sharpness to outstanding images with a wide dynamic range in a variety of lighting conditions. A wide ISO range of 100-6400 (expandable to Hi-2 of 25,600) allows for more versatile shooting to capture challenging conditions such as nature at twilight or even sports under less-than-ideal lighting. Even at higher ISOs, noise is minimized for both still images as well as when recording HD video.
Nikon D7100 DSLR Camera - back angle
The Nikon D7100 is designed for the experienced shooter ready to take their photography to the next level, who demands a camera that conveys reliability and performance, and who is eager to embrace the next photographic challenge. These features include:
New 51-Point AF System – The D7100 features Nikon’s professionally proven and lightning-fast 51-point AF system, with a new Multi-CAM 3500DX AF module. Additionally, the AF system and exposure are augmented with Nikon’s 3D Color Matrix Metering II 2,016-pixel RGB sensor and Scene Recognition System, which recognizes the scene prior to shooting in order to adjust AF, AE, AWB and other parameters. The results of this system are accurate and even exposures, sharp details and vivid color, frame after frame. For additional precision, 15 of the 51 AF points are cross-type, and the center point is functional at f/8, giving DX photographers an additional telephoto advantage when using a teleconverter.
Rapid Response and Operation – To help ensure the decisive shot is not missed, the D7100 can shoot at up to six frames-per-second (fps) at full resolution and up to seven fps when using the new 1.3x crop mode at slightly reduced resolution. Overall operation and image processing is swift, while startup and shutter lag is nearly imperceptible with a release time lag of 0.052 second (CIPA). Image data is also written to dual SD card slots, which accept the latest high-speed UHS-1 and SDXC cards.
Nikon D7100 DSLR Camera - double slot
1.3x Crop Mode – Sports photographers take note: Building upon the telephoto benefits of the DX-format, the D7100 has the unique ability to shoot in a 1.3x DX crop mode for both stills and HD video. While in this innovative mode, shooters will gain an extra telephoto boost (2X), and a boost in burst speed to seven fps, with 15.4- megapixel resolution. Additionally, while in this mode, the 51-point AF array covers more of the frame, allowing improved subject acquisition and tracking performance through the viewfinder.
New High Resolution LCD – The new, wide and bright LCD screen is 3.2-inches and features a super high resolution of 1,229K dots. Now photographers can easily compose and check critical focus for HD video.
New Viewfinder – Nikon has implemented a bright and high-contrast new OLED data display within the optical viewfinder that makes it easier to read and see shooting data. When composing through the viewfinder, users see 100% frame coverage, essential for proper framing.
Spot White Balance – A new feature for Nikon cameras, Spot White Balance allows for quick and precise white balance adjustment while shooting in live view. By selecting a desired point on the screen, users can set a custom white balance from a distance, even while using a super-telephoto lens. This is helpful for shooting video or when shooting under unfamiliar lighting when no gray card is available.
Durable Construction – Built to perform in a wide variety of conditions, the D7100 is built to the same moisture and dust resistance specifications of the venerable Nikon D300S. For durability, the top and rear covers are constructed of magnesium alloy, while internally, the shutter has been tested to withstand 150,000 cycles. Despite its robust construction, the camera remains lightweight, weighing in at approximately 1.5 pounds (body).
Enhanced Interface – To make it easier for users to quickly access frequently used functions, the “i” button has been added to the enthusiast-oriented control layout on the camera.
With an attached (optional) WU-1a Wireless Mobile Adapter the user has the ability to share images to a supported smartphone or tablet, shoot remotely from their device, and transfer photos from up to 49 feet away. The Nikon Wireless Mobile Utility application is available free of charge on Google Play for Android™ devices or from the App Store. When using the application, photographers can wirelessly transfer images from the camera to a mobile device and even remotely control the camera.
The Nikon D7100 has a wide variety of innovative features for capturing HD video at various frame rates. With a press of the dedicated video record button, video can be recorded at 1080/30p, or at 60i/50i (in 1.3x Crop Mode) for optimal playback on many HDTV’s when connected via HDMI. The D7100 also provides the ability to record stereo sound through the internal microphone, or attach an optional external microphone such as Nikon’s ME-1, through the dedicated microphone terminal. To reference audio, the camera also features a headphone terminal. Users can also get creative using Nikon’s Creative Effects in real time. This feature lets users take advantage of modes like Selective Color or Color Sketch to create truly customized movies.
Nikon D7100 DSLR Camera - top
In addition to full manual controls, the Nikon D7100 features a variety of intelligent modes to create effects and special features so that users can unleash their creativity. Nikon’s Picture Controls can be applied to photo and video to change the color, tone and saturation of an image for creative control. When capturing still images, the same Creative Effects modes and filters available in video are also at the disposal of the user. By combining consecutive frames, the D7100 also has a high dynamic range (HDR) function to let users capture photos with a vast tonal range.
The D7100 is compatible with Nikon’s dedicated DX-format lenses and more than 50 FX-format lenses. NIKKOR lenses offer the ultimate in sharpness and clarity in photos and HD video. For added versatility, the camera features a built-in flash, or can act as a commander in Nikon’s popular Creative Lighting System (CLS).
Nikon D7100 DSLR Camera - right
Nikon D7100 DSLR Camera - left
In addition to the D7100, Nikon also announced the WR-1 Transceiver for Nikon D-SLR cameras. This device uses the 2.4 GHz radio frequency for maximum range when communicating with the camera, extending the range and functionality for remote shooting applications. The communication range between WR-1 units is approximately 394 feet, and 15 channels are available. Users also have the ability to remotely control a camera (with a WR-1 used as a receiver) attached by operation of another WR-1 (used as a transmitter), and also perform simultaneous or synchronized release of shutters on several cameras using the WR-1. Furthermore, there are a wide variety of options for remote shooting, which include dividing remote cameras into groups and controlling each group separately and interval timer photography. Remote shooting by combining the WR-1 with WR-R10/WRT10 wireless remotes is also possible.
Price and Availability (March 2013)
  • Nikon D7100 with the AF-S DX NIKKOR 18-105mm f/3.5-5.6 VR lens → $1,599.95
  • Nikon D7100 (body only) → $1,199.95
The new MB-D15 battery grip and the WR-1 transceiver will also be available in March 2013, and pricing for these products is not yet announced. The WU-1a Wireless Mobile Adapter is currently available $59.95.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
