DSLR Cameras
Nikon D600 SLR Digital Camera
D600_24_85_front34l_KM.low
Nikon recently introduced their smallest, lightest and most affordable full-frame HD-SLR D600 digital camera with pro-grade photo and video features plus wireless sharing and capture capabilities.
The D600 employs Nikon’s newly developed, large 24.3-megapixel FX-format CMOS Sensor (35.9 x 24mm) with a wide ISO range from 100-6400 (expandable from 50-25,600) to give photographers maximum low-light flexibility yielding clean images with minimal noise and accurate color. The full ISO range can also be used while capturing HD video in challenging light. Nikon’s exclusive EXPEED 3 image processing engine interprets the massive amount of image data flowing from the sensor to quickly process images and HD video.
Nikon’s Scene Recognition System and 2,016 pixel RGB sensor recognizes the scene prior to capture. It meticulously analyzes factors such as color and brightness with extraordinary precision and compares all the data using Nikon’s exclusive 30,000 image database. The result is enhanced AF performance and flattering exposures.
For precise AF performance in a wide variety of shooting conditions, the D600 features a 39 point AF system with the new MultiCAM 4800FX AF module. This AF array is well suited to a wide variety of shooting styles and disciplines, offering AF modes to let users select a single point, continuous AF, Dynamic AF or use 3D tracking to keep pace with a moving subject throughout the frame. Additionally, the system features nine cross type sensors for maximum accuracy, while seven AF points are fully functional when using compatible NIKKOR lenses and teleconverters with an aperture value up to f/8 for extreme telephoto applications.
The D600 is ready to shoot in 0.13 seconds, with a 0.052 second shutter release. The camera emphasizes speed and performance, from overall operation and image processing, helped in part by the exceptional EXPEED 3 processing engine. The camera is also capable of bursts of images at 5.5 frames per second (fps) at full resolution with full AF, to capture decisive moments. To further enhance speed and workflow, images and video can also be rapidly transferred to dual SD card slots that are compatible with the latest SDXC and UHS-1 high speed standards.
Enthusiasts will also appreciate other thoughtful features made to appeal to more advanced photographers, such as the 100% frame coverage seen through optical viewfinder. The wide and bright view makes it easy to compose in a variety of conditions, and affords the ability to enjoy shooting for hours on end with minimal eye fatigue. Additionally, the D600 features several scene modes and features to enhance creativity, including one-touch access to Picture Control functions through a new dedicated button. Photographers can also shoot images in High Dynamic (HDR) mode for amazing highlights, and create awe-inspiring time lapses with ease.
The Nikon D600 gives users the ability to record Full HD at varying frame rates and resolutions including 1080p video at 30, 25 or 24p, and 720p video at 60, 50 and 30p. When shooting HD video at the highest quality setting, up to 20 minutes can be recorded, or up to 29 minutes and 59 seconds in normal quality for added convenience when shooting static shots such as interviews and events. The large 3.2-inch 921K dot LCD screen makes it easy to preview images or video captured, navigate the menu system or confirm critical HD focus, while automatic brightness control adapts seamlessly to changing lighting conditions.
Sophisticated video features help to increase the production value on any project, including full manual control of exposure, and the ability to switch between FX and DX-format (1.5X) at Full HD for a telephoto boost and alter depth of field. Users can opt to focus manually or can take advantage of the full-time AF while recording to help ensure faces are in focus or track a moving subject. Additionally, videographers have the ability to capture audio with the onboard microphone or record stereo audio externally using the mic input. Audio can be monitored through the headphone jack and levels can be displayed on the LCD with peaking.
In addition to the ability to play back HD video and images through the HDMI terminal, users are also able to experience pro-grade video features in the Nikon D600. For monitoring and streaming applications, the image can be displayed on the LCD screen while simultaneously shown on another monitor through the HDMI, with or without shooting data. What’s more, the D600 adds the ability to transfer uncompressed video via the HDMI connection, which can then be routed to a digital recorder or similar device.
The D600 is compatible with more than 70 NIKKOR AF and AF-S lenses for maximum versatility. Those with DX-format lenses will also be happy to know that these lenses can also be used on the camera as well as the ability to set DX crop for stills or video to extend the reach of telephoto or telephoto zoom lenses.
The new Nikon HD-SLR is also a gateway to Nikon’s renowned Creative Lighting System (CLS) which illuminates a whole new world of creative image making using multiple Speedlights. A built-in Speedlight commander can control multiple Speedlights such as Nikon’s SB-700, SB-910 or Wireless Close Up Speedlight System, and the camera can also control up to two individual speedlight groups for further creative control.
[youtube id=”z1-BD9S08UQ” width=”610″ height=”373″]
The D600’s hand grip has been improved for comfort, while the overall impression from using the camera is reassuringly solid. The shutter button has been recessed, while the Mode Dial can be locked. The body of the D600 is sealed and gasketed against dirt and moisture. The camera uses magnesium alloy top and rear construction to provide a lightweight camera with maximum durability. The shutter has been tested for 150,000 cycles, and sensor cleaning is also employed. The battery is rated for approximately 900 shots. Additionally, the optional MB-D14 Multi Power Battery Pack extends the grip for comfort and can effectively double the battery capacity when using two batteries. An optional WU-1b Wireless Adapter is also available.
Price and Availability
$2,099.95 → Nikon D600 (body only)
$2,699.95 → Nikon D600 with the AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR
376 Comments
Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
