DSLR Cameras
Nikon D500 DSLR Camera
Nikon announced the D500, a DX-format 21-megapixel DSLR with pro-level features, claiming the best combination of speed, reach and connectivity in a compact and lightweight body. Like its sibling the D5, the D500 benefits from Nikon’s latest technological innovations such as the totally new, blazing-fast Multi-CAM 20K 153-point AF system and 4K UHD video capture, yet adds a fun new way to share photos with Nikon SnapBridge built-in.
Pro-Level Image Quality, DX-Format Versatility
The D500 imagines the best of both worlds, offering advanced enthusiasts and pro photographers all the benefits of DX-format, such as smaller form-factor and lens crop, combined with many of the same advanced pro features found in the new Nikon D5. The new Nikon D500 features an all-new 20.9-megapixel DX-format CMOS sensor that renders images with outstanding colors and gorgeous tonality. This new sensor is coupled with Nikon’s new EXPEED 5 image processing engine, affording low noise and maximum processing power with a surprisingly small footprint and superbly balanced body.
The benefits of the DX-format are evident for long-distance applications like wildlife and sports photography, where telephoto ability is at a premium and weight reduction is welcome. With Nikon’s legendary FX or smaller-sized DX-format NIKKOR lenses, the sleek D500 is the ideal companion for wanderlust. When mated with the new AF-S NIKKOR 200-500mm f/5.6E ED VR lens, the D500 offers a remarkable 350-750mm equivalent focal range for a lightweight, yet super-telephoto duo.
Because amazing images can happen even when the sun goes down, the D500 is capable of excellent low-light performance, with an ISO range of 100-51,200, expandable to 50-1,640,000 equivalent. From low-light cityscapes to action sports under the lights, the D500 is ready to tackle any imaging challenge.
Performance Meets Portability
Within the streamlined body of the D500 is a formidable processing powerhouse. Whether photographing sideline sports for the home team or animals in exotic destinations, a super-fast 10 frames-per-second (fps) burst speed with full AF and AE will help nail nearly any shot. This extreme speed lets users capture every fleeting moment in exceptional clarity, while a generous buffer allows for up to 79 shots (14-bit, uncompressed RAW/NEF) to be captured, so the moment won’t be missed.
To keep pace with the action, the D500 is fitted with the same AF system as the Nikon D5, the Multi-CAM 20K AF sensor module, with a separate dedicated processor for AF function. On the D500’s DX format sensor, the 153-point AF array fills the frame from side to side, letting users flawlessly track and lock-onto subjects from the edges of the viewfinder. Like the D5, the D500 utilizes the new 180K RGB Metering system and Advanced Scene Recognition System to help ensure balanced exposures and fantastic color rendition in nearly any shooting situation.
Controls and Rugged Construction
The D500 features an enhanced level of robust build quality, offering the same amount of rugged weather sealing as the Nikon D810. The durable body is a monocoque structure composed of magnesium alloy for the top and rear, while the front is reinforced with lightweight carbon fiber. The shutter mechanism has been tested for 200K actuations, helping to ensure maximum endurance. For further durability, the D500 excludes a pop-up flash, yet is compatible with Nikon’s newest radio frequency capable flash, the SB-5000 Speedlight (with optional WR-R10 & WR-A10).
Nikon D500 back
It’s easy to compose and view images on the D500’s bright 3.2-inch, high resolution (2359K-dot) touchscreen LCD, which lets users interact with photos in playback, control the camera and operate menus. When mounted on a tripod or shooting from creative angles, landscape and event shooters will appreciate the reinforced tilting LCD screen, similar to that of the Nikon D750. Additionally, images are rapidly written to either a fast XQD card slot or to the additional SD card slot for maximum workflow efficiency.
Constant Connectivity with the New Nikon SnapBridge
The D500 marshals in a new way to share photos wirelessly with the new Nikon SnapBridge, making the camera’s built-in connectivity easier to use than ever before. SnapBridge allows for Bluetooth2 supported connection between your camera and compatible smart device, thus making automatic upload of your images possible. Once enabled, the camera stays connected to the smart device and transfers photos, eliminating the need to re-connect devices. Those looking to share images from their travels or from the field can also tag images for transfer in camera and can password protect their connection for added security. As an added benefit, the D500’s built-in Near Field Communication (NFC)3 capability easily connects the camera to a compatible smart device with just a tap, while built-in Wi-Fi3 capability allows for faster wireless image transfer.
For those looking for an even faster transfer solution, the D500 is also compatible with the new optional WT-7A Wireless Transmitter, enabling wired or wireless transmission of files to an FTP server or computer at faster speeds.
Advanced Video Features
Just like the D5, the D500 has the ability to capture striking 4K UHD video at up to 30p (3840×2160), as well as Full HD (1080p) video at a variety of frame rates. Ready for any production, the camera sports a host of pro video features derived from the D810, including uncompressed HDMI output and Picture Controls, but adds even more great features. These pro-level creative video features include the ability to create 4K time-lapse movies in-camera, Auto ISO smoothing to provide fluid transitions in exposure during recording, and the capability to record 4K UHD video to the card and output to HDMI simultaneously. When capturing 1080p Full HD content, the camera also has a new 3-axis electronic VR feature that can be activated regardless of the lens being used. Challenging video exposures are no problem for the D500, as it also adds in Active D-Lighting to Full HD video to balance exposure values within a scene to help prevent blown-out highlights
Price and Availability
The new Nikon D500 DSLR will be available in March 2016:
  • $1,999.95 for the body-only configuration.
  • $3,069.95 for kit bundled with the versatile AF-S DX NIKKOR 16-80mm f/2.8-4E ED VR ED VR lens
The MB-D17-battery pack will also be available in March 2016 for $449.95 and will add extended battery life and facilitate vertical shooting. The WT-7A Wireless Transmitter will be available in March 2016 for $934.95.
Man wearing Focal Bathys Black Edition Wireless Headphones
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Naim CI-Uniti 102 Streaming Amplifier Angle Naim CI-Uniti 102 Streaming Amplifier Angle
At only $1,499 USD, the Naim CI-Uniti 102 feels like a streamlined Uniti Atom in a pair of skinny jeans.
Sony UBP-X700/K 4K Blu-ray Disc Player Tray Open Front Angle Sony UBP-X700/K 4K Blu-ray Disc Player Tray Open Front Angle
At $300, Sony is going to make UHD 4K fans both happy and somewhat upset with new UBP-X700/K Blu-ray disc player for 2025.
Triangle BR04 Stand-mount Loudspeakers in Chestnut Lifestyle Triangle BR04 Stand-mount Loudspeakers in Chestnut Lifestyle
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Philips Roku 65-oinch OLED TV Philips Roku 65-oinch OLED TV
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Rotel DX-3 Black Angle Front Lifestyle with Headphones Rotel DX-3 Black Angle Front Lifestyle with Headphones
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
