Compact Cameras
Nikon COOLPIX S8200 Digital Camera
Nikon announced the high-performance COOLPIX S8200 super zoom digital camera, a compact COOLPIX S-series model equipped with a 14x Optical Zoom-NIKKOR ED glass lens, 16.1-megapixel CMOS sensor with advanced functions in a surprisingly compact body (approximately 1.3-inch depth).
The S8200 is the successor to the COOLPIX S8100. The S8200 is a high-spec compact digital camera equipped with a backside illumination CMOS image sensor. Its 14x optical zoom lens covers a broad range of focal lengths, beginning at the wide-angle 25 mm (equivalent in 35mm [135] format). Despite these features, the S8200 is roughly the same size as its predecessor. In addition to new features such as Target finding AF, with which the user need simply point the camera at the intended subject and the camera automatically detects that subject and focuses on it, and Smile timer continuous, with which the camera automatically detects smiling faces and captures up to five shots at the moment the human subject smiles, the S8200 offers the functions and performance users have come to expect including continuous shooting, support for recording of full-HD movies and high-speed response.
Nikon COOLPIX S8200 Digital Camera - Top
The COOLPIX S8200's speedy performance is accelerated thanks to its high-speed continuous shooting which can capture five shots at up to six frames-per-second (fps) and a pre-shooting cache that records images before releasing the shutter to capture the action faster than a user's reflexes. From fast-paced action shots to nights out on the town with friends, the COOLPIX S8200 helps to ensure that every moment is captured. Additionally, photos and movies are composed, captured and edited easily on the bright 3.0-inch (921,000-dot) LCD display.
The COOLPIX S8200 features Full HD (1080p) video with stereo sound and amazing optics that lets the user capture with confidence. For even more dynamic movies, consumers have the ability to zoom during recording. To help further unleash creativity, the COOLPIX S8200 has a host of Special Effects (when shooting movies and stills) and Filter Effects (in playback mode for still images), including Selective Color and Fisheye Effect.
Nikon COOLPIX S8200 Digital Camera - Back in red
Price and Availability
The COOLPIX S8200 will be available in mid September 2011 for $329.95 in a choice of colors including black, silver and red.
Specifications
Effective pixels 16.1 million
Image sensor 1/2.3-in. type CMOS; total pixels: approx. 16.79 million
Lens 14x optical zoom, NIKKOR lens 4.5-63.0mm (angle of view equivalent to that of 25-350 mm lens in 35mm [135] format)
f/3.3-5.9; Digital zoom Up to 2x (angle of view equivalent to that of approx. 700 mm lens in 35mm [135] format)
Focus range
(from lens)
[W]: Approx. 50 cm to ∞,
[T]: Approx. 1.0 m to ∞,
Macro mode: Approx. 1 cm to ∞ ( wider than Δ )
Monitor 7.5 cm (3-in.), approx. 921k-dot, wide viewing angle TFT LCD with anti-reflection coating and 5-level brightness adjustment
Storage media Internal memory (approx. 89 MB), SD/SDHC/SDXC memory card
ISO sensitivity ISO 100, 200, 400, 800, 1600, 3200
Auto (auto gain from ISO 100 to 1600)
Fixed range auto (ISO 100 to 400, ISO 100 to 800)
Interface Hi-Speed USB
HDMI output Can be selected from Auto, 480p, 720p, and 1080i
Power sources One Rechargeable Li-ion Battery EN-EL12 (supplied)
AC Adapter EH-62F (available separately)
Battery life
(EN-EL19)
Still pictures: Approx. 250 shots
Movies: Approx. 1h 10 min (HD 1080p). (The maximum file size for a single movie is 4 GB and the maximum movie length for a single movie is 29 minutes, even when there is sufficient free space on the memory card for longer recording.)
Dimensions(WxHxD) Approx. 103.7 x 59.3 x 32.7 mm
Weight Approx. 213 g (including battery and SD memory card)
Supplied accessories Camera Strap, Rechargeable Li-ion Battery EN-EL12, Charging AC Adapter EH-69P, USB Cable UC-E6, Audio Video Cable EG-CP16, ViewNX 2 CD-ROM
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
