Compact Cameras
Nikon COOLPIX S6200 Digital Camera
Nikon announced the 16-megapixel COOLPIX S6200 superzoom digital camera with a 10x optical zoom NIKKOR lens in a slim, compact body. In addition to offering excellent basic performance with superior image quality and high-speed response, the S6200 is equipped with four features–less noise at high sensitivities, Motion detection function, lens-shift vibration reduction (VR) function, flash control system–that enable capture of beautiful nighttime shots.
The S6200 is also equipped with a hand-held/tripod night landscape detection function that enables it to automatically distinguish between hand-held shooting and shooting with the camera mounted on a tripod to provide the optimum response to shooting conditions regardless of lighting levels, making successful capture of blur-free night landscapes even easier. What's more, Special effects mode for shooting and Filter effects for editing photos already taken allow you to create artistic photos and movies never before possible.
Nikon COOLPIX S6200 Digital Camera - Top
The COOLPIX S6200 is easy-to-carry, yet stylish solution for capturing memorable images in an instant. Beautiful photos are achieved with the help of the S6200's 16.0-megapixel resolution and VR system to eliminate blur. With HD (720p) movie recording, a large 2.7-inch LCD display and a selection of Special Effects, creating unforgettable photos and movies is a breeze.
Price and Availability
The Nikon COOLPIX S6200 will be available in mid September 2011 for $229.95 in red, pink, silver, blue and black.
Nikon COOLPIX S6200 Digital Camera - Back
Specifications
Effective pixels 16.0 million
Image sensor 1/2.3-in. type CCD; total pixels: approx. 16.44 million
Lens 10x optical zoom, NIKKOR lens 4.5-45.0mm (angle of view equivalent to that of 25-250 mm lens in 35mm [135] format) f/3.2-5.8; Digital zoom Up to 4x (angle of view equivalent to that of approx. 1000 mm lens in 35mm [135] format)
Focus range(from lens) [W]: Approx. 50 cm to infinity, [T]: Approx. 1.0 m to infinity, Macro mode: Approx. 10 cm to infinity ( wide-angle position )
Monitor 6.7 cm (2.7-in.), approx. 230k-dot, TFT LCD with anti-reflection coating and 5-level brightness adjustment
Storage media Internal memory (approx. 74 MB), SD/SDHC/SDXC memory card
ISO sensitivity ISO 80, 100, 200, 400, 800, 1600, 3200 Auto (auto gain from ISO 80 to 1600) Fixed range auto (ISO 80 to 400, 80 to 800)
Interface Hi-Speed USB
HDMI output Can be selected from Auto, 480p, 720p, and 1080i
Power sources One Rechargeable Li-ion Battery EN-EL12 (supplied) AC Adapter EH-62F (available separately)
Battery life(EN-EL19) Still pictures: Approx. 250 shots Movies: Approx. 1h 40 min (HD 720p). The maximum file size for a single movie is 4 GB and the maximum movie length for a single movie is 29 minutes, even when there is sufficient free space on the memory card for longer recording.
Dimensions(WxHxD) Approx. 93.0 x 56.7 x 25.4 mm
Weight Approx. 160 g (including battery and SD memory card)
Supplied accessories Camera Strap, Rechargeable Li-ion Battery EN-EL12, Charging AC Adapter EH-69P, USB Cable UC-E6, Audio Video Cable EG-CP16, ViewNX 2 CD-ROM
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
