Compact Cameras
Nikon COOLPIX S1200pj Digital Camera with Built-in Projector
Nikon today announced its third-generation projector-equipped digital camera, the COOLPIX S1200pj offering a 40% increase in projection brightness and three times greater projection contrast, enabling projection of vivid images at a projection size of up to 60-inch display. In addition, the S1200pj can be connected to an iPhone, iPad or iPod touch via the dedicated cable, allowing users to project images and movies stored on these devices as well as online content from websites such as YouTube.
The S1200pj truly offers new ways of using a camera by overcoming distance with the ability to view and project images and movies users have recorded themselves as well as images and movies acquired from around the world via the Internet.
Nikon COOLPIX S1200pj Digital Camera with Built-in Projector - Top
Building off last year's COOLPIX S1100pj model, the new S1200pj provides a brighter 20-lumen built-in projector, 14.1-megapixel resolution, 5x Optical Zoom, HD (720p) movie capture with stereo sound and a 3.0-inch LCD screen display to help compose at the touch of a finger. The user can also add their artistic touch to their images with a variety of Special Effects and Filter Effects. Compact enough to slip into a pocket, the COOLPIX S1200pj goes wherever life takes it.
Price and Availability
The COOLPIX S1200pj will be available in mid September 2011 for $429.95 in black and pink.
Nikon COOLPIX S1200pj Digital Camera with Built-in Projector - Back
Specifications
Effective pixels 14.1 million
Image sensor 1/2.3-in. type CCD; approx. 14.48 million total pixels
Lens 5× optical zoom, NIKKOR lens; 5.0-25.0mm (angle of view equivalent to that of 28–140 mm lens in 35mm format); f/3.9–5.8;
Digital zoom: Up to 4× (angle of view equivalent to that of approx. 560mm lens in 35mm format)
Focus range (from lens) [W]: Approx. 1 ft (30 cm) to infinity, [T]: Approx. 1 ft 8 in. (50 cm) to infinity,
Macro mode: Approx. 1.2 in (3 cm) to infinity (wide-angle position)
Monitor 3-in. , approx. 460,000-dot, TFT LCD monitor with anti-reflection coating 5-level brightness adjustment
Storage media Internal memory (approx. 94 MB), SD/SDHC/SDXC memory card
ISO sensitivity ISO 80, 100, 200, 400, 800, 1600, 3200, 6400
Auto (auto gain from ISO 80 to 800)
Fixed range auto (ISO 80 to 200, 80 to 400)
Interface Hi-Speed USB
Power sources One Rechargeable Li-ion Battery EN-EL12 (supplied)
AC Adapter EH-62F (available separately)
Battery life (EN-EL12) Still pictures: Approx. 220 shots
Movies: Approx. 1 h 40 min (HD 720p (1280×720))
Dimensions (WxHxD) Approx. 4.3 x 2.5 x 0.9 in. (107.0 × 63.4 × 22.6 mm) (excluding projections)
Weight Approx. 6.6 oz. (186 g) (including battery and SD memory card)
Supplied accessories Camera Strap CP-19, Rechargeable Li-ion Battery EN-EL12, Charging AC Adapter EH-69P, USB Cable UC-E6, Audio Movie Cable EG-CP16, ViewNX 2 CD-ROM, PC-PJ Transfer CD-ROM
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
