Nikon COOLPIX P900 Superzoom Digital Camera
Nikon COOLPIX P900 Digital Camera
Nikon just announced the 16-megapixel COOLPIX P900 digital camera, which offers an incredible 83x optical zoom with built-in Wi-Fi and NFC, for $600. Its long zoom (24-2000mm equivalent) lens provides users with incredibly sharp NIKKOR optics, while its 166x Dynamic Fine Zoom range reaches even farther distances. Plus its high performance Autofocus (AF) system shoots at 7 frames-per-second (fps). Then share photos from the camera to a compatible smartphone or tablet via Snapbridge technology.
Nikon COOLPIX P900 Back View
Users can easily and intuitively frame their subjects by using the camera’s built-in electronic viewfinder (EVF) with an eye sensor or high-resolution, Vari-angle 3-inch 921K-dot LCD display. Users can utilize the camera’s snap-back zoom button to effortlessly frame subjects when shooting super-telephoto shots, while the Side Zoom Control button’s position helps to combat camera shake. Additionally, the camera has an intuitive control layout, with the Fn (function) button providing fast access to frequently used functions, plus the Command Dial and Mode Dial allow users to quickly apply or adjust settings with just one hand. The COOLPIX P900 also features Manual (spot), Manual (normal) and Manual (wide) AF Area Mode options that can be selected in accordance with the size and position of the primary subject.
Nikon COOLPIX P900 Angle Back View LCD
The COOLPIX P900 boasts a speedy shooting lag time of approximately 0.12 seconds at the maximum wide-angle position and approximately 0.75 seconds at the maximum telephoto position. This rapid performance allows users to capture clear back-to-back shots of a runner dashing toward the finish line or a baseball player headed towards home plate with rich detail. What’s more, the camera incorporates the new Dual Detect Optical VR technology to help achieve the highest level of camera shake compensation available in a Nikon compact digital camera, equivalent to a 5.0-stop increase in shutter speed to help ensure sharp photos.
Nikon COOLPIX P900 Top View
The COOLPIX P900 offers fun and user-friendly features like Scene Modes, filter effects, special effects, Picture Controls and macro mode to help users not only find the best settings for nearly any environment, but allow them to add a personal touch to every image or video. Additionally, users can capture video in Full HD 1080p with stereo audio recording or use the camera’s innovative Time Lapse feature to capture a beautiful sunrise or sunset video over the course of time. When recording video from afar, the Zoom Microphone function helps to enables clear recording of sounds from a variety of distances. Lastly, the COOLPIX P900 makes it easy to document every vacation spot or outdoor adventure as the camera’s built-in GPS and POI allows users to geo-tag images and view where those images were taken on a map.
Price and Availability
The COOLPIX P900 will be available April 2015 in black for $599.95.
Toshiba Aurex AX-RP10 Portable Vinyl Record Player
Earbuds & In-Ear Headphones
In-Wall Speakers
