Compact Cameras
Nikon CoolPix P7000 Digital Camera
Full Manual Controls and Superior NIKKOR Optics Plus Advanced Photo and Video Features in a Camera That Evokes SLR Familiarity
Nikon Inc. today introduced the COOLPIX P7000, the ultimate compact camera that's ready to take on most any photo assignment. At home in a pro's gadget bag or in the hands of a spirited enthusiast, passionate photographers of all levels will benefit from the P7000's high performance, extensive manual controls, stunning image quality and advanced shooting functions.
The 10.1-megapixel COOLPIX P7000 features a large 1/1.7″ CCD sensor coupled with a 7.1x Wide Angle Optical Zoom-NIKKOR ED Glass Lens for consistent superior image quality that explodes with vivid color and sharpness frame after frame. Taking Nikon's commitment to image quality a step further, the P7000 adopts Nikon's new EXPEED C2 high performance digital image processing engine to ensure high-quality pictures with stunning color and sharpness.
Nikon CoolPix P7000 Digital Camera - Top
ISO sensitivity ranges from ISO 100 to 6400 (expandable to ISO 12,800 in low noise Night Mode) to ensure incredibly sharp, crisp images when shooting in low-light or photographing fast-moving subjects. The P7000 also offers a variety of functions that enable superior rendering when shooting at high sensitivities, including a Low Noise Night Mode and a Noise Reduction Filter. The camera also features 5-Way VR Image Stabilization System, which utilizes a variety of tactics including optical lens shift to minimize the effect of camera shake to help banish the blur while shooting handheld or in low-light.
Thoughtful engineering has led to the addition of features that will be welcome to current D-SLR users. The Zoom Memory function allows the camera's 28-200mm (35mm equivalent) lens to be used in a way that simulates use of a prime lens, ideal for shooting at a preferred angle of view. The P7000 also adds controls and buttons for key features like ISO, white balance, bracketing and exposure compensation. The new innovative and independent Quick Menu dial ensures easy access to key functions with the comfort of analog operation. Advanced users will also enjoy the benefits of shooting RAW/NRW* files for creative freedom, and macro abilities as close as 0.8 inches.
Nikon CoolPix P7000 Digital Camera - Back
While the image quality of the P7000 is nothing short of stellar, the video capabilities are far beyond that of a typical compact. The P7000 records HD video at 720p at 24 frames-per-second (fps) with optical zoom and autofocus control. A COOLPIX first, users can now record audio with an external stereo microphone via the microphone input. An accessory microphone or Nikon Speedlight can be mounted on the P7000's hot shoe.
Additional features of the Nikon COOLPIX P7000 digital camera include:
  • 7.1x Wide-Angle Optical Zoom-NIKKOR ED glass lens (28-200mm f/2.8-5.6) allows for detailed close-ups and dramatic landscapes.
  • 3.0-inch 921,000-dot Clear Color Display with wide viewing angle makes it easy to compose, view and share still images and movies that come alive with rich detail and improved contrast.
  • Large optical viewfinder with diopter adjustment dial
  • Tone Level Information helps photographers achieve their desired exposure with a histogram display, allowing them to determine the exposure while checking the balance between highlights and shadows.
  • Electronic Virtual Horizon Indicator gives the user visual confirmation that the camera has a level horizon.
  • In-camera editing functions include exposure compensation, COOLPIX Picture Control, noise reduction filter, Quick Retouch, D-Lighting and Active D-Lighting.
  • 5-Way Vibration Reduction (VR) Image Stabilization System
    • Optical VR Image Stabilization by lens shift minimizes the effects of camera shake.
    • Hybrid VR Image Stabilization by lens shift and electronic VR.
    • Motion Detection automatically detects moving subjects and adjusts shutter speed and the ISO setting to compensate for camera shake and subject movement.
    • High ISO up to 6400 at full resolution for optimal results when shooting in low-light or photographing fast-moving subjects.
    • Best Shot Selector (BSS) automatically takes up to 10 shots while the user presses the shutter and saves the sharpest image.
  • Full Manual Controls-PSAM (Program, Shutter, Aperture, Manual) control gives creative control over images.
  • NRW (RAW) file function compatible with Mac® and Windows® Operating Systems.
  • Bracketing functions for Automatic Exposure (Sv and Tv) and White Balance allows the user to take consecutive shots with slightly different settings and select the one that best matches their intention.
  • HD (720p) Movie with Stereo, Mic Input Jack and HDMI Output records at 24 fps with optical zoom, autofocus and stereo sound.
  • Subject Tracking automatically activates autofocus while tracking moving subjects, like active children or unpredictable animals.
  • Scene Auto Selector automatically recognizes the shooting situation and adjusts the camera's settings accordingly for great pictures anywhere.
  • Smart Portrait System integrates the following features to make it a snap to capture stunning portraits:
    • In-Camera Red-Eye Fix automatically fixes most instances of red-eye.
    • Enhanced Face-Priority AF can detect up to 12 faces from a variety of angles.
    • Skin Softening ensures smooth skin tone on the face of subjects by leveraging built-in face-detection technology.
    • Smile Timer automatically detects when a subject smiles and releases the shutter.
    • Blink Warning alerts the photographer if a subject has blinked.
Price and Availability
The Nikon COOLPIX P7000 will be available in late September 2010 for $499.95 MSRP.
* ViewNX 2(supplied) and Capture NX 2(available separately) are required to open NRW files on a computer. The application or updates can be downloaded from Nikon's website.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
