Compact Cameras
Nikon COOLPIX L10 and L11 Digital Cameras Announced
Upload Upload Upload
Easy shooting with smooth operation, enabling anyone to get great results, more of the time.
Nikon Corporation is pleased to announce the introduction of the COOLPIX L11 and the COOLPIX L10. With the COOLPIX L11 packing 6.0 effective megapixels and the L10 packing 5.0 effective megapixels, and both cameras offering easy operation, they enable even absolute beginners to take great-looking pictures.
Each featuring a powerful 3x Nikkor-Zoom lens with a focal range of 37.5-112.5mm (35mm equivalent), the COOLPIX L11 and L10 make it easy for users to capture special moments with friends and family, anytime. And because they offer the aforementioned image resolution of 6.0 and 5.0 effective megapixels respectively, the COOLPIX L11 and L10 are great for capturing fine detail with sharpness that remains even when images are significantly enlarged.
What’s more, both cameras offer high light sensitivity up to ISO 800, which makes it easier to produce quality shots in low light conditions without using a slower exposure. Such sensitivity also makes it possible to use much faster shutter speeds in ordinary lighting conditions to capture fast-moving subjects with greater sharpness.
Both cameras additionally feature large LCD monitors that make for easy image composition and handy playback anywhere. The LCD of the COOLPIX L11 measures an impressive 2.4-inches across while that of the L10 measures 2.0-inches across — ample dimensions that make it easy for everyone to gather round and enjoy the results.
Adding a further element of convenience, both the COOLPIX L11 and L10 are compatible with AA-size batteries. Such batteries are, of course, widely available around the world, which means users never have to worry about running out of power, no matter where they happen to be. What’s more, the COOLPIX L11 and L10 both feature three unique Nikon innovations that enable anyone to improve their images in-camera — Face-priority AF* that automatically detects and achieves sharp focus on people’s faces wherever they are in the frame, In-Camera Red-Eye Fix that can automatically overcome the red-eye effect sometimes caused by flash, and Nikon’s D-Lighting that can rescue underexposed images or shots taken with too much backlight.
Furthermore, like all other cameras in the popular Nikon COOLPIX range, both the COOLPIX L11 and L10 come bundled with Nikon’s exclusive PictureProject software. Powerful, yet exceptionally easy to use, PictureProject makes it a snap to transfer, organize, edit and share photos with family and friends.
* Face recognition capability may be limited in some shooting conditions.
Note: Specifications, design, product name, standard accessories, and release schedule may differ by country or area.
Nikon COOLPIX L11/L10 Feature Highlights
Compatible with AA batteries
Unlike many compact digital cameras on the market the COOLPIX L11 and the COOLPIX L10 are compatible with AA-size batteries. Thanks to this advantage, users never have to worry about recharging their batteries or running out of power at an unfortunate moment. They can simply pick up a new set of batteries no matter where they are in the world and keep on shooting without worry.
A design exuding high quality
With the COOLPIX L11 and L10, the high quality of the images is complemented by superior body design. Slim and compact, they fit comfortably in the hand to promote natural, yet steady shooting, while the lens retracts when not in use to make both cameras even more compact for carrying. What’s more, they are also available in a range of attractive colors.
Nikon COOLPIX L11/L10 Other Features
  • Light weight with compact dimensions
  • Choice of 16 Scene modes
  • Selection of movie recording modes
  • BSS (Best Shot Selector) identifies and saves the sharpest image automatically from ten sequential shots
  • SDHC memory card compatibility
  • Voice recording capability
  • Color Options add to creative freedom
  • 7MB of internal memory (approx.)
  • PictBridge compatible
  • ImageLink compatible (L11 only)
  • Menu available in a choice of 20 languages
  • USB connectivity enables swift data transfer to computers
  • Macro shooting enables shooting from as close as 15cm (5.9 in.)
  • Time zone function allows setting of home town and new city time zone for easy image sorting after traveling
  • 4x digital zoom extends compositional freedom
  • Choice of White Balance
  • Auto with TTL control, 7-mode manual (Direct sunlight, Incandescent,
  • Fluorescent, Cloudy, Shade, Flash and White Bal. Preset)
Note: Available colors may differ by country or area.
Nikon Digital Camera COOLPIX L11/L10 Specifications
Effective pixels L11: 6.0 million
L10: 5.0 million
Image sensor 1/2.5-in. CCD; total pixels: approx. 6.18 million (L11)/ 5.05 million total pixels (L10)
Lens 3x Zoom-Nikkor; 6.2-18.6mm (35mm [135] format picture angle: 37.5-112.5mm); f/2.8-5.2; 6 elements in 5 groups; Digital zoom: up to 4x (35mm [135] format picture angle: approx. 450mm)
Focus range (from lens) 40cm (1 ft. 4 in.) to infinity (∞), Macro close-up mode: 15cm (5.9 in.) to infinity (∞)
Monitor L11: 2.4-in., 115,000-dot, TFT LCD with brightness adjustment
L10: 2.0-in., 153,000-dot, TFT LCD with brightness adjustment
Storage Media Internal memory (approx. 7 MB), SD memory cards
Movie With sound: TV movie (640) at 30fps/15fps, Small size (320) at 30fps/15fps, Smaller size (160) at 15fps
Image size (pixels) L11: 2816 x 2112 (High: 2816*/Normal: 2816), 2048 x 1536 (Normal: 2048), 1024 x 768 (PC screen: 1024), 640 x 480 (TV screen: 640)
L10: 2560 x 1920 (High: 2560*/Normal: 2560), 2048 x 1536 (Normal: 2048), 1024 x 768 (PC screen: 1024), 640 x 480 (TV screen: 640)
ISO sensitivity Auto (auto gain ISO 64-800)
Built-in flash Range: (W) approx. 0.4-3.0m (1 ft. 4 in. — 9 ft. 10 in.), (T) approx. 0.4-2.5m (1 ft. 4 in. — 8 ft. 2 in.)
Interface USB
Languages Czech, Danish, German, English, Spanish, French, Indonesian, Italian, Dutch, Norwegian, Polish, Portuguese, Russian, Finnish, Swedish, Chinese (Simplified and Traditional), Japanese, Korean, Thai
Power sources Two AA alkaline, oxyride, or lithium batteries, two EN-MH1 rechargeable NiMH batteries (optional), EH-65A AC adapter (optional)
Battery life Approx. 250 shots with alkaline, 600 shots with lithium, or 300 shots with EN-MH1, or 250 shots with oxyride batteries (based on CIPA standard)
Dimensions (W x H x D) L11: 89.5 x 60.5 x 27 mm (3.5 x 2.4 x 1.1 in.) excluding projections/
L10: 89.5 x 60.5 x 26 mm (3.5 x 2.4 x 1.0 in.) excluding projections
Weight L11: Approx. 125 g (4.4 oz.) without battery and SD memory card
L10: Approx. 115 g (4.1 oz.) without battery and SD memory card
Supplied Accessories* Two 1.5V LR6 AA-size alkaline batteries, USB Cable UC-E6, Audio Video Cable EG-CP14(L11 only), Strap, Dock Insert PV-14(L11 only), PictureProject CD-ROM
Optional Accessories Battery Charger MH-71, Ni-MH Rechargeable Battery EN-MH1, AC Adapter EH-65A, Audio Video Cable EG-CP14
*Supplied accessories may differ by country or area.
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
