Camera Lenses
Nikon AF-S NIKKOR 24-120mm f/4 G ED VR Lens
The AF-S NIKKOR 24-120mm f/4G ED VR is a 5X standard zoom lens with a fixed maximum aperture of f/4 throughout its entire zoom range. Nano Crystal Coat has been deposited on some lens elements for fine, clear images, and the lens is equipped with Nikon's latest vibration reduction mechanism, VR II.
The new AF-S 24-120mm f/4 G ED VR zoom lens redefines the wide-to-portrait lens category, and provides users with a medium focal range lens with a constant aperture that is ideally suited for a wide variety of photographic disciplines. This high performance lens offers a constant maximum aperture of f/4 to maintain exposure settings throughout the entire zoom range and is perfect for photographing landscapes, portraits, interiors and weddings. The 24-120mm f/4 also features two ED elements, three aspherical lens elements, a useful M/A Focus Mode Switch, Internal Focus and Nano Crystal Coat to reduce ghosting and flare for greater image clarity throughout the entire frame.
Features
  • A 5X standard zoom lens with a fixed maximum aperture of f/4 through the full 24mm to 120mm range of focal lengths
  • A 5X standard zoom lens that offers superior function and performance. This zoom lens has a high reproduction ratio that is both practical and functional for professional and advanced amateur photographers. It consistently demonstrates excellent rendering performance.
  • Built-in vibration reduction (VR II) offering camera shake compensation equivalent to a shutter speed increase of approximately four steps
  • Equipped with two VR modes, Normal and Active, the vibration reduction function responds to a variety of shooting scenes.
  • Nano Crystal Coat adopted to significantly reduce ghost and flare
  • Nikon's internal focusing (IF) system has been adopted with no increase in the length of the lens
  • Equipped with two ED and three aspherical lens elements for superior optical performance
  • Equipped with two focus modes, M/A (autofocus with manual override) and M (manual)
  • Equipped with a Silent Wave Motor (SWM) for extremely quiet autofocusing
Price and Availability
The versatile AF-S NIKKOR 24-120mm f/4 G ED VR will be available in September 2010 for $1,049.95 MSRP.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
