Mirrorless Cameras
Nikon 1 V2 Digital Camera
Nikon 1 V2
Nikon recently released the 14.2-megapixel Nikon 1 V2 interchangeable lens system camera offering a balance of portability and performance. The V2 adds a new ergonomic grip for familiar handling, a built-in flash and the addition of a Command Mode Dial to provide easy access to features and controls. Nikon also introduced the new SB-N7, an optional compact speedlight that offers versatile lighting possibilities for Nikon 1 V1 and Nikon 1 V2 shooters.
The new Nikon 1 V2 delivers astoundingly rapid Autofocus (AF) and shooting response, incredible image quality, sharp Full HD video and advanced yet easy-to-use shooting options. The V2 offers a new 14.2-megapixel CX-format super high-speed CMOS sensor that has been engineered to allow for amazing image quality that exhibits eye-catching colors, rich hues and striking detail. The upgraded sensor combined with the blazing fast Advance Hybrid AF system allows users to shoot up to 15 frames-per-second (fps) while maintaining full AF tracking that allows the capturing of fast moving subjects. Other new and noteworthy features include versatile and fun shooting modes such as Best Moment Capture Mode and the new Live Image Control that lets a user preview their creative vision, pre-capture.
The new V2 sports an enhanced design that includes a comfortable traditional grip as well as a textured camera body and thoughtfully placed mode dials. With easy access to the new top-placed Command Dial, V2 shooters will be able to make camera adjustments quickly and easily, even when framing photos in the camera’s 1.4-million-dot electronic viewfinder. The camera also includes a new Direct Setting Control that enables quick access to settings in manual exposure modes (P,S,A,M), so that settings can be changed without taking an eye off the electronic viewfinder or the high-resolution 921,000-dot 3.0-inch LCD display.
The camera also includes the new EXPEED 3A image processing engine, both specifically designed to produce still images and HD video with stunning clarity and color. Additionally, the new EXPEED 3A has improved image-signal processing capability as well as high-speed readout.
A wide ISO range (160-6400) allows the V2 to perform brilliantly in tough lighting conditions, while the highly responsive Advanced Hybrid Autofocus (AF) system provides users with superfast shooting speeds, allowing them to capture fast action with crisp focus, whether at a football game or dance recital. The Nikon 1 V2’s 73 point AF array ensures accuracy and super precise focus, even on moving subjects. The camera also provides high-speed continuous shooting with continuous Auto focusing letting users capture approximately 15 fps up to 45 frames. High-speed continuous shooting at approximately 60 fps for up to 40 frames is also possible.
The Nikon 1 V2’s new top-placed Mode Dial, allows users to access the camera’s Auto Mode as well as full manual controls on the fly. The camera is also equipped with an Enhanced Motion Snapshot Mode, which users can utilize to capture fleeting moments with a short, slow-motion movie sequence in addition to a single defining still image. A Motion Snapshot can be saved as a four second MOV file and JPEG image file separately or it can also be saved as a 10 second movie file without a separate JPEG image file, making it easy to share with others. Furthermore, Motion Snapshots can be combined into a continuous slideshow seamlessly within the camera.
The Nikon 1 V2 also includes Best Moment Capture Mode, an advanced creative mode that allows individuals to use Slow View to slow down a moment they are capturing, in real time. By simply pressing the shutter button halfway down when focused, users can capture live action (approx. 1.33 seconds), while the view of the subject is displayed at five times slower than normal speed (approx. 6.66 sec). The action is replayed repeatedly as long as the shutter-release button is half-pressed. Fast action sports and events are transformed to slow motion right on the LCD screen, letting the user capture once-in-a-lifetime moments with confidence.
[youtube id=”MCZlvybCYrE” width=”610″ height=”373″]
Additionally, original Nikon 1 features like Smart Photo Selector are still available on this new camera, and are accessible through the Best Moment Capture Mode. When using Smart Photo Selector, V2 users can capture up to 20 shots with a single press of the shutter button, and the camera will then automatically select the five best images to keep based on factors such as exposure, focus and facial recognition. The Nikon 1 V2 also includes an Advance Movie Mode that allows for the simultaneous shooting of 1080p Full HD video and high-resolution stills of the same subject or scene. Slow motion movies at both 400 fps and 1200 fps can also be captured, plus full manual exposure controls are accessible while in Advance Movie Mode.
Image effects and image-creation functions such as in-camera HDR and the innovative Live Image Control allow users even more ways to customize their photos. Live Image Control gives users the ability to see end-result images before capture by incorporating effects of various camera settings on a scene. With Live Image Control, real time adjustments to motion control, brightness control, Active D-Lighting and background focus are seen on the LCD screen or the electronic viewfinder prior to capture to help ensure the user’s creative vision is fulfilled.
Like the other Nikon 1 system cameras, V2 shooters will have access to a growing lineup of incredible 1 NIKKOR lenses, Nikon 1 accessories, as well as F-Mount NIKKOR lenses when connected to the FT-1 Mount Adapter. The V2 is also compatible with the optional WU-1b Wireless Mobile Adapter.
A built-in pop-up flash supplies extra lighting when capturing images in low-light situations or to provide a fill flash to eliminate shadows. The camera also features a Nikon 1 i-TTL hot shoe port for use with the new SB-N7 speedlight lightweight flash unit (sold separately). The premium flash head tilts up to 120 degrees for situations that call for bouncing the flash output. The new speedlight is easy-to-use and travel friendly, and also uses common AAA batteries. The speedlight provides a guide number of 18 meters/59 feet (at ISO 100), as well as a supplied external wide flash adapter for wider shooting coverage.
Price and Availability
The Nikon 1 V2 camera with the 10-30mm lens now available for $899.95 in white or black.
Nikon’s SB-N7 speedlight will be available in January 2013 for $159.95.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
